Question about Apple iPod shuffle Second Gen. Silver (1 GB) MP3 Player (MA564LL/A)
Settings/content pane in itunes for adding songs does not show up
I have a 1st gen ipod that everything works fine with but when i plug my 2nd gen ipod in, (it's fully charged) the settings/content pane does not show up and neither does the little area at the bottom which lets you add songs. I was not even able to register it. The only thing that shows up when I'm on the ipod pane is a blank white area that says itunes store. I'm updated to the most recent itunes. i have the same problem- it won't even recognize it when it is plugged in. When I tried my other iPod, it worked. Is something wrong with the shuffle??/
  • jeffsmith182 Jul 30, 2008
    I appear to have the same problem.
    I can add music to my library with no problems.
    I can then drag music across to the ipod shuffle as it appears as a DEVICE in the left hand menu.
    However, the device has no submenus and I cannot see what is on the ipod shuffle. When I click on the device the main window is blank apart from a large title saying iTunes Store.
    The shuffle works fine when playing as required, but I cannot see what it on it nor take anything off of it or add anything new as it is now full!!
    Please can someone help?
    I can see it as drive and could probably delete files from the folder via a Windows Exlporer page, but I shouldn't have to do it this way and I'm not sure if this would cause further problems...
  • Technocrap Jul 30, 2008
    Exactly the same problem! Help!
Had the same problem. Just reinstalled Itunes. As of July 30th 7.7.1.11 Version. Fixed the problem right up.. I was able to register and get my songs to show up.. Good luck and happy listening...
Posted on Jul 31, 2008
How to delete some songs from 3rd generation ipod nano
For automatic syncing, you must reconfigure your settings so that the album/tracks/content you wish to remove is no longer configured to sync to your iPod. For example, if the Sync only checked songs and videos option is enabled from under the iPod's Summary tab, make sure all the tracks for this album do NOT have a tick mark next to them in your iPod. Then resync your iPod with iTunes.
If that isn't the case, you'll want to look at the iPod's Music configuration tab. You can access this tab by selecting your iPod underDevices. This should bring you to theSummary tab over to the right. Look for the Music tab along the top and select it. Here you can configure how and what music syncs to your device. If you make any changes to this tab, be sure to hit the Apply button in the lower right hand corner to sync the updated changes to your device.
Otherwise, if you manually manage your iPod's contents, you must manually remove content from it. You can do this by plugging your iPod in and clicking the small black triangle next to your iPod from under the Devices section in the left hand pane of iTunes. This will open up a submenu of content that is indented underneath the name of your device, so go ahead and click on Music (or whatever content you are wanting to remove). Locate the track or tracks/content you wish to delete. Highlight them and hit the Delete key or choose Edit -> Delete.
how do delete music from my itunes account and my ipod nano 3rd gen
Feb 12, 2015 | Apple iPod nano 3rd Generation
I added songs to my ipod shffle nd now i cant delete them?
To delete songs on your iPod you can connect the ipod to your computer via USB.
This should launch iTunes.
Your iPod should display on the left side of iTunes. Click on your iPod and it will display the contents. Select all of the songs and hit the delete key on your keyboard.
If you do not use iTunes, or this does not work for you, please provide more information.
Thanks!
Dec 21, 2010 | Apple iPod shuffle Second Gen. Silver (1...
How can i erase songs from my ipod
1. Connect your iPod to the computer. You cannot delete files from the iPod directly, and must use the iTunes interface to add and remove content from the iPod. Connect the device to the computer by plugging the long end of the sync cable (which came bundled with your iPod) into the data port of the iPod and then plugging the USB side into your computer.
2. Launch iTunes. Once you have plugged in your iPod, launch the iTunes program. You may need to wait a few moments while the program locates your iPod. You will know that your iPod has been located because a small icon that looks like your iPod will pop up on the left side of the iTunes program.
3. Click on your iPod to show the Device menu and then scroll over to the center pane where the music is. Find the song(s) you wish to delete. Left-click on the song (or album) you want to delete and then right-click.
4. Select "Remove" from the submenu. A message will pop up asking if you only want to remove it from the iPod or whether you want to remove it from the iPod and iTunes. If you want to keep a copy of the file(s) on your computer, select the option that removes the file only from your iPod. Once the file has been removed, go back to the iPod menu and select "Sync" from the center pane. This will remove the song from your iPod.
Sep 24, 2009 | Apple iPod nano 2nd Generation MP3 Player
ITunes+used 2nd gen ipod shuffle not working.
Ok, try completely uninsalling itunes, then reinstalling it. then importing the songs via add to library.
Jan 05, 2009 | Apple iPod shuffle Second Gen. Silver (1...
IPOD Shuffle Will Only Load 8 Songs
okay plug the shuffle to a windows based computer, then use "Disk Management" to format it, once it is formatted, run the iTunes then perform an update for the shuffle. once completed try to load songs and this should work for you now..
if you have other questions just lemme know.
Oct 03, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Nano Dilema
iTunes should copy the songs to the computer before doing the restore.
Sep 18, 2008 | Apple iPod nano
Music on Itouch shows up in Itunes but Itouch says No content add from Itunes
First you need to restart your itouch.
Then, plug it in to your computer and wait for iTunes to pop up.
Select a few songs from your library or some movies that you have and drag them to your iPod.
What I did was, dragged some movies on my itouch to the tv shows folder as soon as i did this everything popped back on to my screen
Sep 10, 2008 | Apple iPod touch
The 5 Rs: Reset, Retry, Restart, Reinstall, Restore
Remember these five basic suggestions if you have a problem with iPod shuffle. Try
these steps one at a time until the problem is resolved. If one of the following doesn’t
help, read on for solutions to specific problems.
â Reset iPod shuffle by turning it off, waiting five seconds, and then turning it back on
again.
â Retry with a different USB port if you cannot see iPod shuffle in iTunes.
â Restart your computer, and make sure you have the latest software updates
installed.
â Reinstall iTunes software from the latest version on the web.
â Restore iPod shuffle. See “Updating and Restoring iPod shuffle Software” on
page 26.
Jul 16, 2008 | Apple iPod shuffle Second Gen. Silver (1...
My Ipod shuffle does not work, when I switch on the ipod, I see orange light on and off..it does not show green. I charged the battery for more than 4 hours. Can anyone help ne why is this happening and...
I am not sure about the 1st generation but the 2nd generation definitely charges via the USB connection. If you don't hear the music its because there are no songs on your device. When you initially add songs, they go to the Library in iTunes, not the Shuffle. Just drag and drop your songs from the "Library" to your "Device" in iTunes and then you'll notice them get sync'd with the Shuffle.
Jan 14, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Deleting all memory at once
Ipod manuals http://www.apple.com/support/manuals/ipod/ Not sure if you have 1st or 2nd gen 1st: http://manuals.info.apple.com/en/iPod_nano_Features_Guide.pdf 2nd: http://manuals.info.apple.com/en/iPod_nano_2nd_Gen_Features_Guide.pdf These manuals suggest that when you connect to itunes, it automatically deletes all songs not in your library. Otherwise i don't see a format option unless the drive shows up in my computer and you can format it there (right click). It basically suggests that you have to use one of the manual methods on the pod or computer to delete songs. Have fun!
Aug 28, 2007 | Apple iPod nano
Apple iPod  shuffle Second Gen. Silver (1 GB) MP3 Player (MA564LL/A) Logo
105 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
