Question about Asko Dishwashers
My asko dishwasher will not stop running, it gets to one min. left and just doesn't stop
  • will Jul 21, 2008
    even with only 1 min left in the last cycle?
    Scholar:
  • 50 Answers
It is not heating. It must reach a certain temp in the rinse to move on.
Posted on Jul 21, 2008
  • Austin DeBock Jul 21, 2008
    These dishwashers don't heat the air to dry the dishes. They bring the final rinse temp up to a certain temp and hold it there for a few minutes. This stores heat in the dishes and this stored heat (combined with the rinse aid) is what drys the dishes.
Asko 1375 will not fill completely
It needs to have the correct fittings you can call around and see if you can get a generic one that had the same threading for your reducer however it doesn't sound like a bad valve I think its the float switch that is bad
Jul 25, 2012 | Asko 1375 Dishwasher
The drain pump motor on my ASKO model 1375 dishwasher wont stop running
Had a similar scenario on my Asko 1325. I simply removed the unit in preparation to chuck it, but once outside decided to check the inside of the pump/impeller and the electrical connections. Found plastic debris in the pump, and wiggled every electrical connector of its attachment and then re-attached it. Tried the Asko-fiasko outside and it worked.
BTW be prepared for an electrical failure/ meltdown as per the following two photos:e4b01cd.jpg47ce737.jpg
Jun 22, 2009 | Asko 1375 Dishwasher
ASKO dishwasher won't drain and makes rattling sound.
I had tried several failed attempts to fix this problem. Finally I got on my knees and asked God to make the dishwasher run in Christ's name. The dishwasher just completed it's first cycle without any problems.
Feb 10, 2009 | Asko 24 in. D3121XL Free-standing...
Asko 1385 dishwasher spray arm doesn't stop when door is opened
If there's a fault it's with your door latch/switch cheers
Jan 08, 2009 | Asko 1385 Dishwasher
Viking (made by ASKO) Dishwasher Problem
You can find parts, solutions and manuals at link below. Hope this helps, Sea Breeze
Click below
http://www.retrevo.com/s/Asko-D1716-Dishwashers-review-manual/id/21338ci577/t/1-2/
Dec 18, 2008 | Asko D1716 Built-in Dishwasher
ASKO dishwasher
F2 fault water in the base remove dishwasher from under the bench and tip back water will run out,then it will restart.remove rear lower panel and run the dishwasher you may find a leak,also check that the inlet valve is shutting off and not filling the dishwasher up overnight.hope this helps.
Mar 27, 2008 | Asko D1776 Stainless Steel Built-in...
Asko D1876 dishwasher
the dishwasher remembers how long the last wash took.was it intterupted? try using again, or the board could be faulty it should be about 2hrs 10 min approx.hope this helps
Mar 16, 2008 | Asko D1876 Dishwasher
Asko D1796F1 builtin...lights are on but no one is home
Our Asko D1796 dishwasher has the lights on the panel working as usual but you can't select a cycle and it won't turn on. We unplugged the pipe. If we turn it off and wait for 12+ hours we have gotten it to work twice.
Mar 02, 2008 | Asko D1796FI Built-in Dishwasher
Asko dishwasher d3120
Hi this is known as an L1 fault (Not heating) you need to check the element,thermistor,wash motor,wiring or the pcb.Failing this you need to ring asko
Mar 02, 2008 | Asko D1776 Stainless Steel Built-in...
Asko diswasher
Remove the backpanel of the machine, and look if there is water at the bottom of the machine. If so, use a towel or so to dry up the water. This should solve the prob.
Nov 23, 2007 | Asko D1776 Stainless Steel Built-in...
Dishwashers Logo
117 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
