Question about Bose Wave Radio
AWR1-1W Just died. No lights on display. Power out of transformer yet I do not know what the voltages should be. Is a transformer available. Capacitors OK. Static heard when pulling cord from outlet. Output power transistor OK. This seems to be a common problem with this unit. Is there a common component and an easy way to test for this issue. Thanks in advance for any advice.
  • 6 more comments
  • kenkress Feb 03, 2009
    Thanks for the suggestion. The rectifier and the cap both had 15v out. Still no fix.
    Thanks again,
    I tossed the unit. Got to be too much time invested.
    Ken
  • Anonymous Feb 05, 2009
    Time light does not stay bright.
  • pieterbull Feb 08, 2009
    I have the same model and problem: no power, no display, with or without the 3 AA batteries. No sound or pop at all.
    Any help appreciated!
  • okheffta Feb 08, 2009
    Radio died--no clock
  • Jon Watt Feb 10, 2009
    Today, noticed all possible lights were light up on the display, tried to turn radio on but it would not turn on, then unplugged the power and replugged now nothing, no lights or sound, but when I unplug it again I hear a pop in the speakers.
  • JimB22 Feb 12, 2009
    Same problems as previously reported by others, noticed all possible lights were light up on the display, tried to turn radio on but it would not turn on, then unplugged the power and replugged now nothing, no lights or sound, but when I unplug it again I hear a pop in the speakers.
  • pieterbull May 11, 2010
    mosfet guy,
    I'm not sure if you're comment was for the earlier folks or me...I just posted a few days ago...but I can certainly use the info/help!
    Much Appreciated either way!!
    Pieter
Display lit with a bunch of information which seems to be frozen. radio does not play
Posted on Jun 14, 2011
    Problem Solver:
  • 16 Answers
Check the rectifier next to the transformer, the dc out should be around 15 volts and the big main cap as well.
mosfet guy
Posted on Feb 02, 2009
  • tim Feb 03, 2009
    well im waiting for the bridge amp and a to92 mosfet for mine i believe this is the problem. if you know where the regulator is there should be around 18 volts in and about 12 out.
  • tim Feb 11, 2009
    well if you are still looking to fix the radio i have some info for you. email me if you would like the info as i cant type to fast and it will take me alittle while to explain. my radio is fixed now and its great.
    mosfet guy
Samsung tv un60j6200afxza version ns02. No standby light and will not power on. Power board tested ok by tv tech. Replaced main board and still not working. Yes board tested ok. Tried multiple outlets to...
Power board is where 120 volts AC enters the TV. From the rear, the power board is on your right hand side (not bottom). After 120 volts, there is a fuse on the power line. Then the 120 volts go to a high voltage transformer and then there is a capacitor - 100 uf at 450 volts DC. Check the voltage here -- should be at least 390 volts or higher. If not, replace this capacitor with a higher capacity, ie, 350 uf with a rating of at least 400 volts (or any combination of capacitors totaling 350 uf.)
Dec 29, 2017 | Samsung Televison & Video
Onkyo AV Receiver HT-R500 No power whatsoever, no illumination of any display options and no activation clicks upon pressing the power button! We inspected the receiver via dust cover removal and found no...
If that is true the power transformer is probably open at the primary, the secondary voltages feed the receiver and power various parts. I suggest getting it checked, my worry is the power transformer may not be available from the parts manufacture.
Mar 28, 2012 | Onkyo Audio Players & Recorders
After off for a while, blue on indicator flashes for 12 times stops then flashes again. TV is Pioneer PDP-5070 Plasma TV.
Ur tv have a dying power supply board,that the board where the power a/c cord plug into.U have all the tools and know basic electronic also can do basic soldering work?Yes,take the tv aparts and check the tv power supply board carefully looking for dying capacitors components parts.These dying many capacitors components parts are alway bulges up or puffing up onto it tops.These capacitors parts are slowing leaking and dying to causes the tv to have a unstable managements of power voltages to tv to powering up the tv,unstable power supply board source that why the tv LED power light indicator are flashing.Replaced all these dying and leakages capacitors components parts are bulging ups or puffing ups onto it tops.Replaced all these dying capacitors parts with the same Micro Fared and but it voltages higer like 5 or 10 voltages higher than the old capacitors parts u are replacing.These higher 5 or 10 voltages on the new capacitors parts will help it to with stand heat better than those old capacitors parts u are replacing.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv power supply board for the replacement.
Aug 15, 2011 | Pioneer PDP-5070HD 50 in. Plasma...
