Konica Minolta bizhub C250 All-In-One Laser Printer Logo
Posted on Feb 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error 5102 - Konica Minolta bizhub C250 All-In-One Laser Printer
Anonymous
Level 2:
New Friend:
  • Expert 60 Answers
  • Posted on Feb 14, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
60
Questions
0
Helped
34822
Points
107
If this error code show at power up, this mean the main motor has failed and need to be replaced, but if you already did that this mean you may need and the board PWB-M.
Error 5102 installing panda endpoint agent
use MS ESSENTIALS or clamwin av it is free antivirus software
Oce plotwave 300 error 5102
Severe developer pollution. The error actually means there is far less toner in the developer mix than the system will allow. Look inside the toner hopper. If it is full of toner, it may be the toner hopper motor or auger has failed. Unfortunately once it gets to this level of error, an authorized Oce service technician has to be called to either reset the error and to run tests to bring the toner/developer level back to normal.
C-5102 error in C353
Transport motor dealing with the duplexer which helps with making double side copies, your right side of the machine the cover has to opening outer open section is causing the problem check it and have a tech come out and check it.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1helpful
KONICA MINOLTA C353 ERROR CODE C-5102
hi tracey, 5102 is a main motor failure, it is possible for there to be paper jammed tight in the fuser unit, if not this will pretty much be guaranteed to be the main motor
Bizhub 164 error code c-5102
Code
C5102
Description
Main motor malfunction
- The main motor (M1) lock signal remains HIGH for a continuous 1-sec. a period at any time 1 sec. after the main motor has started turning.
Remedy
1 Check the connector between M1-PRCB CN6 for proper connection and correct as necessary.
2 Check M1 for correct drive coupling and correct as necessary.
3 M1 operation check.
4 Change PRCB.
5 Change DCPU.
I’m happy to assist further over the phone at https://www.6ya.com/expert/latoya_8ed1bf3dc615c15d
I have a Konica Minolta Bizhub c252 what is code c-5102
C-5102/5103 - Main motor failure.
Check the motor connector,the drive coupling or the mechanical control board and DC power supply unit.90% mechanical rpoblem.
Error code c5102 on bizhub c353
I tried all the above but still it shows code C-5102.
Please advise.
Acer amd turion 5102
reinstall the driver and try again.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
