Question about Mitsubishi WD-52525 52" Rear Projection HDTV
T.V. Problems We have a 2004 Mitsubishi WD-62525 T.V. that is displaying a blue screen with like fuzzy lines in the middle. No picture at all. It won't even turn channels. Do you know what's going on?
  • Mitsubishi Master
  • 8,617 Answers
Sounds like the capacitors on the FMT or Signal PWB need to be replaced.
Posted on Jul 22, 2008
SOURCE:
MITSUBISHI WD62525 - bad fuzzy picture with lines and waves - have MonLink hooked up to DTV. Picture does not improve even when playing a DVD. Used same MonLINK with another tv and picture was great !
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 27, 2011 | Mitsubishi WD-62525 62" Rear Projection...
I have a Mitsubishi WD-62525. In general the picture is great from all sources (cable, component, and hdmi). However, there occasionally are very thin, horizontal lines that flicker across the screen....
I have seen this problem before. It is usually caused by a malfunctioning color wheel. Replacing it should resolve the problem. Let me know if you wish to fix it yourself so that I can find you a replacement.
Jan 16, 2011 | Mitsubishi WD-62525 62" Rear Projection...
T.V.powers up I get light blue screen then shuts down mits.wd-625
not bulb component is damaged in power supply serction shutting down to protect other components
Sep 09, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Scrolling lines
problem with the Picture tube.set graphics properties to check.
Jul 06, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 BLUE SCREEN NO PICTURE NO SOUND
I had the same problem and I found that it was 2 caps on the power supply board. I had both caps replaced and it worked perfect. While it is apart see if any other caps are bad( if they are puffed up in the center they are bad).
Jun 29, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Blue clouds in the screen of a Mitsubishi WD-62527
i have had similar problems before for me it was caused by a strong magnet on the floor below me. i suggest looking around for a strong magnet that could cause the problem
Jun 06, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Unable to receive input device signal
Can you post a picture of the screen so I can properly diagnose it. It sounds like the caps on the FMT PWB but a picture would help me be certain.
Aug 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Blue screen with white snowy circle in the middle of screen
Sounds like bad capacitors
Replacing the C9A37 & C9A38 caps or
problems with some capacitors on the pwd power board, and that it would be good to change them if they were swollen
Oct 20, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
118 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
