Question about Philips 27PT6441 27" TV
My phillips tv is dead
The set is dead there is no pictures, when it is turned on it makes a click and turns itself off. any help will be greatly appreciated.
  • 1 more comment
  • Abec17 Jul 28, 2008
    I can't turn on my T.V. When I push power it starts ticking. The LED light lights up solid once and then flashes 5 separate times and then repeats the cycle.
  • Anonymous Aug 02, 2008
    My 27" philips 27PT6441/37 the green light just flashes on and off no high voltage. I was told a board #3139 1880 6221 was bad. However I can't find that board inside the TV
  • Chriss TV Aug 02, 2008
    I have a Philips 27" TV that the green light blinks. No high voltage at all. I was told that a board # 3139 1880 6221 is bad, but there is no such board. What is wrong? Model# 27PT6441/37
I am sorry, what do you mean by remote faction, do I need to turn the set with its own remote? thanks a lot.
Posted on Jul 21, 2008
No remote faction
Samsung dlp dnie
just from personal exp the easiest thing to do may fix or at least make it better. if u see puffed and leaky caps on power supply replace capacitors. if really dusty clean. both previously mentioned and both helped me. my tv was completely dead and replacing caps got it to power back up and work. it takes two trys to come on but works great so far. then i cleaned every nook and cranny with a small vacuum hose and different size/angle brushes that could be attached to hose. i only took out the psb board with caps and didnt touch anything in there that i could mess up. just cleaning helped enhance the colors. right now this is the best picture ive had on a tv and it was completly dead when i got it.
Jul 28, 2014 | Samsung HL Televison & Video
I have a 50" phillips
hi need more information on the fault, thanks
shaun
Apr 16, 2017 | Televison & Video
TV turns itself off after about 5 minutes (green light remains on). I can turn off the TV and turn it back on immediately, however, the TV turns itself back off after a few minutes. It started turning off...
Check and make sure your fans are working and there is sufficiant cooling to the back of the set. Sounds like it is overheating and going into protection mode.
May 04, 2011 | Mitsubishi WS-65513 65" Rear Projection...
Z50PX2D - I did not have the typical "Popping" Problem, nor have I ever had any Picture Problems. When I try to turn the set on, I hear the normal "Click", and the entire set is dead, standby light turns...
I own the same set. I had the "pop" happen to me. I decided not to fix the set, but before trashing the TV I removed all the boards and parts that I could. This included the Power Supply Board and the Main Board along with the Y Sus, Z Sus, Y Buffers, Speakers, Cooling Fans and few other things I don't know the name of. I'll sell all these parts $150, cheaper than you will find the Power Supply Board by itself. With all these parts you can fix the set cheaply no matter what ends up being the problem. Let me know if you are interested.
Sep 27, 2010 | Zenith Z50PX2D 50 in. Plasma HDTV
TV will not turn on
Hi, make & model ? clicking is tv`s relay turning set on but set shuts down because power supply has a dead short in it, you will need a tv tech to fix this one, gl,
Jun 08, 2009 | Televison & Video
TV makes "Pops" and "Crackles" sounds from the back while viewing
remove the cover and observe the source of the light. if its in the picture tube it can be fixed with a picture rejuvonator. if its a cracked solder joint a soldering iron and solder will fix it.
Dec 06, 2008 | Philips Magnavox 42MF521D/37 Television
Phillips 60pp935217
I have a phillips HDTV monitor model 60pp935217, i don't get an hd picture but i do have sound. Please help.
Apr 08, 2008 | Philips 60PP9352 60" Rear Projection...
TV turns itself off after a few seconds, no picture at all
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Mar 28, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Phillips 60'' projection hdtv wont turn on
Question do you see green led or light when pressing power button? If you can also listen for a high pitch noise coming from back of set. This would be an indication that the set has powersuppy problem or high voltage problems. If the set is dead and no noise then maybe fuse or open circuit.
Aug 13, 2007 | RCA P46924 46" Rear Projection Television
Philips 27PT6441 27" TV Logo
117 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
