Question about Samsung LN-T4061F 40 in. LCD HDTV
Image problem Hi I have a 3 month old 40 Inch Samsung LCD T4061FT4061F, and sometimes the picture and goes into multicolor thin vertical frames.....pink blue green red and so on....these are not static....I totally loose the picture but i have the audio keeps working. I am concerned because it has done it about three times now....I goes after a few hours..... is this a major problem?
  • grimzo Nov 26, 2008
    i have the exact same problem on mine. i called up samsung and they suggested unplugging the TV for a few minutes and starting it up again - that solved the problem for a couple of weeks, but now it's back again.
  • howiejon Dec 30, 2008
    I have the same problem: thin multi-colored lines down the screen that occur shortly after turning the tv on. Turning it off for an hour allows me to see the image for a few minutes but then it happens again.
  • 52 Answers
Its only 3 month old, so its still under warranty. Yes, its a major problem.
Posted on Jul 24, 2008
Whenever I turn my television on, multicolored vertical bars appear over the image. They do not fade and appear to be linked to changes in color on the image on the screen. Is there any way to fix this?
the screen is damaged on the connectors, if you slightly push on the top or on the top of the screen and the picture comes normal thats where the fault is, if not then its come off on the connector board at the top of the screen before it goes to the driver board on the back sometimes can be fixed if you put a thin wedge in the gap with the screen taken apart then put back together, but if you dont have space and good knowledge to do this dont try it as it will cost you a new screen if you damage it, the lcd is only as thick as a 1,5mm and can easily break. you can do it without taking the whole screen out of the case and just remove the metal shroud, and stick some foam pads on the cables to the screen and carefully put the shroud back on so the shroud hold the pads in place.
Jan 03, 2015 | Samsung Un46eh6000 46-inch 1080p 120hz Led...
Toshiba 40inch lcd multicolored vertical lines on side of picture
BAD LCD PANEL, common problem with older Sony's that used Samsung panels!!!
Nov 06, 2013 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
I got multiple thin colors on the middle of the screen
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display issue (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further updates will be on my Facebook page.
Aug 17, 2011 | Toshiba REGZA 52RV530U LCD TV
2/5 of the screen has vertical lines multi colors. Is this a fixable problem?
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display problem (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further resolution updates will be on my Facebook page.
Jul 24, 2011 | Toshiba REGZA 52RV530U LCD TV
The screen has colored vertical lines and becomes to a dark black band about 6 inches of width.The tv is exactly two years old by today.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further solution updates will be on my Facebook page.
Apr 11, 2011 | Toshiba REGZA 52RV530U LCD TV
Have a Samsung LNS4695 DX LCD about 3 1/2 years old. When powers on will take about 5 secs and then picture but has thin, multicolored vertical lines. After turning off and on a few times, picture is...
yes this is due to bad caps I have replace dozens of caps for samsung tv's you can do it your self or have some body do it for you or ship the power board to me
Sep 04, 2010 | Samsung LN-S4695D 46 in. LCD HDTV
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
LCD TV SCREEN PROBLEM RED HORIZONTAL LINES OF DOTS ALL OVER SCREEN PLEASE HELP
This should be repairable. It may be the LVDS Cable or the Main board problem. The only other problem is the T-Con Board.
Dec 13, 2007 | Samsung LN-S4051D 40 in. LCD Television
Samsung LN-T4061F 40 in. LCD HDTV Logo
391 people viewed this question
Henry  Thomas
Henry Thomas
