Question about Refrigerators
My GE 21.7 cf no-ffrost side by side keeps running, leaks water to the floor and warms up. Age unknown. What might be wrong?
  • valta Jul 22, 2008
    Thanks Krazytech,
    I managed to feed a small plastic hose all through the
    drainline and will wait another day. Will report outcome.
    valta
  • valta Jul 24, 2008
    A day later the fridge is running fine--just like you said.
    Thanks Krazytech.
    valta
  • 725 Answers
The drain must be plugged . defrost the freezer (leave unpluged with door open for 24 to 48 hrs or untill it stops leaking water...
clean and clear drain plug back in and it will work like a charm...
please let me know
Posted on Jul 21, 2008
I have a GE refrigerator which leaks water. Point of origin of the leak is unknown but the water drips down the interior and pools at the bottem until it overflows and drips on the floor from the fro
You have a frozen drain in the freezer side of frig....take back panel off in freezer and you'll see your build up of ice take out ice and pour hot hot water down drain....make sure clear and clean then you're done....easy peasy....
Oct 02, 2012 | GE Refrigerators
Sidex side 26 cf... 5 yrs old... frequent water on floor under freezer... freezer temp is erratic and will seldom be below 6, but infrequently will go below 0 setting ..can not keep ice cream
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 28, 2010 | GE Refrigerators
Feezer seems to be stuck in defrost mode. Everything will defrost and and water leaks out on the floor. Refrigerator becomes too warm. If the unit is unplugged for a time, and then restarted, it works...
The defrost timer probably is not working at all...
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
Water Running in efrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 16, 2010 | GE GSS25JEMWW Side by Side
Water leaking from overflow tube
pour warm water and baking soda down drain and look for cracks in tube.
May 12, 2009 | GE Refrigerators
GE Freezer Leaking
Open the freezer door, remove the bottom tray, smash the ice on the floor with your fist to remove it. Now get a glass of hot water and pour it into the trough which is at the bottom of the back wall of the freezer. Allow a few minutes for the ice to melt then remove it with an ice pick or scrrewdriver. Once the ice is out, pour more hot water into the trough. Now take a long tube ( an old washer fill hose works perfectly) and stick one end in the hole in the trough. Now fill your mouth with warm water and blow it very hard through the tube. Once the drain is clear, pour some hot water and a very little amount of bleach through the hole.
Apr 06, 2009 | GE Refrigerators
Water accumulating in bottom of freezer and leaking onto floor
Yes the drain is clogged and the water that supouse to go through became ice so it make it worse.Put hot water in the drain hole until it runs through,it'll go to an evaporative pan on top of the compresor to keep it warm and vaporize the water.
Apr 04, 2009 | GE GSL25JFPBS Side by Side Refrigerator
GE side by side leaks water onto floor, no ice
There is a pipe that runs up the back of the appliance and feeds the ice maker , if this freezes inside then it canpush the fitting off the back of the appliance and cause water to go everywhere. Usual problem is a leaky watervalve causeing water to drip into the pipe which freezes and builds up until it is totally blocked.
Aug 16, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
44 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
