Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA D52W20 52in Rear Projection TV/ Picture
The TV has developed a greenish tint like it's lost its red color. I thought it might be the bulb but I am not sure.
  • 1 more comment
  • webutler Aug 19, 2008
    Same type problem. Lost Red, I can run the tint scale all the way to the right but no help.
  • gbcichlids Sep 21, 2008
    Same problem here. Just moved tv to other side of room and now the red tint has vanished.
  • razoosa Dec 27, 2008
    I unplugged the Xbox360 unit to move to another tv, but when I brought it back the greenish tint appeared. I tried resetting unplugged overnight, but nothing. The unit is holding this greenish tint and missing reds and browns. Any suggestions on a fix?
I'm encountering the same problem - missing reds and browns. Could someone please let me know how to fix this problem. Thanks.
Posted on Jan 25, 2010
    Scholar:
  • 154 Answers
Sounds like someone has put a magnet near it or picture projection from rear may have moved is the picture fine other than tinting?
Posted on Jul 23, 2008
Green Color Tint
I had a similar problem with my tv. Sometimes it depends where the tv is located, have you moved it? Magnesium in the earth caused my tv to have greanish tints in all four corners of my tv. Try moving your tv forward, backwards, or side to side. Let me know if this works.
Cynthia
Feb 01, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Picture is starting to get greenish, yellowish colored
hitachi model 51f510 projection tv has horizontal lines & has greenish tint,do i need to chang the bulbs??i alredy tryd the magic focus button & manual focus,but unsuccesfl,any ideas????
Nov 27, 2009 | Hitachi 51F510 51" Rear Projection...
I have a Sony KDS 55A TV.
Please check color temperature adjustment in menu and also check white balance adjustment.
Jul 23, 2009 | Sony KDS-55A2020 55" Television
Greenish tint to picture
there may be a green tube issue or there could be a screen voltage or screen control adjustment issue. There is a control block with six adjustment screw inside the front panel in front of tv. WARNING high voltage exsit in this set and adjusting these controls really should only be done by a tech,....So be careful
Nov 20, 2008 | RCA D52W19 52" Rear Projection Television
RCA R2WH74YX58 tint problem
MAYBE LOOSE CONNECTION--CAN'T PICTURE YOU PROBLEM--WHAT'S THE CHASSIS #?? TUNICA
Sep 17, 2008 | RCA P52926 52" Rear Projection Television
RCA Model D61130 Picture is now Green and Dark
yeah mine to,, ive found out which ever direction the color is goin out of line,, when u get 2 the convergence screen,, dont push ok,,push the direction the colors r messed up,, should help u,,good luck
Aug 16, 2008 | RCA P61940 61" Rear Projection Television
Picture with red 3-D effect
IC8001, STK392-560 seems defective, its convergence output IC.
Aug 06, 2008 | Sony KP-51HW40 51" Rear Projection...
TOSHIBA 52 INCH PROJECTION TV - 2003 MODEL
Hi olchap
your tv is projection, maby the heat is causing the bulbs to brighten and dim, you should try to keep the room its in fairly cold or try and have the bulbs replaced to ones that are not as strong,
hope that helps a little ^-^
Jul 29, 2008 | RCA HD61LPW175 61" Rear Projection HDTV
Phillis 55pw9363 yellowish - greenish picture
cleaning the CRT lenses and mirror will help, however with that model I would suspect that the gree and blue CRT needs the coolanr changed to get a your color and clarity back. thats a common problem with all phillips rear projection TVs
Jun 13, 2008 | Philips 55PW9363 55" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
296 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
