Constant restart in XPsp3. unable to complete startup in normal mode, only in safe mode.
  • 300 Answers
If you havent already treied to remove it from the Add/Remove Programs I would check that first by clicking Start > Run > type
appwiz.cpl and press Enter. This will open Add/Remove programs and from there you can choose Windows XP Service Pack 3 the click remove. This should start the uninstall process. You may have to click finish to restart at the end.
If the machine starts in safe mode and you see the dialog that states that you are working in safe mode... instead of choosing yes choose no and it should start the system restore feature.
From there you will choose restore your computer to an earlier time and click Next. After that you will have a calendar with bold dates on it. These are the dates that have restore points available. Just select a date of when you know the computer was working correctly and then choose an entry on the right of th lastest time that you know it worked. It is usually a good idea to choose from ones that say "System checkpoint". After you select it click Next. It should bring up a screen verifying that it the point that you want to use. If so, click Next and your machine will restart and be brough back to the state that it was in accoring to the restore point you choose.
Here is a link from Microsoft that will also explain some other processes that you can use.
http://support.microsoft.com/kb/950249
Thanks
Posted on Jul 21, 2008
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
WHERE DO I FIND SAFE MODE IN LAPTOP OF HP 6735s
Enter Safe Mode at startup Follow the steps below to start Windows Vista in Safe Mode.
  1. Remove all CDs and DVDs from the computer.
  2. Restart the computer.
  3. At the first screen on restart, before the HP or Windows logo appears, press the f8 key repeatedly.
  4. When prompted, select the Safe Mode with Networking option.
  5. Log onto the computer with a user account that has administrator rights.
Enter Safe Mode when PC is operating If the computer can boot into the Vista operating system, follow the steps below to enter Safe Mode.
  1. Click Start , type msconfig in the search field, and then press the enter to open the System Configuration window.
  2. On the General tab of the System Configuration window, select Diagnostic startup .
  3. On the Boot tab, select Safe boot and click OK .
  4. When prompted, click Restart to start the computer in Safe Mode. If the computer does not restart automatically, press the Power button to turn the power on.
  5. On the Tools tab of the System Configuration window, select and launch the desired diagnostic tool.
The computer is now operating in Safe Mode. Exit the Safe Mode After completing the required troubleshooting and repair, follow the steps below to exit Safe Mode and return to normal operation.
  1. Click Start , type msconfig in the search field, and then press enter to open the System Configuration window.
  2. On the General tab of the System Configuration window, select Normal startup and click OK .
The computer restarts in the normal mode.
May 18, 2012 | HP Compaq 6735s Notebook
I deleted a virus from my computer. when finished it asked for me to restart computer, upon restart, the computer would shut down and not logon to windows desktop
Hi There,
It seems like you're having boot issues after the virus removal from your computer. I have encountered this same scenario before and what I did was to boot to safe mode and clear all startup items. Here's how:
Step 1 - How to go to safe mode :
  • 1. Shut down your computer
  • 2. Disconnect all USB devices,except your mouse and keyboard
  • 3. Restart computer and starttapping on "F8" key repeatedly until it boots to a different screen
  • 4. Wait for the initial logsto complete and choose "Safe mode only" when given the options.
Step 2 - How to clean up startup items :
  • 1. Click on start and choose"Run"
  • 2. Type "msconfig" then pressenter key
  • 3. Click on "Startup" tab
  • 4. Click "Disable all" touncheck all startup items
  • 5. Restart your computer
If same problems persist after completing the above steps, then there is a need to completely reinstall the Operating system of your computer using the CD that came with it.
Let me know if you need further assistance, I'll be glad to help.
Thank you for using FixYa.
Feb 25, 2011 | Compaq Computers & Internet
How do you put windows into safe mode?
Power on or Restart your computer, keep tapping F8 on the keyboard while it boots up. After few seconds, you'll be taken to the "Advanced Boot Options" with "Safe Mode" in the lists. Use the Up-Down arrow keys to highlight the "Safe Mode" and press enter on the keyboard to confirm the selected boot options. Black Screen with white texts will be displayed on the display, wait for few seconds until you see the windows logon Screen. You'll also see a confirmation message box asking you to confirm to boot into Safe Mode, click "yes" or "Ok" and proceed forward. There now you are in the Safe Mode.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 26, 2010 | Computers & Internet
In normal mode PC hangs due to spies or viruses. Unable to start the system in safe mode or safe ode in networking mode always it restarts if tried with safe mode. www.kaspersky.com, www.grisoft.com,...