The lcd when swicthed on it display for a second and went blank again, but the audion is good
hi,
You have to check the backlight inverter board of your TV. If any one of the chopper transformer ( high voltage transformer) is faulty then the inverter board will consume more current from the power supply. This will sense by the protection circuit and will deactivate the voltage to the inverter board. Some times faulty electrolitic capacitors in the power supply or in the invereter board can can lead to this type of problem. First of all check the electrolityic capacitors. If any one of the capacitors in the power supply or in the inverter board seen budging on the top repace the same. If the problem remains then you have to replace the backlight inverter board.
ok
Jul 04, 2011 | LG 32LG30 32 in. LCD HDTV
My LG takes a longtime to turn on, why?
hi,
You have to check the back light of your lcd TV. All lcd screen have a back light to illuminate the pixels. you can conform is the back light is faulty or not by watching the lcd screen nearby. Watch can you see any image (negative image) on the screen. you have to look very closely. if you see any image on the screen then the back light or the back light inverter is faulty.
first of all check all the electrolytic capacitors in the power supply and back light inverter board.If available then replace these capacitors first.
You have to check the back light inverter board. Normally in lcd monitors you can see three circuit boards. power supply, mother board, and the inverter board. If available then try to replace the inverter board. There are high voltage transformers in this board. There is a chance for its winding get short. You will not get the transformer in open market. Try for the inverter board .
ok
Jun 09, 2011 | LG 47 in. Flat-Panel LCD HDTV
My LG 21 int ch flat screen takes time to show pictures,the red button appears on and sound will be heard but their will be no pictures,they appear after some time please help me.
hi,
ok
Jun 09, 2011 | LG 37LD450 37 in. TV
Tv flickers off and on
You have to check the back light inverter of your lcd tv. In all lcd tvs there are back lights to illuminate the pixels. There are two types of back lighting in use . CCFL ( cold cathode fluorescent lamp) and LED (light emitting diode). In you your tv it will be CCFL. If it is CCFL then it need an inverter (voltage step up circuit) for getting its working voltages. Normally it will produce above 1000V in low current. In the inverter circuit there will be inverter transformers. If the winding of the transformer get shorted then the inverter will drain a high current from the power supply. If so then the current sensing circuit senses the same and it will shut down the power supply. That's why it do the cycle ON an OFF repeatedly.
Just check the inverter board. Normally there will be three circuit boards in LCD TV. Mother board, SMPS (switch mode power supply) and inverter board. In some tvs the SMPS and inverter bord will com-pained as one board. you have to check the inverter transformers. there will be 4 or 6 inverter transformers. if available replace the inverter board as a whole.
Also check the electrolytic capacitors in the power supply. if any of the capacitor seems like one that in the picture, then replace the same and then only go for the inverter board
ajin_g_8.jpg ok
May 29, 2011 | LG 42LC2D 42 in. LCD HDTV
My Dell 1905fp Ultrasharp was coming on intermittently for a little bit and then it would not power up at all.
You said your monitor will be on for little bit and then would not power up anymore... there are two possible reasons why this problem occur..
1. You need to check if the high voltage ballast transformer of your backlight inverter is about to be burned... the transformer is overheating..that's why you experience the monitor working for a couple of minutes and then it will shut off until the transformer cool down again and then it will be ready to work again...
2. You need to check the power supply section for possible loose connections and blown capacitors.. the ballast transformer has direct effect on power supply section.. when there is overheating transformer,,, the supply current from the power supply section becomes unstable.. and will not be able to supply the remaining good working ballast transformer.
In case you do not know, the ballast transformer generates high voltage for the backlight inverter to work..The backlight inverter is the light source that is responsible for the image display of your screen...If the ballast transformer is not working or if the backlight is busted then the only thing that you will see in your screen is black....
Please be advise that if you don't have the knowledge, the proper skills and the right tools to open the back cover of your monitor and replace its part...don't risk it...
Otherwise, bring your unit to a credible technician and avail of warranty if there is any.....
Much appreciated if you rate this help...thanks...
May 24, 2010 | Dell UltraSharp 1905FP LCD Monitor
No display after 3 secs.
try looking for bloated caps, check all diodes... see if its not shorted/leaking and finally check the power regulator ic if its not shorted! note: some capacitors and diodes are very tiny, you should use a lens with good amount of light...
if it does not help..... well, what the hell? try pouring some gas, then light it up! that should solve the problem, at least it turned on right? hehehehe!
Apr 27, 2009 | AOC LM729 17" LCD Monitor
Sony STR- DE315 Transformer Voltages
yes primary smoothing capacitors it place just after the rectifires.
Jan 08, 2009 | Audio Players & Recorders
Bose Wave Radio Logo
633 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
