I have an LG laptop connected to an external monitor. It has worked in the past. In the last week when i turned on my laptop the external motitor showed the boot up process right up until the final desktop screen appears when it says 'no signal'. I have managed to get the external motitor to display my background pic but nothing else. Help please.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 106 Answers
There should be a button on the keyboard that controls the output...it is done by pressing the Fn key (function) in combination with the Fkey (all those F1..F2..and so on next to the Escape key) Also, you can Right click anywhere on the desktop (the first screen you get when the computer boots to Vista) and when you get the set of menus, choose the bottom one calle "Personalize" This will bring up the "Personalization" screen. Here you can choose the bottom "Display Settings" to make sure you have your second monitor (external) ready under the "extend my desktop onto this monitor" check. Go on and click on the #1 screen and the #2 screen and play with the options so you get a good feel for them and to see wich one works best for you.. Hope this helps.
Posted on Jul 21, 2008
Lenovo g550 laptop with an external monitor would only display of broken original screen after crash dump
Firstly you need to get your external monitor working. Have you tried pressing FN+F3 while turned on, (may take several presses).
If you can get the external monitor working then you'll need to run windows in safe mode and try removing any new drivers you installed. or try a 'Last Known good' on start up this depends on the OS version.
Nov 19, 2014 | Acer Computers & Internet
Monitor automatically clicks into power saving mode
Laptops often have a function key which switches from laptop only, external monitor only, laptop & external. One of the top number keys, along with the function (fn for short) must be pressed simultaneously to step through these.
Where these keys are at, may differ from laptop to laptop.
Nov 28, 2007 | LG L1915S 19" LCD Monitor
My screen on my laptop is broke so I'm using a monitor with vga now for some reason the monitor is going into power saving mode on start up how to I get it off power saving I really need my laptop have so...
The laptop may no longer be set for external monitor mode. Try boting it up and then holding the FN key down while pressing the F5 key at about 2 second intervals. This is the most common key combination to switch display modes on most laptops. If everything is working you might find the external monitor setting after a few tries.
Nov 02, 2014 | Computers & Internet
Cant connect my laptop to my LG32LC45 tv
Hi there
Below is a link which takes you to a page that shows how to cable the PC (laptop) and the TV together, with a brief explanation of resolutions etc.
http://www.lg.com/uk/support/product-help/CT00008333-CT00008334-2132861
If the above doesn't get you any further then the link below takes you to an LG support page from which you can download the full manual for your TV, which gives the supported connection methods and the supported resolutions.
http://www.lg.com/uk/support-product/lg-32LC45#
I would strongly suspect that if correctly cabled then either the laptop external resolution is set to a level that the TV can't cope with, or the external monitor function is turned off. If the external monitor function is turned off then pressing and holding the Fn button whilst pressing a function button once and releasing both should turn the external monitor on. On a Toshiba Tecra the top line functon button you need is F5, on an MSI U130 its F3, on a Dell Inspiron 1525 its F8, on a different Dell model its F1, so you need to check your laptop and its manual to find out which button is relevant to your machine.
Sorry to have been longwinded - Good luck
Aug 25, 2014 | Computers & Internet
My hp dv5215us laptop monitor broke several months ago. I've been using the computer with an external monitor plugged in to the vga port, but I turned it on today and the external monitor isn't...
Hardware failure of the motherboard - most likely something went wrong with the northbridge.
The repair will cost way more than it's worth, this laptop is effectively dead, time for a new one
Jul 20, 2011 | HP Pavilion dv5215us Notebook
The display on the Dell SE198 dispays while it is searching for the input mode. It displays for aproximatelly 2-3 seconds while it confirms that it is recieving analog input. Afterwards the motitor "seems"...
Turn your computer off.
Turn your computer on, and immediately keep tapping the 'F8' key,
until you see a "boot-menu".
If you never see that menu, connect the monitor to a different computer, e.g., a laptop, and see if the monitor works at all.
When you see the boot-menu, select "Safe Mode".
Reset the video-resolution to 800-by-600, and restart.
Nov 14, 2009 | Dell SE198WFP LCD Monitor
Last week I ended up restarting my computer and for some reason the monitors starting to go black. It's an alienware and it pretty much these are the symptoms. Keep in mind that my laptop is always plugged...
try to connect laptop to an ext monitor if you will still be getting this problem. if yes uninstall and resintall the video driver. if not then LCD might causes the problem. try reseating the LCD cable if possible.
Oct 14, 2009 | Computers & Internet
Today I noticed that when turning on computer, after 1-2 mins the screen goe black and I cant see anything. I noticed in the past month that occasionaly I get lightening flashes in the background. this...
To determine if the LCD screen is faulty ot the video card, connect an external monitor to the laptop's video port. Power up the external monitor first and the boot up the laptop. The video image should automatically switch to the external monitor. If you don't get flashes on the monitor then the video card is OK and the fault lies with the LCD screen. Flashes coud be caused by a faulty inverter or a faulty CCFL lamp. A fault is usually easier to diagnose when it is not intermitten.
Jun 08, 2009 | Dell Inspiron 6000 Notebook
HP Pavilian external monitor color problem.
The easiest thing would be to check your cable for a bent or loose pin. Next put another external monitor on the laptop. The circuitry to provide video to the laptop screen and the external monitor are separate except that they share a video processor and video memory. There can be bad electronics involved.
Apr 08, 2009 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
David Payne
David Payne
