Question about Kenwood KDC-3028 CD Player
  • 1,586 Answers
You should be able to buy one through a car stereo shop, directly from the manufacturer, or possibly on eBay.
Posted on Jul 23, 2008
I have a 98 grand prix an I was wondering how to install it.. I have a harness that came with it but my factory harness won't fit. I was wondering if j have to rewire the factory harness to my JVC...
You need to go to your local "best buy" or electronics store and ask them for your car's "stereo wire harness". This will convert the wires from your car to match all the colors from your deck. (green, purple, white, gray, blue, yellow, red, ect. Same on all after market decks. All brands use the same wires) Take that new harness and your deck harness, twist the matching wire colors together, tape them with electrical tape, plug the harness back into the car and deck, and it should be good. Click, click, done. Remember to plug the antenna in as well before you get the deck in.
Jun 05, 2011 | 1998 Pontiac Grand Prix
Can i install cd deck in pontiac grand am without wire harness
That depends on several factors:
What CD Deck? Some can fit directly, others won't. Check the deck specifically to see it it will.
Do you want to hardwire the deck? If so, find wiring diagrams and install per both manufacturer's recommendations.
May 13, 2011 | 2001 Pontiac Grand Am SE
How do you get access to the rear turn signal lights in a 95 dodge intrepid
From Please let me know if you have any questions.
  1. Release the trunk latch and open the trunk lid.
  2. Remove the fasteners holding the trunk lining to the lower rear deck panel.
  3. Separate the trunk lining from the deck panel.
  4. Detach the lamp wiring from the wiring harness.
  5. Remove the nuts that retain the tail lamp to the lower deck and quarter panel.
  6. Remove the tail lamp from the vehicle.
  7. Remove the socket and pull the bulb out if replacement is needed.
To install:
  1. Push a new bulb into place if required, then insert the socket into the lamp.
  2. Insert the wire harness through the hole in the lower deck panel.
  3. Install the wiring harness grommet into the lower deck panel.
  4. Place the tail lamp into position on the vehicle.
  5. Install the nuts to hold the lamp to the lower deck and quarter panel.
  6. Attach the wire from the lamp to the body harness.
  7. Place the trunk lining into position on the lower deck panel.
  8. Install the fasteners that hold the trunk lining to the lower rear deck panel.
  9. Check the operation of the lamp.
Nov 05, 2010 | 1995 Dodge Intrepid
Whats the proper way to install the cd player into a 1992 chevy pick up truck and if u cud send a manuel
The proper way to install any aftermarket deck into a newer vehicle is to get a factory wiring harness adapter. This adapter will attach to the existing wiring harness for your factory stereo system. You can purchase these from various websites like this
When you plug this in your factory speakers and power/ground will all be available to wire to your new deck without cutting or splicing any wires. The colors follow the E.I.A standard and should match your new stereo. I hope this is helpful and thanks for using FixYa.
Sep 17, 2010 | Car Audio & Video
I need to know how to install a cd player in my 1997 jeep wrangler sport.
My suggestion would be to buy a wiring harness and a dash mounting kit. After that unscrew or pull out the console/dash part thats around your factory deck. Then unscrew the bolts/screws holding the factory one in place. Remove it. Plug the wiring harness into the factory wire plug. Pull harness wires through the mounting kit. Attach the corresponding colored wires from the harness to your new deck. Slide your deck into the mounting kit and secure it in place. Most decks have little prongs that you can pry up to **** up against the mounting kit so it wont slide out without pushing those down (makes it more secure and harder to steal). Place deck with mounting kit into area factory deck was. Put the screws/bolts back into place tightly. Place console/dash part back on. You will need the mounting kit (99% of new decks are smaller than the factory). Wiring harness is optional but recommended.
Jun 22, 2010 | Panasonic CQ-C7105U CD Player
Rockford fosgate installation?
The best way to install a stereo deck is go get yourself a Scoshe wiring harness. This will allow you to wire the harness directly to the stereo, then plug directly in to the OEM wiring clip that is plugged into the factory stereo. It helps if and when you sell the truck and want to put the factory stereo back in. Plus you dont have to hack up wires. Hope it helps. You can get the wiring harness from any car stereo installation or customization shop.
Jul 27, 2009 | Rockford Fosgate RFX-9000 CD Player
Audio wiring problem
Constant 12V+ Blue/Yellow
Switched 12V+ Gray
Ground Brown (or your own wire to a metal grounding point)
Illumination Green
Antenna Trigger Black/Red
Front Speakers 4" Dash
Left Front (+) Pink
Left Front (-) Purple
Right Front (+) Green
Right Front (-) Blue
Rear Speakers 5 1/4" Rear Deck
Left Rear (+) Black
Left Rear (-) Yellow
Right Rear (+) Red
Right Rear (-) White
I a '83 camry, there are 2 seperate plugs that go into a factory radio.
One for Power/and front speakers, and the other for rear speakers.
Sounds as if you are missing part of the harness for the rear speakers (or it is shoved in the back of the dash unused by the previous install). If there is not an un-cut plug in the dash - your only course of action would be to run your own set of speaker wire to the rear.
See this picture... these are the plugs that should go into your factory radio....
Metra kit 71-1938 will go from your factory wiring directly into your factory radio.
Thanks for using FixYa - a FixYa rating is appreciated for my effort in answering this Freebie question.
Feb 25, 2009 | 1983 Toyota Camry
How do I know if a new/used car cd player will fit?
yes.......... just buy a mounting kit for your car and a wire harness for your install just unplug factory radio and clip the harness on to factory plugs that you just unhooked from factory radio now just attach the same colour to colour wires from your new deck to the harness......mounting kit comes with instructions
(make sure to buy WIRE HARNESS & MOUNTING KIT for your car) and your install should take less than a hr to do
have fun
Feb 18, 2009 | Pioneer DEH-P2000 CD Player
I just bought a Kenwood KDC-MP438U I installed all the wires right, power is to the deck because it accepts a cd. the deck face doesn't light up. I called in at Kenwood and they had me test it directly to...
Check your Ground Wire inside the Truck and Check the Illumination Wire. I Think on Kenwood the Illumination Wire goes with the Power Wire. If they still will not work, You might want to get a Wiring Harness from Please Rate My Response! Thanks!
Jan 30, 2009 | Kenwood KDC-MP438U Car CD/ MP3 Player
Kenwood stereo Won't turn on
look and see if there is a reset... usually a tiny hole you can push a pen point into...(lightly)
Jan 27, 2008 | Kenwood KDC-MP205 CD Player
Kenwood KDC-3028 CD Player Logo
77 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
