Question about Apple iPhone Smartphone
NO SERVICE I manage to unlock my iphone but the problem I cannot use it to call and send SMS as it is showing that my service provider is not authorized provider.
My number will be change.how can i do?
Posted on Jul 22, 2008
Samsung gt c3303 network
Hi i think your samsung c3303 mobile is locked to network ...Due to this if you enter other network sim in it ..It wont work with it unless you unlock it .If you want to unlock your samsung c3303 mobile from network lock then you can use online providers like Theunlockarena.com who render unlock code for all mobile models at affordable ..Even after unlocking it if it shows same message then you can better contact your service provider.
Jun 24, 2013 | iPhone Apps
Sms problems
this type of problem happens due to sim card and service provider go to setting and check sms center number and call the customer care for the help.
Dec 06, 2007 | Apple iPhone Smartphone
Tip
IPhone texts not sending
Green text messages not sending from iPhone...
this is part of the SMS text service and is activated from within iMessage..
go to settings and select messages
turn iMessage ON and sign in to your Apple ID
this turns SMS texting on so you can now send green text messages from your iPhone...
good luck !
on Mar 30, 2017 | Apple iPhone Cell Phones
My mms messages do not send on my curve 8520, they try to send for a long time then show it failed to send, i tried sending to myself and that did not work
This could only be caused by a couple of things. The message center number in the handset may not be correct, which will cause the messages to fail. The other possibility is that the feature is not active on your account with your wireless provider. What you need to do is test a couple of things. See if you can send a text/sms message to yourself, in doing this you can verify that you can not only send, but receive text/sms messages. If you cannot send, or receive text/sms messages, then that verifies that the message/service center number is off, and will need to be corrected. If that works, and you can receive text/sms messages, then your service center number is correct, and you will move to the next troubleshooting step, which is to test your web browser. If you cannot launch the web browser on your handset, then this is an issue, because the MMS service requires that you have both SMS, and web browser service to send a MMS message. If you can access the internet and you have the ability to send/receive text/sms, then you need to call your service provider as the issue may be with their service.
Mar 10, 2011 | RIM BlackBerry Curve 8520 Smartphone
My iphone says no service so i cant ring or send sms messages
You will have to move to a place within range of service providers transceiver site to get service ... You don't say where you are located ... it is difficult to give you better advice. I suggest you contact your service provider
Oct 20, 2010 | Cell Phones
I cant send sms text messages. When I send it
For this please check if for the network issue buy sending a PIN to PIN message if you are able to send a PIN to PIN message then the network is fine if you are still getting red X the contact your service provider so that they raise a service request to the network team.
Hope this helps you
Aug 10, 2009 | RIM BlackBerry Pearl 8100
Problem in sending sms
if you are unable to send text messages(sms) to anyone then there is a problem with the message centre no. refer your manual to fine the message centre no in your phone(probably in text message settings) and check if its compatible with the service provider.( call the customer care of service provider to get the message centre no) and enter it and save it. then you will able to send text messages.
Jul 02, 2009 | Sony Ericsson T230
Iphone SMS problems
I found this solution posted as comment on this clip:
This following solution was suggested on youtube, it worked for me. There is one negative point about it: ALL YOUR OLD MESSAGES WILL BE DELETED
If you delete your sms.db file (located in: var\mobile\library\sms) it fixes it, you can open and send\recieve sms. i think the only permanent solution is to upgrade to 1.1.3 with itunes and start again (im asuming u got the bug using ziphone, i did). i installed isms as a backup sms service incase it stops working, which it does often. you cant look at recieved messages, but good for sending sms if sms.ap is playing up
to delete sms.db i use mobilefinder on my iphone
Dec 09, 2007 | Apple iPhone Smartphone
Check message center no.(Service provider will provide u ) , message sent as (Should be "text"),message validity (max. time), replay via same center no.(No)
Gizmo1
Oct 22, 2007 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
