Identify the ink cartridge that has run out (the ink cartridge flashes quickly at around 1-second intervals).
Replace the applicable ink cartridge and close the cover.
Press the [Resume/Cancel] button on the device to continue printing.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility using the link at the top of the page.
The ink cartridge has not been installed correctly.
Resolution:
Lift the printer cover up.
Check that the red lights on the ink cartridges are all turned on.
If no red light is activated on a particular cartridge, check that the cartridge is securely positioned and adjust if necessary.
Also make sure that the orange protective cap has been removed from the bottom of the ink cartridge.
try to reset ur printer. first off ur printer and take off the jack,just hold the grin light then plug the jack,and also hold the red light den move your fingers in the grin and red light
By analyzing your printer paper jam problem,it deffinately due to paper piece or dust particle wrapped to the the printer page roller.So check your printer keenly for any paper piece or any other obstacle disturbing printer roller and clean dust wrapped on printer roller with brush.Then turn on the printer give the page to the printer,care must be taken that page inserted is must be straight.then give the print. It definitely solves your problem.if you have any problem regarding this issue comment your problem with more information,we will glad to assist you.
If streaking is occurring only at the bottom of the page (i.e. the last area to print as the paper is fed beneath the print head), the problem may be due to improper curl of the paper. Many inkjet printers (Canon especially), rely on a slight curl of the paper so that it is "bowed" when it travels beneath the print head.
To see if this is the problem, gently roll a sheet of paper so that the print side is on the outside of the roll. When you place the paper in the feed area, it should have a very slight bow so that the center of the print side is slightly raised off the surface, while the edges are on the surface.
Also, make sure you use only OEM (Canon) cartridges. There is not a single "compatible" cartridge in the world that won't screw up your Canon print head. Take my word for it (and I DON'T work for Canon), you must use only Canon cartridges.
