Question about Miele 24 in. G656SCi Plus SS Built-in Dishwasher
Half way through a program then stops, leaving water in the bottom of the machine
I have checked all the filters including the water inlet, all clear
Any program stops half way through leaving water in the washer, with the Inlet/Drain light flashing.
I will replace the water inlet pipe tonight, this is a costly exercise if I am not right with this solution.
Please advise
  • Metooaswell May 11, 2010
    I have the same problem. Where is the flood switch and how does one check it?
    Problem Solver:
  • 4 Answers
Check the flood switch first. It will stop the dishwasher but you may hear a moter running.
Posted on Oct 10, 2008
Hotpoint WML 730
Possible this seems to be an error. You need to start by check the inlet water flow, check the free flow, if not check the inlet valve or the valve drive. Also check the drain pump and see if there is no clogging, Now switch on and check voltage on the inlet valve, if absent check the main program controller. If water flows check
Nov 21, 2013 | Washing Machines
Whirlpool Cabrio washer model WTW6200SW, when the wash cycle is started, starts filling with water, after roughly one minute the machine stops than goes into spin cycle, will spin for a short time than...
Possible there are errors in the program memory. Power off the washer for half an hour, press and hold down the start button , then switch on. Try also with another program. Also check if the inlet filter is clogged and the water flow is good, if not clean. Also check the water level pressure sensor.
Nov 01, 2013 | Washing Machines
My smart drive GW 509 au does not fill up with water. Water goes in but only for 10 seconds and stops. Machine then bips with some error.
Please check the pressure on the inlet valve and see if the flow is good, if this is low on the inlet then check your tap and water line. Otherwise check the INLET filter, check the command to the inlet valve and if the inlet is timed out then there is fault on the program controller unit.
Jan 02, 2013 | Washing Machines
Hi my hotpoint ultima wmd960 of 2 half years,when i put a wash on it starts and fills up for about 3 mins later it comes up :no water, check supply, then starts ti drain water away ,then fills up again,so...
Please check your inlet water hose for any clogging that may be stopping the proper flow. some machines are programmed to get filled in particular given interval of time. they need proper pressure to properly work. Remove the hose and clean the wire mesh filter.
Oct 02, 2017 | Washing Machines
Zanussi 1140m stops half way through wash cycle then displays error code E21.....works ok on stright spin cycle....filters checked and found to be clear
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Jul 19, 2011 | Washing Machines
Meile Novotronic W 828 Washing machine half way through the cycle it stopped and the screen shows a message saying "check the inlet"
It means what it says! i.e. water is not getting into the machine, the inlet hose or path is blocked or the inlet valve has failed. You need to turn off power and water and check it is getting water through inlet hose and that the inlet filter is clear, the filter can be seen on the valve when you remove the hose. You will need to open the machine to check the inlet valve and tubing. Hope that helps please vote
Feb 04, 2011 | Miele Washing Machines
Water dispenser stopped working
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your water line could be frozen in the door. You can disconnect the line at the bottom before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does, leave the door open till it thaws.
If it doesn't come out there disconnect it at the water inlet valve and see if it comes out there. The valve could be bad.
A strainer before the inlet valve can also get stopped up restricting flow.
Dec 13, 2009 | Washing Machines
Soapy water left in bottom of tub.
This is usually caused by a cold water supply problem, since cold water is what is used in the rinse. Check the water inlet valve. Remove the water supply hoses and check the small screens inside the water inlet valve (especially on the cold side). Make sure they are clear of rust and debris. The solenoids can be tested using a mulitmeter or ohmmeter. Test for continuity. A lack of continuity indicates a faulty solenoid. I will attach a photo for reference. Hope this helped and best wishes.
Aug 15, 2009 | Washing Machines
Dishwasher stuck´s in program
Well to Reset the error message as follows: To cancel the error message, turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs. Then switch the appliance off and then back on again.
If resetting not work then you can check that the stopcock is opened fully or whether the water inlet hose is kinked. Check that the water inlet filter is not clogged and clean it, if necessary, as described in the operating instructions. Check that the drain pump is not clogged.
Good Luck!!
Jun 21, 2009 | Dishwashers
Miele 24 in. G656SCi Plus SS Built-in Dishwasher Logo
428 people viewed this question
Top Miele Dishwashers Experts
mpservices
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
