Question about RCA Universal Remote Control
Programing to a tv
I need to find codes for a sanyo tv The Sanyo TV I am trying to program does not accept anny of te codes.
  • 2,071 Answers
Http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): programing to a tv - clip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Aug 25, 2008
I need the code to program a sanyo tv using the one for all untiveral remote URC-2060
If you do not have the code for you Sanyo TV then you can use the remote itself to get the code. It is a bit painful as you have to count the number of blinks it makes.
Follow the steps under getting your code.
Also it would help if you provide the model number of your sanyo TV in the comments section.
How to Program your One For All remote
Aug 17, 2014 | Televison & Video
I need a code for my sanyo tv
There are only 4codes for sanyo for the 5-n1 they are: 087, 179, 219, 349. To program the remote press and hold program button until it blinks three times then put in three numbers. The red light will flash if accepted. Press power button to see if it was the right number.
Dec 06, 2013 | Universal Remote Control Televison & Video
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
https://www.mydish.com/support/remotecodes
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
https://www.directly.com/.../dish-network-my-dish-remote-needs-progra...
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
https://www.directly.com/.../dish-network-how-do-i-program-my-dish-re...
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
Jan 09, 2012 | Sanyo 42 in. LCD TV
I need the code to program my sunflwer remote with my sanyo tv
try these 014 / 032 / 045 / 075 / 120 / 121 / 122 /123 / 124 / 163 / 168 / 171 / 183 / 196 / 206 / 305 these are for all diffant sanyo tv and if your remote needs more than a 3 number code sorry can not help
Nov 28, 2009 | Sanyo Televison & Video
Need te code for programing a Sanyo TV, Philip SRU
Sanyo 0154, 0159 (manufactures codes)
hope this help you out if so please leave a thumbs up
Cheers
Little Dish Fitter
Oct 07, 2009 | Televison & Video
Need to program rca univ remote for sanyo tv & i lost the manual
Get your Sanyo TV codes and one by one program the into you RCA universal until you can turn the TV on and off. Find codes at Sanyo.com, the manual, Sat Manual, Vcr Manual etc.
Sep 19, 2009 | RCA Universal Remote Control
I need the codes for a sanyo tv to program my philips universal
please find the similiar type of the tv (must good tv) remove both tv memory ic and copy from the good tv.use memory ic copier all settle ok
Jun 06, 2009 | Sanyo DS27800 27" TV
I have a rca 311 w to program into a sanyo tv
Code For Model RCR311W
Code 1004 for Sanyo TV Code 1048 for Sanyo TV Code 1049 for Sanyo TV Code 1073 for Sanyo TV Code 1080 for Sanyo TV Code 1162 for Sanyo TV Code 1169 for Sanyo TV Code 1180 for Sanyo TV
Jun 05, 2009 | RCA RCR311B Remote Control
Sanyo tv codes
The codes listed by Sanyo for my TV won't work in my star Choice remote.
I tried 017 021 039 056 057 058 and 140 as listed by Sanyo.
Any ideas?
Dec 18, 2007 | GE JASRM24912 Remote Control
Programming a universal remote control for a tv
The code for a Sanyo TV set should be 100. Press and hold the TV button on the remote while entering the code. The light should blink 5 times if it was accepted, and then you can test to see if it worked.
Dec 07, 2007 | Televison & Video
Televison & Video Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
