Question about Philips HTS3450 System
470uF capacitors I thought that there were supposed to be two 470uF/25V capacitors on the power supply board in the sub-woofer. Instead I see two 470uF/200V capacitors in there. Should I still get the 25V or stick with 200V that's currently on the power supply board in the subwoofer?
  • mdeck Aug 10, 2008
    Does the pcb with the capacitors have to be detatched from the other pcb?
    The two big 200v capacitors on easily accessible , right next to the flat slab aluminum heatsink.
    is there another pair hiding somewhere?
  • anon291842 Dec 10, 2008
    the capacitors on these systems are actually 470uF/16v for most people. They are little brown ones you gotta replace, on the other side opposite of the huge black 200v capacitors.
    I replaced them, and the sound is back and there is no buzzing, but the sound is so low I have to turn everything else in the room off to hear it, even at max volume.
    Problem Solver:
  • 3 Answers
I have the same problem but only can see 1000uf/50v. Can you post a photo of their position.
Posted on Aug 13, 2008
  • 20 Answers
The 470uF/25V Caps are in the middle of the PCB alongside of the slab-looking aluminum heatsink. You should be able to see that the tops are popped up and the glue around them is brown from overheating.
Posted on Jul 26, 2008
Capacitors - Philips HTS3450 System Problem
Are you sure you are looking at the right board? I was looking at the wrong board (the one with the long, low heat sink and lots of capacitors). I can post or e-mail you a picture of the location if that will help.
Aug 13, 2008 | Philips HTS3450 System
Phillisp HTS3450
As I found somewhere on the internet; there are two 470uF/25V capacitors on the power supply board in the sub-woofer that are the cause of buzzing, crackling and then eventually no sound. Go to Radio Shack and buy two Catalog #: 272-1030 470uF/35V capacitors and change them out. They are in the middle of the Power Supply PCB and are close to the long flat aluminum heatsink. Make sure you match the polarity properly when replacing. Your unit will be as good as new and will proibably last forever now.
Jul 06, 2008 | Philips HTS3450 System
I bought philips 5.1 home theatre for PC it is not supporting
Jul 02, 2008 | Philips HTS3450 System
Email id
Jun 12, 2008 | Philips HTS3450 System
Philips HTS3450 sound problem
Jun 09, 2008 | Philips HTS3450 System
Won't power up
May 10, 2008 | Philips HTS3450 System
No SOund from the HTS3450
Apr 20, 2008 | Philips HTS3450 System
No sound nothing
Jan 01, 2008 | Philips HTS3450 System
Mine buzz for about a month and now it is turning red light and no sound..... anything I can replace to fix it?
Dec 18, 2007 | Philips HTS3450 System
Home theater system
There are two 470uF/25V capacitors on the power supply board in the sub-woofer that are the cause of buzzing, crackling and then eventually no sound. Go to Radio Shack and buy two Catalog #272-1030 470uF/35V capacitors and change them out. They are in the middle of the Power Supply PCB and are close to the long flat aluminum heatsink. As far as installation instructions go; you have to have some soldering experience, first. You will also need some type of de-soldering device, be it a solder ****** or solder wick to remove the caps. Make note of the polarity before removing. Then it is just a matter of popping the new ones in (they are slightly larger than the originals so they might not go all the way down flush with the PCB) and soldering them back in. Make sure you do not make any solder shorts or your system will be toast! Your unit will be as good as new and will probably last forever now.
Sep 22, 2007 | Philips HTS3450 System
Philips HTS3450 System Logo
381 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
