Question about KitchenAid Dryers
Kitchen aid dry motor noise
I just fought to get the blower fan off, had to resort to breaking it with a hammer. Once the fan was off I replace it with the new one. Put the machine back together, plugged it in, pushed the on button, now the motor wont spin. Just makes a loud humming noise. Did I damage it trying to get the fan off, or did I over tighten the new fan resulting in unknown problem ? I took everything apart back down to just the motor, tried to run it again with same humming noise. Any thoughts.
  • 1 more comment
  • jgreenacres Jul 24, 2008
    The motor was bad, when I pulled the new motor out the box I notice the shaft didn't move back and forth. On the old motor it would do this with little effort. But ... after installing the new motor and connecting everthing together, pushed the button to test ..ran fine , losts of air movement ...no heat. Yesturday with the old motor it wouldn't turn over but I had heat, lots of it, now none. Any thoughts.
    I came across a web site that suggested to test a number different parts with a volt meter, fuse, thermostat's, and heating element. I came across a thermostat that didn't give me any readings. Hopefully this will be the end of the problem. Does it sound like I'm on track?
  • jgreenacres Jul 25, 2008
    It was the thermostat, after I replaced it put it all back together again, machine was back up and running.
    Scholar:
  • 50 Answers
Try taking it apart again and try to turn the motor by hand. It should spin freely. If it does you've probably got a bad motor. If it is stiff or doesn't turn at all, then you might have missed something putting it back together. I wouldn't think you can overtighten the blower, it is probably something else, and with it apart it should be easy to see.
Posted on Jul 21, 2008
  • Austin DeBock Jul 24, 2008
    When checking fuses and thermostats you need to make sure you disconnect one of the wires to prevent a false reading. Ohm the 2 terminals on each termostat and thermal fuse. You should read 0 ohms. If it meter doesn't change (infinite ohms) than it is open and will not allow current through it. Some thermostats will have 3 or 4 wires. If yours does, make sure you test the 2 largest terminals, they will usually be the 2 farthest apart. It does sound like you are on the right track.
    Also make sure you take the 2 wires off the heater and check each terminal to the case of the heater. If you get anything other than infinite, the heater is shorted to ground and you will need to replace the heater and the thermostat or fuse that opened.
Frig is making loud noise when it turns back on to cool.
proberly ice build up around the fan motor.You may have a defrost problem.
Oct 16, 2014 | KitchenAid Whirlpool Kitchen Aid...
Why is blower motor making whining noise when on?
The bearings are shot. You have to replace it.
Nov 12, 2013 | 2002 Honda Accord
My dyer is makes a loud, rattling sound.
did you find what caused the blower fan to break in the first place?I suspect the casing around the fan may not be clearing and something is in the fan again. or the keepers to keep it on the motor shaft are loose. The rollers for the drum and belt may be faulty. these are all of the parts that move so it has to be one or more of them.
Mar 01, 2012 | Amana NED4500VQ Dryer
Honda pilot 2007 blower fan making noise blower fan was replaced once still making noise
Either its developed the same fault or the fan motor bearing has failed, needs greasing or, if there's a belt, the belt is slipping.
Feb 22, 2012 | 2008 Honda Pilot
KitchenAid KHTU160KSS Kitchen Hood makes noise
Remove the fan and motor assembly from the hood (the fan motor will plug into the hood housing) and using an electrical motor cleaner (such as CRC electrical motor cleaner available from your local auto parts store) wash the motor and fan as completely as possible, lubricate the end bearings (sparingly) with a very light oil such as sewing machine oil, gun oil or as a last resort 3 in 1 oil. Hope this helps.
Dec 14, 2011 | KitchenAid KHTU160KSS Kitchen Hood
2004 4runner Blower doesnt work when its cold out
the problem is eather the blower motor or the switch that controls it the switch somtimes has a set of balast Risters that control the speed of the motor could be that the main balast is bad
Feb 24, 2010 | 2004 Toyota 4Runner
Advice on how to get fan off motor shaft on Kitchen Aid Gas Dryer
no special tool, but it is reverse threaded!i usually place a vice grip over the plastic portion of the fan and with a monkey wrench onthe motor pulley im able to break the connection free, REVERSED THREADS gets me every time!
Mar 02, 2009 | KitchenAid Dryers
Remove blower blade from motor
A guy who has been repairing these for twenty+ years told me sometimes the blower fan is just too tight to remove. If so, you have to use a screwdriver or punch from the motor side and literally break the plastic fan apart. I thought that was going to be my problem, but..... With wrench tightly fastened to the nut at the back of the motor and resting against the post of the rubber wheel, I put a sturdy wrench on the shaft at the front of the motor and whacked it in a clockwise direction with a hammer. It snapped and came loose! Hooray. Try that before you demolish the blower fan.
Jan 15, 2008 | Dryers
Dryers Logo
87 people viewed this question
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Oloyede Monsuru
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
