Question about HP PSC 1610 All-In-One InkJet Printer
When making a scan or a photo copy it it prints a one inch wide black line down the middle of the page. This does not happen if a print is made from the computer. It's frustrating because the printer has very little use. Your assistance would be appreciated
  • ward5354 Aug 05, 2008
    Whether Scanning or making a Copy there is a 4" line down the left side of the entire length of the page.
  • e_oliver Aug 21, 2008
    When I scan something I have 1/2-1 inch black line down the left side of the page. So I can only scan something that I can edit the back line out. I have looked in the scanner, on the lid, and anywhere else I can think of but there is nothing there. I have no idea why it started this. My unit is a little over 2 years old.
  • 84 Answers
Try to check if there is something that you should remove from the inside top cover of the scanner
Posted on Jul 21, 2008
Getting black strip about 9/16"
it may be due to either malfunctioning of the scanner tube within the printer itself or whenever you copy a certain page the lid is not properly pace resulting to excess light on that side giving you black line when the copying is in process
Mar 06, 2011 | HP Officejet 5610 All-In-One InkJet...
Black line is present when copying document; not
This sounds as if you have some ink/contamination on the small scaning glass that sits to either the left or right of the main glass on the copier.(Depending on the model/make)As your original is scanned over this thin piece of glass the scanning device will see any spots and this will result in a black line down the page.Please clean the glass with a soft rag.
Oct 12, 2009 | Office Equipment & Supplies
Black vertical line (1 inch wide) appears while scanning/copying
For this kind of problem you need to call the tech support because the printer is already messed up and it is in need of replacement
Hope this help
Byron
Jun 15, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Whenever I scan a picture or document I get a line going down the middle of the page. When I print the same document the line prints down the page. THIS only happens on the scan not when I print from the...
first of all try to make a copy..when you make a copy if you get lines..then clean the scanner glass and the rollers..if its still the same..connect the printer directlu to the wall outlet and then check
Mar 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
3-INCH WIDE VERTICAL LINES RUND DOWN LEFT SIDE OF FAX MACHINE
Do your incoming faxes have the same marks?
If not you might find that the scanning part of your machine has a dirty mark on the glass or that the unit has become faulty.
Try and take a copy from the machine and print from a report or any print from memory.
If you have the black lines on both then i'd suggest getting a new drum unit, if u have it only on the copy I would have a look at your scanner glass and see if there is a dirty mark on it. if not maybe call out an engineer as the scanner unit maybe faulty.
Need anymore help msg me.
Dec 11, 2008 | Office Equipment & Supplies
Copies and faxes come out with 5 inch black area over whole page
Does this same thing happen if you just print a report out of it?
Here's the logic behind this.
If it happens on scanning or copying, but not on printing that's a problem with the scanning section.
If it happens on everything (scanning, printing etc) that's a problem with in the printer controls.
Usually on lasers, if it's printing related, the first thing to do is change the toner.
If the imaging drum (which is part of the toner cartridge) is damaged, it will leave lines down the page.
This is a fairly common problem on refilled toners.
If you have changed the toner, and it still does it, it's a different problem.
Aug 11, 2008 | HP LaserJet 3015 All-In-One Printer
Copy mode
Is this happening when you print or when you scan? If when scaning you could have something on the scanner bed... If this is happening when you print, it could be the cartride is defective.
Jul 06, 2007 | HP Photosmart 2575 All-In-One InkJet...
HP PSC 1610 All-In-One InkJet Printer Logo
118 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
