Question about Sony Cyber-Shot DSC-P200 Digital Camera
Water damage my camera dropped in some water. i took the battery and memory card out to dry. then i tried charging it and the light is coming on to say its charging but the camera wont turn on. help please!
  • 1 more comment
  • xoxiwubbyoux Aug 13, 2008
    i left my camera out in the rain and i took the battery and memory card out to dry, i put the battery in the charger and the light goes on but when i put the battery back in it turns on but nothing shows on the screen,what should i do?
  • chris932 Aug 19, 2008
    The bag it was in got water spilled on it and the camera was protected inside but still saw a little moisture.
    I opened it up and let it dry out.
    It does not turn on with the battery. It does turn on and take pictures if plugged into the charger. But not on battery alone?
    Battery show 3.1V on the meter but says it should be 3.6V.
    Any suggestions?
  • Anonymous Apr 06, 2009
    we went to a water fall and the bag in whic we had our camera got a little wet..may be moisture got in...we dried the battery for while then tried we were able to turn it off an on....and disply came up,...now its not working at all...help us
There are micro fuse on main PCB of camera first check it. If problem is still not solve than do let me know regards
Posted on Jul 21, 2008
Water Damage Lens Error
Most cameras with retractable lenses are very sensitive to grit (sand, dirt, salt etc.) in the lens mechanics and will shut themselves off if everything is not perfect. It's possible some salty water remained in the works and left a salty residue when it dried out.
Unfortunately, most repair shops will charge you almost what the camera is worth to properly clean it and it is not a job for the do-it-yourselfer.
Apr 27, 2017 | Canon SD4000 IS IXUS 300 HS Digital Camera
Dropped nikon coolpix s220 in water took out battery and memory card immediatly is there anything i can do or is it broke
Don't try to turn it on. After drying out the card and battery compartment as best you can, bury the camera in a bowl of dry rice for one week. Then, try to turn it on with your fingers crossed. I'm assuming the water was clear and not saltwater. You still may have a problem with water spots on the inside lens elements if any water got inside them.
Jun 29, 2011 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Water damage
Glad to see I'm not the only person to drop a digital camera in the water. LOL. Here is what I did to save my camera.
First remove it from the water. Take the batteries and SD Memory card out. Toss the batteries out. Dry the memory card with a soft terry cloth hand towel and set aside. Do your best to drain the water from the camera. There is still water in the camera. Give it about 3 or 4 days to let it dry out. Leave the battery lids off and prop the camera up onto it's side so any excess water can drain or evaporate freely.
Once the camera is dry, put a set of fresh batteries in (not rechargeables) but not the memory card. Power the camera on and see if LCD comes to life.
Feb 08, 2010 | Vtech Kidizoom Digital Camera
Hi! I got a Canon rebel XT. problem... the camera is dead
Like all electronics, water is it's worst enemy so even by drying it (which is commendable) you still may have traces of water somewhere on the circuit board. We all know water is conductive, so if some solder tracks were shorted there can be a problem there or if the water has corroded through a solder track the circuit fails. There are numerous chips in the camera that are super tiny so even the slightest water can damage them.
In my experience when something is water damaged (and seriously water damaged) it is beyond repair.
Nov 01, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Dropped in water, won't turn on
Was the camera on at the time it fell in the water?
Apr 24, 2009 | Olympus FE-280 Digital Camera
Repairing Sony H7
I HATE TO SAY THIS, BUT DROPPING IT IN SALT WATER IS ABOUT LIKE THE BLUE SCREEN OF DEATH ON YOUR COMPUTER. SALT WATER BEING VERY CORROSIVE WILL, IF NOT HAS RUINED ANY WORKING PARTS AND CIRCUITS IN THE CAMERA. DRYING IT DOES NOT REMOVE THE SALT AND THE DAMAGE WILL BE TO SUCH AN EXTENT THAT REPAIR WILL BE ALL BUT IMPOSSIBLE. THERE JUST ISN'T ANY FIX FOR SOMETHING LIKE SALT WATER. I'M SURE THAT INSERTING THE BATTERY MOST LIKELY SHORTED OUT CIRTCUITS INSIDE THE CAMERA. THERE JUST ISN'T MUCH HELP HERE EXCEPT A VERY EXPENSIVE REPAIR IF YOU COULD FIND ANYONE WHO WOULD EVEN WORK ON A SALT WATER DAMAGE. WATER AND CAMERAS JUST DON'T MIX.
Aug 24, 2008 | Sony Cyber-shot DSC-H7 Digital Camera
Nothing transfered from the lens (ccd) to the screen/memory card
Greetings Maltheskalle,
Units that experience water damage are normally irrepairable even after drying out. I would take it to a qualified repair center and have them give you an estimate on repairing the unit. You may find that replacing the camera is more economical than repairing it.
Sincerely,
Dorothy
Go Ahead. Use Us.
Jun 10, 2008 | Kodak EasyShare CX7525 Digital Camera
Water Damaged
ok there is one fix that i used with my canon sd700
again, it dropped it in the water and it stopped working
i took of the screen and changed the batterey wattage to 65w instead of 45w using a zxd breaker
then the "hotfix"
i pit it into a oven for 30 sec to get all compo. hot and then let it cool
i pressed the power button, and it worked!!
bad thing is the battery lasts about 5 or 6 hours only because of wattage change!
May 23, 2008 | Pentax Optio S50 Digital Camera
Sony Cybershot
Turning on may have killed it. however try this. Take the batteries and card out and leave the doors open Take a polythene bag and place in it a quantity of uncooked rice or salt tied into a suitable cloth. put the camera in and seal the bag. leave in a warm dry place for several days This may save it -or it may not.
Aug 02, 2007 | Sony Cybershot S650 Digital Camera
Camera dropped in a bucket of water
I very much doubt it. If you had removed the batteries straight away, stripped the complete camera and let warm air waft over it for a day and then put it all back together and tried it, you may have been lucky. But wet circuit boards and electricity is asking for major problems. Even leaving a closed camera for 2 days wouldn't have given it a good drying out.
Jun 13, 2006 | Panasonic Lumix DMC-FZ5 Digital Camera
Sony Cyber-Shot DSC-P200 Digital Camera Logo
440 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
