Question about Canon imageRUNNER C3200 Copier
For Canon IRC3200N
How to scan (not photocopy) using the photocopier on a 2-sided original so that I can send it via network ? Thks!
  • 38 Answers
1st off, you don't mention if your network sending has been set up, so I'm going to assume that it is. To scan both sides of the page is relatively easy. after you've selected the destination where it should be sent to, on the display there should be a button marked "Two-sided original". simply press this button and choose "book type" and press OK and the green start button.
I'm using a later version of that model, so the button may not be on your display. if it isn't try looking inside scan settings or send settings. Don't be affraid to play with the options available on the screen, they're not permanent, so if you activate a setting that you don't want, you can clear it by pressing the yellow button with the two lines on it.
Also, you need to keep in mind that if you do manage to send double-sided, the image at the computer will appear as two single-sided sheets. to print them double sided you will have to select that option during printing.
If your network send feature has not been set up, I would suggest that you either get somebody familiar with the product, like a canon tachnician, or even clued up I.T. technician to set it up for you.
Posted on Jul 24, 2008
How to connect a 3 computers to one photocopier machine using an IP address.
As all your PCs have Internet connection, I'm assuming that you have some kind of "network" already installed.
On each PC connected to LAN (Local Area Network) use "add printer wizard" and choose "add network printer" option. The wizard should be able to find your Canon device.
Oct 16, 2014 | Computers & Internet
How to make darker copies
if your referring to photocopying but printout is darker, it doesnt work. canon copiers produce copies like the original or better than the original sometimes. try to scan the file in custom mode and adjust the brightness and contrast and click preview to view the outcome before scanning it then print it later
Sep 30, 2013 | Canon PIXMA MP210 Photo All-In-One Printer
When I am photocopying and scanning documents I am noticing vertical lines on the print in the middle of the page which is ruining the copy, any ideas? Alos message intermittently coming up waste toner...
Most probably you are using the automating document feeder for the photocopy or scanning. If you can lift up the document feeder , there should be the mirror where you can put the original document for manual photocopy or scan. Clean the edges of the mirror with a printer cleaning liquid. There may be some foreign particle stuck there or it is just dirty from long use. Hope this helps.
Sep 02, 2011 | Office Equipment & Supplies
How to scan in two faces in one side for exmaple ID in photocopy scan and printer " canon IR3045N"
select special function on screen>image combination>2 on 1>original size a5R(if u r copying on a4R paper then original size a5) then scan both faces to be printed and >done
Feb 03, 2011 | Canon Office Equipment & Supplies
Is it possible to scan using 210 model scanner by network?
Yes, it is possible ti use Konica Minolta bizhub 210 photocopier as a network printer.For this simply purchase network card Model NC-502 for bizhub 210.
Dec 17, 2010 | Konica Minolta bizhub 180 All-In-One...
Can not photocopy
once scanned a document needs to be save din a file format that the PC can read..doc docx..pdf..txt..go into Word or whichever word processing app you use and click import, from TWAIN device
Jul 23, 2009 | Canon PIXMA MP760 All-In-One InkJet...
Photocopies - Canon Imageclass MF3110
replace the cartridge, the drum cleaning blade is failing
Dec 20, 2007 | Office Equipment & Supplies
My Canon Imagerunner 2200 won't scan.
Sorry that was actually me...after i posted...it asked me to register...so i did.
Okay, you need to download Canon Network scangear from the Canon website. then take your document...put it on the top feeder...turn you scanner online...open up microsoft word 2003..insert, picture....from scanner or camera select network scangear....custom insert....then scan. The machine needs to be hooked up to a network...but note...a simple cross over cable or usb between pc and the photocopier will not work.
Oct 22, 2007 | Canon (6981A002AA) for imagerunner 2200,...
CANON IR 2000
Canon iR1600/2000 not a double-sided copying machine. Can print one side then reverse copies in paper cassette and copy side 2 onto it.
Jan 31, 2007 | Canon imageRUNNER 2000 Copier
Canon imageRUNNER C3200 Copier Logo
185 people viewed this question
old marine
old marine
