Hi.
This happens when the descale has not been done for some times.
Restart the descaling. This time keep a container with a couple of pints of water ready near to the machine.
While descaling is on, keep refilling the machine water container, so that the De-scale does not end before being complete.
You may need to refill the container two or three times before Descale disappears from display.
Regards.
Ginko.
Hi.
De-scaling instructions for B-70 should be the same as the B100 instructions in this link (please click here).
You can use vinegar, descaling solution or citric acid for the first part of descale. If more water is required you can use just water.
If you have never done de-scale before you can wait for your daughter and ask some assistance. Although the operation is not too difficult, it may still result tricky if you have never done it.
Vinegar, may leave a quite unpleasant smell for some times. I suggest using citric acid in granules mixed with water. Something like this will do: Citric Acid 100% Pure - 4 oz.
Regards.
Ginko.
I wanted to add that you can try resetting the machine by disconnecting power cord for two minutes (power reset). If the display Descale message will clear you will be able to use the machine.
I still suggest doing a complete descale as soon as possible. If descale message stays on display it means that the machine did not complete descale.
Please read also my previous message, it includes descaling instructions.
You are welcome, all the best.
Re: This situation is what prompted us to descale to begin with...what could be causing this?
If machine prompted descale, then descale was not complete. Disconnect again, this time wait fifteen or twenty minutes (just in case, but 5 will be OK). If problem was electronic settings, the machine will reset (this machine does not have memory battery).
If problem, like I think, is blockage caused by the descale process, you need to do descale again, and this time do the complete procedure.
Ginko---My daughter started the descaling process last time....she's back at college...not sure how to start it again.
very helpful...thank you.
Ginko--
Good advice...disconnected and descale is no longer on LCD, but the machine only fills half a cup eventho a full cup was requested. This situation is what prompted us to descale to begin with...what could be causing this?
