Question about Behringer (UCA202) Sound Card
How to use
Hello im using serato csratch live, it dont run on soundcards. i woul like to record live mixes from my behringher xenyx1622fx. to my laptop, can you tell me how using uca200
The best way is to connect your master output to the uca200 input and uca out to your amp. u have to use a sound editing software to record.suggestions-audacity.
Yours DjNicq
Posted on Aug 22, 2008
I have the same problem
Posted on Dec 05, 2008
Serato does not recognise my technics turntable. The turntable is on and turning well but no response from serato. the arms in the serato do not move...help?
serato is a software to be used with an external soundcard it doesnt care what turntables you have. u have to a rane mixer or one that is serato capable in order to use it. then you have to go and link and sync your time codes
May 26, 2011 | Technics SL-1200M3D Turntable
Im playing my SL-1200MK2 threw serato and it when i press play to make the record spin serato pick up that the record is slowly spinning backwards? and no noise is coming from the record
do you have your timecodes set properly and configured with serato? that could be the issue try adjusting the timecodes w serato and basically re sync them. if this doesnt help please let me know
May 11, 2011 | Technics SL-1200MK2 Turntable
Ringing sound in background
sounds like there is a input to output loop of some kind. On some of my soundcards I was able to configure a virtual patchbay. Check around in the software for this and macke sure outputs are to outputs and ins to ins. Good luck.
Aug 28, 2009 | Rane Serato Scratch Live Computer DJ...
Why does this not work?
hi i am using a sahara notebook but thair driver are not installed even i dont know the model no how i can solved the problem which driver is the best for my notebook will you plz help me
Jul 13, 2009 | Rane Serato Scratch Live Computer DJ...
My comp cANT SEE serato scratch live
You have to hook up the SL1 Box or the 57SL mixer and then install the drivers. If you are not hooked up to either of these it will say 'Interface Disconnected' or 'Soundcard Not Found'.
Mar 24, 2009 | Rane Serato Scratch Live Computer DJ...
Recording Mixes from IDJ2 to my MAC
I don't know about MACs but I assume most computers are the same in their general anatomy when it comes to the sound system.
ie. Windows has a digital recording system built into the OS that allows you to plug an 1/8" patch cable into the "input" of the soundcard of the computer. Years ago I recorded several things from karaoke songs I sang to pre-recorded song I mixed from my DJ console. The volumes needed to tweeked to avoid sound distortion but it sounded so good I've used my recordings at gigs.
Feb 01, 2009 | Numark iDJ2 - DJ iPOD Mixer Docking...
Distorted sound, Low signal, unable to use deck with serato.
I just want to clarify the way you have your gear set up.,
Normally this is enough to annoy anyone.
Having set all the equipment up,this is what I would do.....
Try without Serato
Firstly I would set the records & platters and then the counterweights,
Then I would do an audible check.Headphones,Monitors and then front of house system
If this passes I will then set the room levels for comfort and then the eq band gets a tune up for the room,
If this set up procedure works then connect Serato,
If problems persists then Uninstall Serato and Reinstall.
Try Again if all else fails ......
www.serato.com they have a contact us,report the problem.
Hope this helps ,If you need more help please let me know,Misterdj
Jan 18, 2009 | Technics SL-1210 Turntable
Song playing backward but table going foward with serato.
hi... swap the left and right rca cable.the one who said it works good on the deck but on the screen goes back ward....see what hapen..u
Dec 09, 2008 | Panasonic Technics SL-1200MK2 Turntable
Using other sound cards with serato scratch live
Using pc onboard sound cards with serato scratch live
Jun 08, 2008 | Rane Serato Scratch Live Computer DJ...
Behringer (UCA202) Sound Card Logo
615 people viewed this question
Top Behringer Computers & Internet Experts
Seanzilla
Brett Duxbury
Brett Duxbury
Steve
Steve
Are you a Behringer Computer and Internet Expert? Answer questions, earn points and help others
