Question about Refrigerators
Side by side jenn aire refrigertor. After six months of use, the right door blows open when closing the left door. I have re leveled to no avail. Any suggestions on the problems
  • Anonymous Sep 20, 2008
    I have the same problem. Just started a month ago after three years of closing properly and staying closed.
    Scholar:
  • 50 Answers
That's not uncommon, but the door should swing back shut. The fridge should be level side to side, but tipped back just a little. This will help the doors close. Also some fridges have door closers on the door hinges. They are usually plastic or nylon and can wear flat. If your fridge has these, the doors will lift just a little (maybe 1/16th to 1/8th inch) when it's opened. Usually the fresh food door is bigger and heavier and will wear out closers faster than the freezer door.
Posted on Jul 21, 2008
Doors not closing all the way
check level from back to front on fridge if good than check the amount of food that is stored on the door if u have a lot of bulk, weighty stuff they may be acting as a counter balance on the door when u close the left side the air that is trapped usually disperses into the unit and is not forceful enough to push open the door but if their is a lot of additional weight on door it makes the door easier to open and swing on hinge
Apr 21, 2010 | Jenn-Air JFC2089HE French Door...
Gasket on Rght side of French Door Fridge
well I suggest you and your neighbor both call Jenn Air as they now have 2 known complaints and perhaps more if others read this and check theirs as well
Jan 28, 2010 | Jenn-Air Pro-Style JFC2089H French Door...
JENN AIRE SIDE BY SIDE REFRIGERATOR IS NOT COOLING ON THE REFRIGERTOR SIDE
this is a thermocouple failure I would think and they will need replacing. it could also be the damper valve that lets cool air into the fridge, I would think this is working and the fan that blows air in is failing because of the thermocouples, thermocouples are quite cheap.
If you have a technician to do the work this website might help
http://www.partselect.com/PartSearchResults.aspx?ModelNum=JCD2295HES&mfgModelNum=&fkMfgID=1&hint=dog+cog
Jan 15, 2010 | Jenn-Air JCD2295HES Side by Side...
Side by side freezer door pops open
This is a problem inherent with lots of refrigerators. Side by side or top freezer. The rush of air pops the doors. You might want to adjust the pitch of the box by adjusting the front wheels to a higher level.
Jun 17, 2009 | Jenn-Air JCB2280HES Side by Side...
Difficult to pull door open and loud click coming from left hinge
I would check for obstruction in the path of the door spring areas. If appropriate, remove the bottom access panel (typically 2 screws); open/close the door in attempt to observe the inside bottom left and right for the clicking sound.
If not already done so, also ensure your dish-washer is raised of the floor a little bit; leveled and properly secured to counter top with 2 screws.
-C
Fremont, CA
Jan 30, 2009 | Jenn-Air 24 in. JDB1100AWS Built-in...
Right side french door does not stay closed
I had the same problem - had my local appliance repair shop come by - simple releveling of the unit such that it is tilted slightly back re-establishes things so that the doors will cloe and pull themselves closed. The gaskets are actually magnetized. If the leveling is correct - even upon closing the left door - forcing enough pressure to push open slightly the right side - it will draw itself back in.
Nov 21, 2008 | Jenn-Air JFC2089HE French Door...
Jenn-Air JCD2289AT side by side
air damper closed? try to open it by hand.
Sep 27, 2008 | Jenn-Air JCD2389G Side by Side...
JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Aug 12, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn air oven stuck closed after attempt to activate self-cleaning
The lock motor may have failed. Most often, bending a coat hanger into a hook and sliding from the right side as you move the door to the right,will allow you to release the lock and open the door.
Jun 09, 2008 | Jenn-Air JJW8130D Electric Single Oven
Jenn-Air 30 in. Electric Wall Overn jjw8530ddw
lendebr is right...
Same problem here on combo microwave and convection oven. The hinges are a horribly wimpy design. Jenn air has a replacement part thats helps..but the replacment hinges will do the same thing in very short order. 1 month after I fixed ours my sister in law opened the oven door and let go of the door when it was about 2/3 open and that was all it took to tweak the new hinges so the door doesnt close all the way again. i should have clued in when the girl at Jenn air sent me three sets of replacement hinges. I thought it was a mistake..turns out she knew it wasnt going to fix it permanently.
The moral is that Jenn air appliances are POS and I will not ever buy anything from the again..But I will tell everyone I possibly can not to buy anything from them.
Jan 08, 2008 | Jenn-Air 27 in. Electric Single Wall Oven...
Refrigerators Logo
71 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
