Question about ASUS A7S333 Motherboard
Asus a7s333 motherboard
I need a wiring diagram for this board. I change cases and it has front usb mic speaker, but I can't even get anything to light up except for the green light inside the computer.
    President:
  • 2,692 Answers
SPEAKER WARNING
Posted on Aug 25, 2008
Hello. When I plug my headphone with mic into the front panel jacks, it does not work. Now if I disconnect my speakers and plug it in the back jacks, it will work. However, the front joacks are there for...
Open up your case.
You should see cables running from the front panel to the motherboard. On the motherboard you will see a multi-pin connector. What is your exact ASUS motherboard model? Here's a generic ASUS one. You will see this on the motherboard where the front panel connects to the board. A bunch of pins will terminate here.
Notice the pin labelled MIC. You will see GND etched on the motherboard. Use this to orient yourself. The Mic one is just below the GND pin. Connect it here. Notice the entire top row is devoted to FP_Audio or Front panel Audio. There are other places to connect it (e.g., if you just want stereo sound, there's a left and right FP_R and FP_L).
Move the mic connector over to the Mic pin if there is one. If not, you can get a cable at your local computer supply shop. As you can tell from the others, they are very basic wires with simple terminals.
Sep 03, 2010 | ASUS Computers & Internet
I HAVE A7S333 ASUS BOARD WITH DDR 1 1.50GB KVR226 AND AGP NVIDIA GEEFORCE FX5500 AND I PLAY NEED FOR SPEED MY PC CLOSE THE GAME WHILE PLAYING SOMETIMES RESTART EVEN I UPGRADE MEMORY
there are many things that could be causing this problem 1 dirty cooling fan on the cpu 2 the cpu is failing 3 a cap/s are failing that is a old board so its hard to tell
Mar 05, 2010 | ASUS A7S333 Motherboard
A7s333 motherboard with 3 dimm ram slots 2 x 1GB pc2700
That board type does not show on the ASUS web site. I think that your problem may be incompatibility of the RAM with the board specs. Placing faster RAM on the board will not make it go faster.
Oct 24, 2009 | ASUS A7S333 Motherboard
How do I attach the front USB, speaker and mic of the case to MB?
Follow that arrows on the pictures. Plug the USB Front Panel Cable.
Aug 06, 2009 | Intel Motherboard
Emachine t1840 wiring diagram power switch wire to mother board ?
Because there are so many different case and motherboard combinations sometimes it can be difficult following the instructions for connecting the front panel, USB header and audio header.
Below is a few generic guide that should stop some of the confusion with the labels on the wires.
Front Panel Audio
***Please note this is a generic wiring guide and we can not guarantee it will work with every motherboard. Please check your motherboard manual first. Wiring the headers wrong can cause damage to the motherboard and case, this damage is not covered by the warranty***
another handy USB wiring guide can be found here http://www.directron.com/installusb.html
this maybe easier to follow
FRONT PANEL AUDIO
2________10
__
1________9
Pin Wire
1) Mic In
2) GND (ground) or if 2xGND available, it’s the GND for the headphones, NOT the Mic
3) Mic BIAS
4) n/c
5) Speaker Right Out
6) Speaker Right Return
7) n/c
8) no pin (n/c)
9) Speaker Left Out
10) Speaker Left Return
n/c = not connected
USB (F_USB1 and also F_USB2)
2________10
 x
1________9
Top row of pins
2 = USB port 2 : VCC/Power/+5V
4 = USB port 2 : Data -/D-
6 = USB port 2 : Data +/D+
8 = USB port 2 : Ground/GND
10 = USB port 2 : pin present, but not connected to anything.
Bottom row of pins
1 = USB port 1 : VCC/Power/+5V
3 = USB port 1 : Data -/D-
5 = USB port 1 : Data +/D+
7 = USB port 1 : Ground/GND
9 = USB port 1 : no pin present
Front Panel Connector (FP1)
1 2
x 
9 10
1 = no pin present
3 & 5 = Power Switch
7 & 9 = Power LED (light)
2 = pin present, but not connected to anything.
4 & 6 = Reset Switch
8 = 10 = Hard Drive LED (light)
Jul 30, 2009 | Computers & Internet
I have a ASUS A7S333 Motherboards and need a hookup drawing.
Hi there, if you have the use of a magnifying glass and a good torch look at the corner of the motherboard opposite the pci slots and you should be able to see where the plugs go,as they are all marked with two letters as follows: hdd led,power sw,reset sw,power led and speaker let me know if this helps.
Feb 20, 2009 | ASUS A7S333 Motherboard
Wirring for a mother board
For information like this :-
Go to the manufacturers WEB site to download the documentation/manual for your model motherboard.
If it is ASUS motherboard try www.asus.com
Dec 03, 2008 | ASUS A7S333 Motherboard
Case connector problem
we would need to know the motherboard you have. most i've worked on have a 7 or 8 pin connector near the bottom of the motherboard.... next to the pci slots. if that front devices uses a modular plug it usually has a blank pin slot so you cannot hook it up to say a usb port.
Get out your magnafying glass and a light... the connectors are often labeled right on the board.
Robert
Please rate this solution.. thanks
Sep 08, 2008 | ASUS A8V Motherboard
Pluging in extra usb ports/Mic and headphone jacks from the tower
Answer me this. You're case is an Antec tower? The motherboard is the Asus P4P800 SE ? Is this correct?
If you have you're manual you can see what goes where on the board for front panel connector page. 2-31. (This diagram shows you how to connect the front mic & speaker).
To connect the Antec's front USB ports plug the case USB front connectors onto USB56 & USB78 shown on page. 2-30. Most case wires are already set within their USB connectors & the Antec's front USB connector should fit right on the mother board's pin's. If you need you're user manual, download from Asus by clicking on this link. http://support.asus.com/download/download.aspx?modelname=P4P800%20SE&SLanguage=en-us
Good Luck!
Mike
May 19, 2008 | ASUS P4P800SE Motherboard
ASUS A7S333 Motherboard Logo
190 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
