I can't look up your wiring diagram because I don't know model year?
On some makes and models, the lower brake lites are wired through the multifunction switch. Your turn and stop use the same bulb filament, just not at the same time. On a left turn, the left turn signal works, but the brake lite on the left doesn't. Now, the brake lamp on the right does work. The high mount brake lite also will work. The highmount brake lite is usually wired differently than the lower brake lites.
W/o being able to look at wiring diagram, I don't know if my info is applicable on your vehicle? I need model year.
SOURCE: right blinker does not blink
With the vehicle In Park and the ignition on, swith the R/S signal on. Now , gwt out of the car and walk to back of car and inspect the R?R signal light . OK ? Now, do the same to the R?F signal light. One of them are not going to working correctly. Replace the defective bulb, or socket
SOURCE: No turn signals or emergency blinkers
I had the same problem twice before. Solved it the same way both times. In my case it was the Hazard switch at the top of the steering column. It was stuck. I knew it was that because the signal lights had been functioning perfectly until I parked my car alongside the road with the hazard lights on to do some nighttime fishing and sip a little white lightnin'. (just kiddin' about the white lightnin')
When I got back in my car to go, I turned off the hazard lights but I had no turn signal lights! So I kept pushing that hazard button up and down for about 30 times with my left turn signal arm down until it started working again. So after having this happen to me twice, I learned a valuable lesson: Don't ever use hazard signals in this car.
SOURCE: Blinkers stopped working
I have a 1994 F150 and the blinkers and E Flashers were out. I bought some flashers from NAPA and put them in with no effect. I noticed my E Flashers were still on from before when I was trying to switch them on. Turned the E flasher switch to the off positiion and the trun signals with the new Flasher are working. I thought I had another flasher spot around the back of the fuse box but didn't have time to look at it yet, so my E Flashers are still not working.
My turn signals won't work with the E flasher on. ??? Hopefully just that, the Flasher around the back.
SOURCE: 1995 chevy silverado z71 no power to right tail light
check fuse.if good you got grounding problems or faulty turn signal switch.