When you are restarting the PC - Press F8 Key till you get the options to Boot
Choose Last Known Good Configuration and load windows
Once you have logged into your PC - try to MSCONFIG
If that does not work, Open Task Manager ( CTRL + ALT + DEL ) key and Click on Services Tab. Click the Services Button below. and it should let you open SERVICES.MSC
Disable all the Antivirus software installed ( double click on the software name and under Startup type - choose Disable )
Also Disable the Windows Installer
Try to access or Download some Virus program to Run or Clean.
Jun 24, 2010 | HP Pavilion a1610n PC Desktop
Windows XP won't start
Try starting it in SAFE MODE. Hit F8 slowly repatedly as it starts before windows screen comes on.
When you get into safe mode, drivers that may be failing are not started. Then you can look at the boot log to see what failed and remove that item so you cana restart normally.
You may have a virus.
IF you have created a restore point, restore while you are in SAFE MODE.
Oct 26, 2009 | Computers & Internet
Wont start up completly
there is the single user start-up, which you were thinking of. There is also a safe-boot for macs.
To start up into Safe Mode (to Safe Boot), do this:
1. Be sure the computer is shut down.
2. Press the power button.
3. Immediately after you hear the startup tone, hold the Shift key. The Shift key should be held as soon as possible after the startup tone but not before.
4. Release the Shift key when you see the gray Apple icon and the progress indicator (looks like a spinning gear).
During startup in Mac OS X 10.4 or later, you will see "Safe Boot" on the login window, which appears even if you normally log in automatically.
During startup in Mac OS X 10.2 through 10.3.9, you will see "Safe Boot" on the Mac OS X startup screen.
To leave Safe Mode in any version of Mac OS X, restart the computer normally, without holding any keys during startup.
Jun 24, 2009 | Apple iMac G5 Desktop
Cant acess safe mode in windows xp, just cycles startup screens
Here are some steps to use MSCONFIG to force your computer into SAFE MODE
  1. Click on Start and then Run.
  2. In the text box in the Run window, type msconfig and click OK. This will open the System Configuration Utility program.
    Note: Do not make changes in the System Configuration Utility other than those outlined here to avoid causing serious system issues. This utility controls a number of startup activities other than those involved with Safe Mode.
  3. Click on the BOOT.INI tab located at the top of the System Configuration Utility window.
  4. Check the checkbox next to /SAFEBOOT and click OK.
  5. You will then be prompted to either Restart, which will restart the PC immediately, or Exit Without Restart, which will close the window and allow you to restart the PC manually.
  6. After the restart, the PC will automatically boot into Windows XP Safe Mode.
    Note: Windows XP will continue to boot into Safe Mode until the System Configuration Utility is configured to again boot normally.
  7. When your work in Safe Mode is complete, click on Start and then Run. Type msconfig in the text box and click OK.
    This will again open the System Configuration Utility program.
  8. Choose the Normal Startup radio button and click OK.
  9. You will then be prompted to either Restart, which will restart the PC immediately, or Exit Without Restart, which will close the window and allow you to restart the PC manually.
  10. After the restart, the PC will boot into Windows XP normally and will continue to do so.
    These instructions were written by About.com
    http://pcsupport.about.com/od/tipstricks/ht/smsysconfig.htm
May 24, 2009 | Microsoft Windows XP Media Center Edition...
Will not display output from Computer
Probably the video resolution or the monitor Refresh Rate (eg: 50/60/75 Hertz) is set too high in the operating system, which over-drives the monitor electronics and it is unable to display anything.
If you restart the computer manually (hold in the power button for 5 seconds, the computer will shut off, turn it back on again) you will see the normal BIOS and Windows startup display on the monitor, but then as Windows completes it's startup it returns to the error message you see.
To fix this, restart the computer manually and start the computer in Safe Mode. To do this press F8 just before the computer starts to load Windows, and choose Safe Mode. Once in Safe Mode, you should see the monitor working correctly.
Now restart the computer in Normal Mode and everything should be fine.
Dec 23, 2008 | Westinghouse LCM-19v1 Monitor
My computer completely rebooted and i cant get to the log in, what do i put in to get to the main frame
Try holding down the shift key after you hear the startup chime. This should start the Mac in Safe Mode and force some cleanup utilities to run. (Note that startup takes a bit longer than usual in Safe Mode.)
The login screen should show the words Safe Mode in red when startup is done. You can then restart and the Mac should boot normally.
Nov 24, 2008 | Apple iMac G4 Desktop
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
