Question about HP Officejet 7210 All-In-One InkJet Printer
Frequent paper jams
Two problems 1. will only fax like 3 pages and then it will just send the other pages through and not fax them and do a fax fail.
2. when we try to print or get a confirmation page it eats up the paper. we have tried several types of paper and does it to it all. it use to work ok but not now.
    Guru:
  • 1,049 Answers
Sounds like the rollers aren't picking up the paper.
  1. Get yourself some "Rubber Renew" or similar product and a pack of cotton swabs.
  2. Open the panel in the back or remove the duplexer if that applies, and open the door in the front.
  3. Recondition the rollers in the back, above the feeder tray, etc. with the rubber renew or cleaner...but use it sparingly because it actually eats away part of the rubber to make them sticky again instead of smooth.
  4. Try the printer.
If that doesn't work, make sure that there is no paper or dirt obstructing the sensors above the feeder tray or around the back of the printer. These should look like small plastic levers.
Posted on Jul 24, 2008
I have a Richo 2035 black and white copier. Recently the copier has begun to paper jam...and its done frequent every time i clear the jam..it runs for a while maybe 10 copies and jams again. What can i do?
Not surprising - it may need some service. It is 7-8 years old. There are a few areas that could be affecting output. Most likely you need to replace the rollers that pick the paper out of the tray (3/drawer) -especially if the problem occurs with 1 specific tray. Try using another tray to isolate the problem
Jul 10, 2011 | Office Equipment & Supplies
My fax machine has an error code "Check Paper", and I cannot clear it and my machine will not work.
Solution :
1. Cheak your backside door and cheak there can be found some broken paper.
2. Poner can be the problem for ......
3. Heat paper broken or the roller jam. if not solve send me ur model no.
Jul 31, 2010 | Brother IntelliFAX 770 Plain Paper Thermal...
HP 1050 Fax Machine will not send out faxes. It sends the first page then prints out paper saying paper jam, but we have not paper jammed in the machine.
Sorry but still do not have it fixed...i printed off the manual for this fax but our problem is not on the trouble shooting list. But i'd think you would be able to tell how to fix it without charging for the sollution.
Oct 20, 2009 | HP 1050 Plain Paper Inkjet Fax
It says that our memory is full. How do you delete the memory?
There are only two things that fill up memory. Out-going faxes that did not send and incoming faxes that could not be printed out.
The first scenario is two fold.
#1 If the phone line has been disconnected in any way the unit will try to send a few times ( most units are set for 3 attempts before failing but this is generally an adjustable setting).
#2 Most fax machines have a setting that will delete files that failed to send automatically. Some operators choose to shut off this auto delete function and this causes unsent items to stay in memory forever.
Incoming faxes will stay in memory until they successfully print out. Some of the causes are:
A paper jam, no paper supply and toner supply or a spent drum unit. If for any reason a recieved document can't print out it remains in memory unitl the problem is solved. Some units will loose that page data if the power is shut off for 12 to 24 hours. ( this is highly dependent on the model/brand).
So break out the owners manual and read up your user settings to cure the first scenario!
Jul 17, 2009 | Brother Office Equipment & Supplies
Double sided copying
http://www.brother-usa.com/ModelDocuments/Consumer/Software%20Users%20Manual/SUM_DCP_7030_7040_MFC_7340_7345N_7440N_7840W_EN_1650.PDF
here is the manual p4 and p16 discuss the topic:
Duplex printing 1
The supplied printer driver supports duplex printing.
Guidelines for printing on both sides of the paper 1
�� If the paper is thin, it may wrinkle.
�� If paper is curled, turn over the stack, straighten it and then put it back in the paper tray or the Manual Feed
Slot.
�� If the paper is not feeding properly, it may be curled. Remove the paper, straighten it and turn over the
stack.
�� When you use the manual duplex function, it is possible that there may be paper jams or poor print quality.
If there is a paper jam, see Paper jams in the User’s Guide. If you have a print quality problem, see
Improving the print quality in the User’s Guide.
