Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
The dishwasher does not drain water
My Frigidaire diswasher worked perfectly for almost two years and a day ago during the washing cycle it stopped draining waste water. I tried to turn it again for wash cycle but I hear only a buzzing noise coming from it. Is the pump that doesn't turn on or is there other problem? Please help.
Chris
  • dennislapris Jan 29, 2009
    I have the same issue with my Frigidaire dishwasher, but it is only about 14 weeks since installed. The same whirring sound from the pump but no water is being pushed out from the tub. I followed on-line advise for trouble shooting hoping it was as simple as the hose being clogged etc. but all hoses were clean and unobstructed. The garbage disposal as well was clear and functioning properly. Last resort - wait a week to get a repair person to come out and look at it!!
  • Anonymous Mar 25, 2014
    Worked perfect for 7 years. Now it stopped getting hot during the wash cycle
My dishwasher's problem was that something got stuck in the drain at the bottom of the dishwasher pan. I took that apart cleaned it and it worked. Apparently this problem is inherent to this model and will probably be recurring. Be prepared!
Posted on Aug 27, 2008
I had the same problem after a year of use. All the cycle sounded good except for the drain. I disconnected the drain hose with all turned off and only a small amount of water came out ( the inside pan was full ) I then stuck it to my mouth ( gross ) and nothing but back pressure. Another great heave and POW a wad of grease came out. In short by wife poured some fresh stock down the drain which backed into the drain pipe and cooled. Done.
Posted on Aug 26, 2008
Water wont drain from diswasher
Probably the relay that switches the water flow between "recirculate/clean and exhaust" cycles. You can confirm by opening the bottom panel and looking at the relay arm. When switching from "washing" to emptying cycle, you will see the relay lever try to switch the flow of the water to the exhaust cycle. Alternately, remove the exhaust hose from the garbage disposal and place it in a bucket or bowl. After the water stops coming out, blow into the end of the hose to see if any food is blocking the hose (sometimes someone operates the disposal while the dishwasher is running and forces food into the exhaust hose.
Mar 10, 2014 | Frigidaire 24 in. PLD2850 Built-in...
Bosch Diswasher
Remove the drain hose and check if you have any residual into it. After 11 years your appliance may need a thourought cleaning.
Check also if the pump has enough pressure.
Apr 22, 2008 | Dishwashers
MY FRIGIDAIRE DISHWASHER WILL NOT DRAIN. MOTOR ONLY HUMS DURING DRAIN CYCLE. OTHER THAN DRAINING IT SEEMS TO WORK FINE. DAY IT QUITE WORKING SINK BACKED UP AND WOULD NOT DRAIN
if there is still water in the dishwasher take the drain hose off from under the sink and use a large pot or mop bucket and but the unit into a drain mode usually by cancelling the wash cycle if the unit still does not drain.Then use a wet dry shop vac and attach it to the end of the drain hose to remove the water
after the water is gone check the drain pump for any kind of obstructions you may need to replace the drain pump
Jun 06, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
Maytag DWU6602AAE. My Maytag dishwasher (14 years
SOUNDS LIKE A TIMER PROBLEM. YOU MAY WANT TO PRICE A REPLACEMENT TIMER. AND PRICE OUT NEW DISHWASHERS. GOOD LUCK!
Feb 25, 2010 | Dishwashers
Frigidaire fdb1050rem2 dishwasher will not drain during was cycle
Checked water temperature at water heater. It was at 110 degrees. Turned water heater up to 125 degrees. Dishwasher works perfectly now.
Mar 30, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
I have a 24" Bosch diswasher - water does not drain
I have the same problem with my she58 water does not drain. only 4 months old and repair man replace 3 diff parts ...same thing happen. Bosch send another company to repair..replace parts by parts. not working....almost 5 months now I don't have dishwasher...i have to call almost everyday to Bosch..to fight for it....couple of days ago customer support told me with in 10 days somebody would call me for the replacement....i have to wait and be back if i don't have heart attack..to tell if they really would replace...gemtx
Jul 26, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Dishasher does not drain
If it gravity drains, but the pump does not push out the water.......replace the drain pump. I just repaired an 8-year-old  Frigidaire dishwasher with this very problem, and although it sounded like the pump was operating, it was not....it was just vibrating. I replaced the drain pump and it now works perfectly. I am a service tech with 38 years experience.
Jun 21, 2007 | Frigidaire 24 in. FDB635RF Built-in...
The dishwasher in my kitchen doesn't seem to drain and it seems pump is not working
I INSTALLED A NEW GARBAGE DISPOSER AND THEN FOUND THAT THE DISHWASHER WOULD NOT DRAIN. READ THAT THERE WAS A SEAL IN THE NOZZLE OF THE GARBAGE DISPOSER THAT HAS TO BE REMOVED IF IT IS ATTACHED TO A DISHWASHER. I DISCONNECTED THE HOSE,WITHOUT REMOVING THE GARBAGE DISPOSER, PLACED A SCREWDRIVER IN THE HOLE AND HIT IT WITH A HAMMER AND KNOCKED IT OUT. REPLACED THE HOSE AND TIGHTENED THE RING AROUND THE HOSE. TURNED THE DISWASHER TO DRAIN AND IT WORKED PERFECTLY. MY MISTAKE FOR NOT READING THE DIRECTIONS THOROUGHLY. ALL IS WORKING WELL; HOPE THE SAME FOR YOU.
Sep 26, 2006 | Frigidaire 24 in. FDB510LC Free-standing...
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
362 people viewed this question
Top Frigidaire Dishwashers Experts
Electrolux
Electrolux
Mike Cairns
Mike Cairns
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
