Question about Philips Magnavox 51MP392H Rear Projection Television
Power Problem I turned off the TV and my girlfriend turned it on like 30 seconds later, it made some unusual sounds like clicking from the back, the sreen came on like a split screen of the same channel and then turned it self off. Now when I turn it on, it shows a silver screen for two seconds and goes to snow with a black horizontal line across it, then goes off. While its off the power button blinks 10 times, stops for 3 seconds and repeats, I guess this might be some sort of code. It refuses to go back on after that until I unplug it from the wall and then plug back in but the whole process just repeats itself with no TV picture at all anymore. Chassis# MAG 1 AA
  • Anonymous Jul 26, 2008
    I have the same problem. The power button just blinks. No power.
Same problem as sweetpetny...blinking power button, won't on.
Posted on Jul 26, 2008
My Magnavox plasma screen tv, model number: 42MF237S/37 makes a clicking sound when I try to turn it on. No sounds, no picture, just the clicking noise. Things I have tried so far: 1) Turning the TV off...
You either have a cold solder joint in your horizontal deflection circuits or your or in your horizontal output circuit. please be careful due to the fly-back transformer still holds power even unplugged until you discharge it.( ground it out). Hope this helps.
Jan 03, 2010 | Philips Magnavox 27MS343S 27" TV
Turn power on, approx. 30 sec later it the power
It varies as to what is actually making the TV shut down. Shorting the connectors on the A.C. plug have nothing to do with it turning back on. Its just the fact you are unpugging it for a few moments.
Nov 11, 2009 | Zenith Z19A11S TV
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Can't make this strange menu go away.
Unplug the power cord for 30 seconds. Before plugging the cord back in, press and hold the power button on the front panel for a few seconds to drain the power out of the system, then plug the power cord back in the power recepticle. Doing this process basically does a HARD RESET for the TV.
Sep 19, 2009 | Durabrand DWT2704 TV
No picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Jul 21, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
When I power up, 5 seconds later this back projector TV turns itself off
t does sound like a bulb problem, either its over heating and shutting off to protect itself, or its already shot. Give a TV repair shop a call and see if they can give you an approximate price, then decide to ditch or repair it.
May 30, 2009 | Televison & Video
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Tv comes on just the sound about three seconds later tv shuts off
I have the same issue with mine and have a solution that sometimes works. I had a repair guy come to check it out and he powered off the TV so that the red light was no longer blinking, then he unplugged the TV for about 30 seconds or so and then plugged it back in. He then turned on the TV and it worked. He said it would cost about $400 to fix the issue (some circuit or something). I have since expeerienced the on/off problem (due to power outage) and now I cannot get the TV to work. But at least give this solution a try and please post to let me know if it worked or not. Good luck!
Dec 23, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv powers on and off
Sound
Sounds like your bulb is nearing the end of its life span you will be needing a new bulb soon.
Jan 14, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Philips Magnavox 51MP392H Rear Projection Television Logo
126 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
