Question about Bosch 24 in. SHU53 Built-in Dishwasher
Does not drain
When we turn the unit on the symbol F flashes on the front of the machine. i do not know what the F signal means. i notice that there is water in the bottom of the tub, below the filters.
    Problem Solver:
  • 7 Answers
Check that the filter is clean -- (more likely) is your drain hose clear? -- you may have to trace it all the way back to the main drain or garbage disposal to be sure. My Bosch 5316 would not drain well, and I found it was clogged at the join up at the top of the sink.
Posted on Jul 23, 2008
Symbols on fridge freezer- i have a flashing symbol that looks like a test tube with a rounded end on hotpoint fridge freezer- what does it mean?
Is the water draining from the unit? It sounds to me like that symbol is telling you the water that has accumulated from removing the moisture in the conditioned air is full and needs to be drained.
Aug 03, 2011 | Danby Portable Air Conditioner
What does the LE flashing mean? Water won't drain out of washer.
LE means that the motor sensor has failed and needs a technician to come out and repair the unit. To remove the water, turn on the unit, press the spin speed button once and press start. It will drain the water out and spin the drum.
Jun 15, 2011 | LG WD-1280FHD Front Load Washer
It has the f02 symbol what does that mean
F02 :
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later
the F/02 error code will be displayed.
Potential Causes • Check the drain hose and make sure it is not plugged or kinked • Check the electrical connections at the pump and make sure the pump is
running. • Check the drain pump filter for foreign objects • If the above does not correct the problem replace the pump
Feb 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washer has a symbol on iy . It flashes H then F Do you know what this means
That code means its not getting water. Has it recently been moved? If yes check and make sure the drain hose is not too far down in the stand pipe causing a siphoning effect. Also check that pressure switch hose is clear. To clear code press pause/cancel twice.
Oct 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Drivers front turn signal don't flash or come on side marker will flash
If any turn signal doesn't flash that means you have a bad flash relay. It is not that hard to replace and should be in your fuse box underneath the hood. Go to your local automotive parts store and let them know you need a flash relay for your turn signal and they will know what you mean and they may even put it on for you since it doesn't take that long. Have a good day!
Aug 23, 2010 | 2001 Pontiac Sunfire
What does the f symbol mean on the whirlpool cabrio he washing machin. I had to turn it on again to drain and spin. There was flashing light all the time with the "F"
My machine is flashing. F all the lights are blinking on and off. Alarm sounds on and off. Give me some direction on what to do. Thank you ! Sue
Oct 05, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
The F21 signal keeps flashing.
f21 is long drain, failed to drain in 8 mins. f27 is overfill, overfill contacts on pressure sw closed. If unit did actually successfully drain normally then pressure sw is likely the problem.
1. did pump come on? if no replace pump
2. is unit draining at normal rate? no then clean pump.
if yes on both replace pressure sw.
to second poster if getting suds error when using HE then you likely are using to much detergent. If avail run a clean washer cycle.
or normal cycle with bleach or fabric softner, no clothes
Apr 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code F-28
It may be that the drain pump is not the problem at all. Error Code F-28 on the Kenmore HE2 means that there is a signal error between the Central Control Unit (CCU) and the Motor Control Unit (MCU)
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
Bosch 24 in. SHU53 Built-in Dishwasher Logo
149 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
