Question about Epson ELP-3500 Multimedia Projector
ELP 3500 Hi, I have an epson ELP 3500, when I plug it in the orange light illuminates indicating the projector is in sleep/standby mode. When I depress the power button I get no response, it does not turn on. I tried it on various outlets in the house, and had it working for about two weeks. Until I unplugged the projector to move it to a new location - same problem again. I even tried swithcing back to the outlet it last worked on, and no such luck. Any advice?
marsrover
  • 682 Answers
SOURCE: epson elp 7200 projector
check power supply (electricity)in wall outlet by another appliance.
--check for defective power cord-test with another one.
=apply good brand of contact cleaner over power switch.and press it many times.
--check blown power fuse and change it with same rate if it is defective.--if all above did not fix the problem pass it to service center.
Posted on Mar 18, 2008
SOURCE: Lamp is on but not no signal from projector coming out !!!
i figured it out. open it up, and make sure the ribbon cables are securely plugged in.
Posted on Apr 03, 2008
Marrie
  • 563 Answers
SOURCE: Epson ELP 5500 projectors
Hi technoteach
Will try and get my hands on a Service Manual for this model - in which you would find the circuit diagrams. This is a faulty Mainboard that is causing the problem.
Posted on May 13, 2008
SOURCE: Projector shuts off after about 45 minutes
Just a long shot, but...
I have an epson 9000i that did the same thing. Turns out that unit has a small fan (I think 60mm) right next to the power supply to keep it cool, in addition to the large fan that exhausts past the lamp. The fan runs non-stop as long as the unit is powered-up for two reasons I can think of - keep the power supply a little cooler, and the lamp a little warmer so there's not such a temp difference when it powers-up. Long story short, that fan had died. I replaced it with an aftermarket 60mm fan and it's been working fine ever since. Hope this helps.
Bob
Posted on Oct 07, 2008
erwinroyo
  • 189 Answers
SOURCE: scanner won't turn on
Try to test the power cord of the scanner (cable from scanner to outlet) using multitester if there is an electricity or if you have extra power cord test it. Maybe that's the defect. If that's not the problem it is now the scanner itself, have it for the repair man or technician.
Thanks
Posted on Nov 19, 2008
The indicator of temperature is red, the indicator of the bulb is off and the fan after 3 o 5 minutes
PowerLite 7800p Multimedia Projector - Epson
www.epson.com/cgi-bin/Store/support/supDetail.jsp?...oid...
EpsonPowerLite 7800p Multimedia Projector. Support ... Indicator Light, Status, Description... Temperature, Red, The projector is overheating, which turns the lamp off ...
PowerLite 735c Multimedia Projector - Epson
EpsonPowerLite 735c Multimedia Projector ... Indicator Light, Status, Description ...Lamp/Temperature, Red, The projector is overheating, which turns the lamp off ...
Maintenance Indicators - ManualsLib
www.manualslib.com > ... > Notevision PG-F212X > Operation manual
The warning lights (power indicator, lamp indicator and temperature warning... ... Redon. Normal (Standby). Green on. Normal (Power on). Red blinks. Abnormal ... Sharpmultimedia projector model xg-mb67x-l operation manual (71 pages).
Dec 14, 2015 | Office Equipment & Supplies
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
LP70 appears to be stuck in standby mode. The orange light illuminates immediately when the power is turned on. The bulb was just replaced.
the power supply needs to be upgraded which involves soldering a wire to the power supply then to the main board.
Jun 25, 2010 | InFocus LP70+ Multimedia Projector
Epson ELP5000 bought from surplus; plug it in and the power indicator glows orange and the lamp indicator is not lit. Opened the lamp unit and it is clearly blown. The user manual indicates that the lamp...
turn on the projector ,at the same time ,if you can hear a continuous beep beep sound (the ballast igniting the lamp)
means the lamp is fault,and other parts is working well
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color
wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Jerry
May 15, 2010 | Epson Replacement Lamp Projector Lamp For...
EPSON ELP5000 bought from surplus; plug it in and the power indicator glows orange and the lamp indicator is not lit. Opened the lamp unit and it is clearly blown. The user manual indicates that the lamp...
It is an indication that the projector is in sleep mode. Press power button and check for any changes on the led indicators. If the power turns red, it means unit is hot. check if the fan is working and if the air filter is clean or needs cleaning. If the lamp turns red it means the lamp is busted, You will experience this since lamp is clearly blown. But if both lights are red, it means that the unit is busted and will require service.
Mar 26, 2010 | Epson Replacement Lamp Projector Lamp For...
What does it mean when that blinking green light turns to orange one in lp 350?
Hi
This would be "Standby"
When you press standby, the display and audio turn off and a blank screen is displayed for 15 minutes.
You can change the amount of time the projector stays in standby mode; see “Standby Time” on page 27 for details.
The LED lights orange while the projector is in standby.
• If you press standby again within 15 minutes, the projector returns to normal operations immediately. The LED changes from orange to green.
• If you press standby again after 15 minutes, there is about a 60 second delay before the lamp turns back on. The LED flashes green while the lamp is re-lighting.
• If you don’t press standby again, the lamp turns off after 15 minutes. The LED lights orange while the projector is in standby.
The full manual can be found here:
Infocus customer support
Infocus LP350 Manual
I hope these help
Mike
Sep 18, 2009 | InFocus LP350 Multimedia Projector
Epson ELP 3000 clicking noise and all lights flashing
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
Jerry
Lampdeng Limited
Mar 26, 2009 | Epson (1023661) Projector Lamp for...
EPSON EMP 3000
There is an adjustment in the Video section for adjusting it to look square.
Aug 13, 2008 | Epson ELPSC07 for PowerLite Home 10,...
Epson ELP-3300 powers up bulb light is green but stays on stand by
Hi djSilver
Try resetting the lamp timer.
This normally solves this problem.
Apr 22, 2008 | Office Equipment & Supplies
49 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
