Question about Hotpoint NVL333EY Electric Dryer
Burns my dryer seems to pinch the clothes and burn them, what can i do to fix this?
    Problem Solver:
  • 16 Answers
You need to check the drum where it fits into the front door/front housing. If the housing is worn close will get caught and tear.
Posted on Jan 06, 2009
Kenmore dryer model 110 leaves burn marks
They aren't burn marks, it is the clothing getting pinched between the drum and the bulkhead due to a worn felt seal. Help Me Find My Model Number RepairClinic com
Oct 17, 2016 | Kenmore Dryers
REPLACED SoLeNOID COILS AND IT BURNS BUT SEEMS TO BE A LOW FLAME
How to fix a none heating Whirlpool or Kenmore gas dryer ...
www.askgene.com/...dryer/...dryer/how-to-fix-a-none-heating-whirlpool...
Dec 27, 2006 - How to find, test and/or replace the igniter, the radiant flame sensor ...The part number for the Whirlpool gas valve coils is 279834. ... The main coil seems to be energized all the time and the auxiliary coil is ..... I have a whirlpool gas dryer model WDG5600SQ0 ,the gas will ignite into a flame but burns out ...
Clothes Dryer Troubleshooting ' Dryer Repair Manual
Jan 01, 2016 | Dryers
Making thumping noise and burning clothes
You list no brand or model so an answer must be somewhat vague. A loose drum causes the noise described while it also allows air to leak from outside the normal air flow path causing erratic high/low temperatures contributing to burning. Sometimes clothes can also get caught in the gaps caused by the tub moving excessively which causes tears, pinches and rips in clothing. Most dryers will have rollers and/or glides to carry the weight at the front of the drum. Check to determine if these are worn, loose or broken. A few models carry all the weight at the rear of the drum (Frigidaire and some GE) so check the rear bearing for excess wear and replace as needed. It's always a good idea to also clean debris and lint from inside the cabinet while the dryer is disassembled for repairs.
Aug 25, 2014 | Dryers
MY FRIGIDAIRE ELECTRIC DRYER IS LEAVING BURN MARKS ON CLOTHES,WHAT IS CAUSING PROBLEM
Assuming that you have the correct temperature selected for your clothes, there are two likely causes:
If the clothes are showing randomly shaped burn marks, the dryer is overheating. This would be accompanied by a burnt smell on the clothes. The high limit thermostat is the culprit.
If the burn marks are dark streaks, the clothes are getting pinched between the drum and the inside of the dryer that does not move. This is caused by worn bearings, slides or rollers. Should you choose to repair this yourself, there is a great deal on a kit with all of the parts you need plus a new belt for only $32 here:
http://www.repairclinic.com/PartDetail/Drum-Bearing-Felt-Seals-Pulley-Belt/5304461262/1261075
Good luck from Detroit, Mi.
Jul 20, 2011 | Frigidaire GLER341A Electric Dryer
Clothes, fabrics are coming out of dryer with burn marks
If those marks are little brown marks/they do look like burn marks but your cloths are being pinched by the front and rear felts on the drum//to test that take a white rag reach in to dryer at the edge of the drum front and rear rub the rag// you may have to push it between the drum and the dryer housing you will get brown marks that is rust///If you replace front and rear drum glides (seals) that will cure the problem I would price parts first as sometimes replacement is a lot cheaper.......Hope this helped....If I did please vote If you need more help please ask...Good luck
Feb 05, 2011 | Kenmore Dryers
My dryer leaves burn marks on the clothes. What
Hi. Thanks for using fixya. I can help you. When clothes get marked or torn in your dryer, check these: Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it. small_8_13.jpg
Nov 09, 2009 | GE DBL333EA Electric Dryer
I'm getting burn marks on clothes. Think it's the seal on the back of dryer? Must hang to dry all white clothes, so what's the point o fhaving a dryer?
The gasket between the drum and the back panel may be worn or missing.  I had a similar problem with a 34 year old dryer when the felt gasket wore out and allowed metal-to-metal contact between the drum and the back panel.  The clothes would get pinched between them and make a black "kiss" mark.
May 18, 2009 | Dryers
Dryer pinching clothes.
The front glides are bad. Easy fix.
Feb 13, 2009 | Dryers
Clothes burnt?
Try turning down the heat setting on your dryer. This should help immensely. Dry these types of clothing on say "medium" setting and the heavier things on normal heat.
Jan 14, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Burning smell
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
Nov 16, 2008 | Kenmore Elite HE4 Electric Dryer
Hotpoint NVL333EY Electric Dryer Logo
70 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
