Question about GE WSXH208A Front Load Washer
Washer I would like to know what i could do about the awfull smell my washer gives off after going through a wash cycle. Should i run it with baking soda?
    Scholar:
  • 50 Answers
Bacteria causes odors. Try running a load without any clothes on HOT and add a cup of bleach to the soap dispenser. In the future use the hottest water the care tag on your clothes will allow. Use bleach as often as possible. If it's a front load washer, make sure you are using HE detergent. Non HE detergent will suds up and the suds could potentially remain after the wash and create an odor. If you don't like to use the hot wash or bleach on your clothes, then you may need to run a load once a month as described above. There is also a slight chance it's coming up from the home plumbing. Make sure the home plumbing is draining fast enough, but ultimately the bleach you use in the washer will run down the drain and help keep it from causing an odor.
Posted on Jul 21, 2008
Zanussie essential 1400 smell of mould can't get rid of it
g'day. Move the machine to check for leaking water. This could be from the taps in the back, or hose clamps throughout the machine and could be causing chronic dampness around the machine. Also check for filter to clean pump. You might have to look under the machine. The soap draw can also get clogged up - but generally doesn't smell. good luck
Aug 14, 2011 | Zanussi FC1200W Front Load Washer
After a wash cycle, there is water sitting in the gasket around the door. This water smells after a few days. What is to be done?
Make sure the washer sits level front to back and side to side. Wipe away any water and leave the door ajar to let the inside dry out. If the whole washer insides smell, run an empty cycle with hot water, detergent, and baking soda to refresh. Hope this helps!
Oct 17, 2010 | LG WM-2277HW Front Load Washer
A foul smell is coming out of the washer. The clothes don't smell, just the washer. I don't know what to do. Maytag MTW6600TQ0
for smelly situations like this you can use half gallon of bleach with no clothes in it full load cycle let it sit 15-30 min's full of water then let it run through all cycles if you want you mix it a half cup of baking soda too and it should do it.
Dec 20, 2009 | Maytag MTW6500TQ
Moldy smell from front-loader Asko washer.
Hi
First check to make sure that the machine is draining properly and that the pump filter is clear of any debris.
On a frontloader a common place for mold to build up is the rubber seal around the door. Clean this out as well as you can with ordinary kitchen cleaner then place a heaped cup of baking soda directly into the drum and run an empty hot/boil wash on a full cycle.
Baking soda has a cleaning and neutralising effect and will help remove any build up of mold or gunge within the machine. You may need to run two of these washes before you see a solid result.
Thereafter I recommend you run a monthly 'maintenance wash' with the baking soda to prevent the problem arising again.
Hope this helps. Thanks for using FixYa
Nov 15, 2009 | Asko W6461 Front Load Washer
We've owned this washing machine for r+ years and it has been making our clothes smell awful--in fact, the machine itself smells awful. I've tried cleaning the basin with a bleach solution and I even ran...
By my experience on Washer Machines, I would say that the problem are bacteria and mildew growing in the machine, not exactly in the drain or drum from the machine. Mildew can grow everywhere.
Oh, by the way, don't even think about bypassing any sensor from your machine. You don't want to wake up tomorrow and find a pool in your house, right?
To kill mildew and bacteria you may want to try some simple solutions:
* Keep the lid up between washes so that bacteria and mildew won't grow in it. Pour a bottle of vinegar in hot water and run it though the machine on a heavy load wash. When it is finished, leave the lid up.
* Didn't help? then pour a box of baking soda in it and running it with hot water cycle. Try running it without clothes.
... I mean, Run the washer machine without clothes inside. (Oh my gosh, I should go to bed, it's too late for giving advice on FixYa)
* If the smell continues Pour a big bottle of peroxide hydrogen (the 3% one from the drug store) and run a heavy load wash. Be sure not to use good clothes, it will get white. if that does not work, u may have a more serious problem. Perhaps the machine needs to receive maintenance and spray some peroxide hydrogen where the mildew is growing.
Also, You can try a commercial product for this kind of issue: http://www.smellywasher.com/
Some people says that it works when everything else fails.
Nov 08, 2009 | GE WPGT9360E Profile Harmony 4.0 cu. ft....
Foul water smell coming from washer after using machine.
Check the hoses to make sure there are no leaks or standing water behind. Try running a cycle or two of vinegar water and baking soda water to kill any mildew that might be in the tub.
New washers often give off an odor described as a burning match or electrical smell. This is normal and is caused by the "wearing in" of clutch shoes and the heating of new paint on the motor windings.
Older washer odors are usually caused by leaving the washer lid closed when not in use. This does not allow air to circulate and dry out the moisture remaining in tub area. The air and moisture mixture becomes stagnant and creates an odor. When washer is not in use, leaving the lid up/open for air circulation will help prevent odor.
To get rid of odors inside of washer follow the steps listed below:
  1. Fill the washer with hot water; set at regular speed & longest time.
  2. Add 3/4 cup of Calgon Clothes Detergent. (Baking soda can be substituted) .
  3. Allow washer to complete entire wash and rinse cycle.
  4. If odor lingers, repeat entire process.
Oct 18, 2009 | Washing Machines
Mold smell
Use about 1 cup of baking soda plus detergent and run a cycle (hot water). After that, leave the door ajar after each wash to allow the interior to dry out. With the door shut, front loaders have no way to vent the residual water out. Hope this helps.
Sep 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Laundry room smells like rotten eggs
Does the sewer drain line have a trap at the bottom that prevents sewer gas from entering the room? If the smell seems to be coming from the washer itself, run a wash cycle empty with a cup of baking soda, detergent and hot water to clean the interior.
Sep 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Admiral Washer smells like mildew
yes it could . If you are trying to pump the water 7 feet or more above the floor then it will at the end of the cycle get air into the drain hose causing cavatation, the result when the machines stops is the water running back down the drain hose back into the tub and that is what causes the musty smell.
Lower the drain if possible
Apr 10, 2008 | Admiral AW22 Top Load Washer
GE WSXH208A Front Load Washer Logo
75 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
