Question about Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television
Panasonic PT-50DL54 problems
Hi you seem real helpful and knoledgeable when it comes to this My TV keeps turning off and the red light blinks 7 times then stops then blinks again 7 times. Can you tell me which code that is please
bulb has been replaced and it continued to turn off.
  • 4,472 Answers
There actually was a class action law suit on these tv's due to the bulbs.
1 | Load Shortage
2 | Over Volage
3 | Fan Sos
4 | Main 3.3v
5 | Lamp Disable
6 | Gc3fm-Iic
7 | Gc3fs-Iic
8 | Gc3i-Iic
9 | Color Wheel Stop
there is the list of codes so yours is 7. Hope this helps.
Keep me posted.
Thanks,
Lee
Posted on Jul 21, 2008
I've replaced the lamp for my panasonic 50DL54J. When i try to turn the tv on, the power button blinks green, then turns yellow, then the lamp red light blinks..and turns off. Can you please help?
some times when the lamp is not sitting in place it will give you this problem. removed the lamp, put it back and make sure it goes all the way in. close the door and attach screws if any. remember if the lamp door is not close, your tv will not turn on. had the same problem until i reseted the lamp in place. good luck
May 13, 2011 | Panasonic PT-50DL54 50" Rear Projection...
Keeps turning off and red light is blinking 3 time
If it is Panasonic PT-53WX54 rear projection tv then 3 times red light blinking indicates problem of convergence output chips failure in tv that need to be replaced to solve its problem.
Let me know if you are handy with electronics stuff repair and can replace/ solder parts in circuit board to provide you more helpful info OR call local tv repairman to replace convergence output chips tin tv.
Thanks.
Dec 30, 2010 | Panasonic PT-53WX54 53" Rear Projection...
I have a Panasonic PT-50DL54 50" rear projection tv. My tv screen won't come on but the fans will. The power led light flashes green like normal but than starts to flash fast for about a minute than the...
Time to get a new TV. I have similar problem. In my case, the set turns off, LED blinking green for about a minute or 2, then the set will turn on by itself. Something the LED started to blink yellow after blinking green and then shuts off. I can turn it back on. This happens 3 or 4 times in an hour. After that, the TV stays on for as many hours as I want until I shut it off.
And then the problem repeats everytime I turn it on from a cold start.
I have my eyes on the 50 inch Plasma from Panasonic. Bestbuy has one for 999.99.
Jun 14, 2010 | Panasonic PT-50DL54 50" Rear Projection...
My television is a PT-50DL54. i turn it on and it will stay on for about 20 seconds and then turn itsel***. The power button light will turn red and blink
my guess is either the lamp needs replacing or there is heating issues.....mine is doing it too and I find it more during the day than night.....after it cools off outside at night, it does not do it any more, but during day, even with a fan blowing on it, it does it about every 45 minutes or so....unplugging it completely and replugging it in again seems to help make it last longer...
May 20, 2010 | Panasonic PT-50DL54 50" Rear Projection...
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic TH-42PZ700U 7 blinks
Remove the back panel. Blow out the dust with compressed air and then vacuum.
Aug 16, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Tv turned itself off and light is red blinking 3 times
sounds like the sleep timer is on. go to your menu and there should be an option to turn it off. or refer to your manual. if you have lost your manual do a quick google search for one or go to the panasonic website. hope that helps you out
Aug 06, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Power - Red light
You need to open the TV and use compressed air to blow out all the dust from the components.
May 17, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Power Button Blinking Red
Talli,
The number of blinks, called error codes, is crucial in determining what's wrong with your unit.. In this case the color wheel is faulty and needs to be replaced. In that unit the color wheel assembly is Panasonic p/n# TXFEN01RP4S and is available from many sources for about $390.00 plus shipping.
There are some companies like Tri-State-Module that have taken-up rebuilding color wheel assemblies but I can't be certain that this is one of the brand/models they support. If you can have it rebuilt you might save about half the price of a new one...
For your edification in the future here are the blink codes for your Tv:
1 | Load Shortage
2 | Over Volage
3 | Fan Sos
4 | Main 3.3v
5 | Lamp Disable
6 | Gc3fm-Iic
7 | Gc3fs-Iic
8 | Gc3i-Iic
If I can help any other way just let me know...
Good Luck!
Bill
Dec 01, 2007 | Panasonic PT-50DL54 50" Rear Projection...
Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television Logo
362 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
