Make sure you car is actually in PARK, Easy to do, Just disengage the parking brake (emergency brake) and attempt to push your car both forward and reverse to ensure your car isnt in neutral. If you cant budge the vehicle your good to go! If it rolls forward it may be in neutral or a forward gear. if it rolls backwards it may be in neutral or reverse. If it rolls both directions its in neutral. On that note if it moves at all skip to the third step (***) and make sure the transmissions shift bracket is in the park possition. Depending on your cars transmission model the parking gear is located all the way left to the farthest possition or all the way right to the farthest possition) One direction will put you in Park, the other in will put you in 1st gear, If your in 1st gear the linkage should be too far away from the shift plate to connect if your column says you are in park. DO NOT ATTEMPT TO START YOUR CAR WHILE IT IS IN A DRIVE GEAR AND THE LINKAGE IS DISCONNECTED IF YOU ARE ABLE TO START YOUR CAR IN ITS CURRENT STATE DO NOT MOVE THE TRANSMISSIONS SHIFT BRACKET UNTIL LATER IN THIS INSTRUCTIONAL!!!!!
* Floor shift automatic, the push pin lever (located inside your shifter/gear stick) may be malfunctioning. You have to pop the grip off and inspect the white plastic pin inside the shaft to see if it is damaged, also check inside the grip while you press the safety release (shift lock button) to ensure the internal slide mechanics are propperly working). Also check for anything obstructing the levers movement inside the floor housing.
** Column Shift. Make sure your pull pin lock is working properly (disengages the shift lock when you pull back the gear shift before you select a gear) if its broke theres two possible behaviors you'll experiance -1. You cant pull the gear shift back at all or -2. No effort or less than normal effot is required to pull back the gear shift. If all that checks out then you have to inspect the steering column linkage bar (you may have to remove some of the steering column housing to view it. Make sure the bar isn't bent or that its movement isnt obstructed.
***Automatic Transmission Linkage Check - Look under the kick panel located above the gas and brake pedals.........Once linkage is located under the dash (kick panel) disconnect it and try the gear shift. If the cable moves under the dash then reconnect it and move on to the next step.
Now block the wheels and climb under the car and disconnect the linkage from the transmission and have someone work the gear shift while you see if the cable is operating propperly, if the linkage moves (as it should) then try shifting the transmission back and fourth by hand while the linkage is disconnected., If the shift bracket feels stiff or is dirty clean it off with non corosive chemicals so you dont damage any seals. If the bracket operates smoother go ahead and reconnect the linkage and try shifting with the column again. Be sure to move the shift bracket back to the park position and make sure your shifter column is in park as well before you reconnect the linkage, if you dont you are sure to run into more issues.
Hope this helps you out! If all the mentioned area's above are in working order then your problem is with the car's transmission and you should take it to a speciallist.
SOURCE: Gear stick stuck
check and see if the brake lights work, if not that is the problem (poss switch at brake pedal), the park position is locked out by a small pin that is pulled back by a electric solenoid that is activated when you step on the brakes, it is called the park interlock, and is a safety feature, if the brake lights do work you will need to drop the steering column and test for pwer to the park pull solenoid I just mentioned above, check the owners manual as well on this issue.
SOURCE: 2000 chevrolet tahoe - can't put the gear stick in
It sounds to me as if the cable isnt adjusted properly. I would check with the shop that put the tranny in and see if they could check the adjustment on the cable, more than likely when they put in the new trans they didnt bother to adjust the cable for the replacement transmission
SOURCE: I have a 98 Concorde
You need to check the linkage. Under the car, the section that connects the gear shift stick to the transmission rods.
SOURCE: gear shift sticks in park on suzuki forenza 2006
You may want to check the gear lock mechanism. This is the one that prevents you from moving from park when you accidentally hit the lever. If that checks out ok, you may want to inspect the linkages of the shifter to the transmission.
SOURCE: Oldsmobile gear shift stuck in park
shifter is getting bowned up on colum or on transmission see why
http://repairhelpcenter.blogspot.in/2012/02/car-will-not-move-when-in-gear.html
transmission sticks in first gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-transmission-sticks-in.html
Transmission not engaging in first
gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-not-engaging-in-first.html
Vehicle only goes
in First gear?
http://howtobyme.blogspot.com/2011/11/chrysler-pt-cruiser-only-goes-in-first.html
Car is stuck in park
and the shift will not move?
http://howtobyme.blogspot.com/2011/08/car-is-stuck-in-park-and-shift-will-not.html
Engine will not go out of park mode?
http://technoanswers.blogspot.in/2012/02/2002-nissan-sentra-will-not-go-out-of.html
Car stuck in park?
http://technoanswers.blogspot.in/2012/02/nissan-sentra-stuck-in-park.html
Car will not come
out of Park?
http://howtobyme.blogspot.com/2011/11/car-will-not-come-out-of-park.html
Automatic
transmission will not go into high gear?
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
Car wont downshift
sometimes?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-downshift-sometimes.html
Transmission
will shift into drive?
http://schematicsdiagram.blogspot.com/2011/12/buick-park-avenuetransmission-will.html
Auto wont shift
from park?
http://schematicsdiagram.blogspot.com/2011/12/ford-taurus-wont-shift-from-park.html
Car Transmission
will not go into Park mode?
http://schematicsdiagram.blogspot.com/2011/12/car-transmission-will-no-go-into-park.html
Shift indicator
directly goes to 2nd when key is turned ON?
http://schematicsdiagram.blogspot.com/2011/12/shift-indicator-directly-goes-to-2nd.html
Third gear missing
and engine losing power?
http://schematicsdiagram.blogspot.com/2012/01/third-gear-missing-and-engine-losing.html
Vehicle has whining sound in gear?
http://technoanswers.blogspot.com/2012/01/chevrolet-silverado-has-whining-sound.html
Hard to shift gears on Manual
transmission?
http://technoanswers.blogspot.com/2012/01/hard-to-shift-gears-on-manual.html
Car hard shift at slow speeds?
http://technoanswers.blogspot.com/2012/01/car-hard-shift-at-slow-speeds.html
Automatic transmission shift lever
hard to move on cold mornings?
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
Gear shifts hard?
http://schematicsdiagram.blogspot.in/2012/02/2000-nissan-maxima-shifts-hard.html
Vehicle noticed sluggish
delayed shifts while driving?
http://schematicsdiagram.blogspot.in/2012/03/vehicle-noticed-sluggish-delayed-shifts.html
This will help.
Thanks.
gear?
Vehicle only goes
in First gear?
Car stuck in park?
Car will not come
out of Park?
Automatic
Car wont downshift
sometimes?
Transmission
Auto wont shift
from park?
Car Transmission
Shift indicator
Third gear missing
transmission?
Gear shifts hard?
This will help.
Thanks.
