Question about Maytag Neptune MAH5500B Front Load Washer
Mah5500B. during spinout a "nd" error message shows up where time is usually shown
  • 725 Answers
ND is no drain ...your drain pump may be clogged if clear check if the drain pump has power, and is not pumping it is either the pump or the pump or hose plugged up.
Posted on Jul 21, 2008
Spin cycle (7min) starts, spin perfectly, try to let water go (doesn't work) then reset back to 7min... ND code does appear but not all the time
ND error code means no drain check the pump filter check the pump and check the drain line that goes from the oulet port coming out of the outter tub to the pump and also check the drain hose leaving the pump that goes out of your washer as well. If you have any further questions message me back I await your rely
Thank you,
Rick
Oct 28, 2011 | Maytag Neptune MAH5500B Front Load Washer
Shows code nd washer only hums when restarted and door will not open
Hello,"nd" refers to a No Drain issue . check for restriction in pump assy, restricted drain hose loose wire at pump, bad pump.
Thanks
May 31, 2010 | Maytag Neptune MAH5500B Front Load Washer
Hi, I get a blinking light with error message "nd". Also machine will not start. Any suggestions? Thanks.
The washer experienced difficulty draining. Check for a kinked drain hose. Check for a plugged stand pipe.
Oct 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Just replaced motor and control kit but water wont drain and nd shows up on screen after wash has gone for apprx 25 min. do i have a pump problem.
well nd means no drain
but you may not have a p[roblem
quite a few times during this repair, the plug for the pump got pulled out, but if thats not the case
just disconnect the pump and make sure there is nothing in it these lil pumps are actually pretty hardy
so im pretty sure its one of those issues
Oct 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
ERROR CODE ND
nd=-no drain
remove the back panal you will see the pump
its probably just clogged
Sep 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Jvc- gr-d740 camcorder's cassette is not ejecting message is showing that unit in safeguard mode please advise
There should be an error code star with E-01 to E-06.Below is an example you have to make sure that which error code showing on your camera
Whenever some abnormal signal is input to the syscon CPU,
an error number (E01, as an example) is displayed on the
LCD monitor or (in the electronic view finder).
In every error status, such the message as shown below
E01 LOADING--------
1. The mechanism is locked during mode shift.
2. The mechanism is locked at the mechanism loading
end, because the encoder position is skipped during
mechanism mode shift.
3. No power is supplied to the loading MDA
Sep 25, 2009 | JVC Video Cameras
What does the code ND mean?
ND - No Drain
Machine control board monitors water level in washer during and at the end of pump out. If wash level does not reset pressure switch, it will see water left in the washer.
1.Check for pump/drain restriction.
2.Check pump operation.
3.Check pressure switch for open contacts.
4.Check inputs and outputs at machine control board.
5.Replace responsible component.
Apr 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer does not drain
ND error means no drain. When this happens it is usually a problem with the drain pump assembly, located under the bottom panel, inside the machine.
check the drain hose and the drain lines, ensure they are not obstructed. Probably the drain pump need replacement.
Oct 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
Nd error essage
nd= no drain. loud buzzing noise sounds like something stuck in pump assy.remove the door(2screws) adn other 2 screws oppisite side, and hte front panel comes off giving you acess to the drain pump, pull the hoses and look for the obstruction
Mar 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
341 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