Manual duplex printing 1
The machine prints all the even-numbered pages on one side of the paper first. Then, the Windows® driver
instructs you (with a pop-up message) to reinsert the paper. Before reinserting the paper, straighten it well,
or you may get a paper jam. Very thin or thick paper is not recommended.
Simultaneous scanning, printing and faxing 1
Your machine can print from your computer while sending or receiving a fax in memory, or while scanning a
document into the computer. Fax sending will not be stopped during PC printing. However, when the machine
is copying or receiving a fax on paper, it pauses the PC printing operation, and then continues printing when
copying or fax receiving has finished.
�� Manual Duplex
Check Manual Duplex. In this mode, the machine prints all the even numbered pages first. Then the
printer driver stops and shows the instructions required to re-install the paper. When you click OK the odd
numbered pages are printed. There are six types of manual duplex binding directions available for each
orientation.
�� Booklet Printing
When you want to print a booklet, use this function. To make the booklet, fold the printed pages down the
middle.
�� Binding Offset
If you check the Binding Offset option, you can also specify the offset for binding in inches or millimeters
May 14, 2009 | Brother MFC-7440N Laser Printer
1 get 3 fuzzy lines on page
If you're getting frequent paper jams, it's usually caused by the feeder motor assembly failing. When the paper is pulled through the printer, if the assembly is failing, it causes the paper to jam and can effect how things are printed. (Sometimes it will go to fast and things will get blurred, sometimes it'll go to slow and text overlaps)
If that sounds like the problem, it's cheaper to replace the printer (can be bought for $50) the it is to repair it ($25 for the motor, $45 for labor to install the motor)
Aug 28, 2008 | Samsung ML 2010 Laser Printer
Paper jams continue to occur on brother fax 2820
Depends on the location of the jam is. Feed wheels need cleaning, clean with windex. or and most likely you have a bad drum unit,
Jul 28, 2008 | Brother IntelliFax-2820 Laser Fax
Paper jamming in fax
look for a piece of paper in the paper path. clean all paper feed rollers
Jun 11, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Machine won't draw the paper in to send the fax
Technically, your machine is jammed. The paper is jamming as it exits the feed area, and enters the machine. Not being specifically familiar with that model, but rather based on experience with other simular machines with like problems, I would say you should look for 3 possible causes... Most machines have, shortly into the paper path, and generally in the area you're indicating, some sort of sensor switch, whether it be photo-electric, or a mechanically activated toggle, that senses and registers the lead edge of the paper so the machine knows it did feed. This switch could be knocked out of place, or simply dirty, and not sensing the lead edge of the paper within a certain period of time after the machine registers the feed had been actuated. A second possible cause would be (and you may be able to visually verify this) is that usually, in these types of machines, there is some sort of pressure or "retard" pad/roller in conjunction with the feed roller. If this isn't working right, the machine may be feeding more than one sheet at a time, and becoming jammed in the paper path path area due to "thickness". A third possible issue could be an unremoved scrap of paper from a previous jam (or a staple/paperclip/piece of rubber-band/or any other foriegn object, as I've seen them all) still remaining in a thin and obscure position of the paper path blocking the paper's progress to the afformentioned switch. Those are the most likely, but probably not the only possible, causes of the problem you are exoeriencing.
Jan 07, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
I can neither send or receive faxes
hi 003 - Recording paper jammed when feeding from the 3rd cassette. Remove the jammed paper. (1) Open the Printer Cover. (2) Remove the jammed paper. (3) Slide out the Paper Cassette. (4) Remove the jammed or wrinkled paper and reload the recording paper into the paper cassette. Caution: Make sure that the paper is set under the clips of the Paper Cassette. You can load about 500 sheets with standard weight paper (20 lb. or 75 g/m2). good luck
Feb 23, 2006 | Panasonic Panafax UF-885 Plain Paper Laser...
HP Officejet 7210 All-In-One InkJet Printer Logo
73 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
