Question about Loewe Articos 55 55" Rear Projection Television
Tv turning off by itself
About every 10 to 15 minutes the tv turns off by itself, forcing someone to turn it back on with the remote
THE FILTERS IN THE BACK HAVE TO BE VACUUMED SO THAT THE TV DOESN'T OVERHEAT. THERE ARE 2 OF THEM IN THE BACK OF THE SET. USE THE VACUUM CLEANER HOSE WITH THE BRUSH ATTACHMENT SO NOTHING GETS DAMAGED.
Posted on Jul 22, 2008
I have a Samsung Plasma PN63A650 that has worked 4 8 years, until today. I turned it on, stays on for 14 seconds, then turns off for 8 seconds. Would not respond to remote commands either
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. ....Samsung E6030 led tv hv blinkin red light issue ... capacitors are looking good ...
Help PLEASE! Samsung Plasma Turning On/Off Repeatedly.
michiganstate.247sports.com > Topics
247Sports.comMy Samsung Plasma HDTV (approx 3.5years old) has some issues as of late. When Iturn the tv on, invariably, it starts to turn off and back on repeatedly.
Samsung Smart TV turning off - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have a Samsung plasma 60 inch model number PN60E6500EFXZA TV. It began to turn itself off every 5 minutes, for the past few days. I was able to factory ... Samsung TV Keeps turning off and on.
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
Samsung Plasma TV turns off by itself
Jun 22, 2011
My Samsung 50 in PN50B650 turns off by itself then on again ...
Apr 30, 2010
More results from www.cnet.com
Jan 13, 2016 | Samsung Televison & Video
What's the matter with my Mitsubishi Big Screen Tv Model VS-5041?
just re-read the trouble-shooting section of your owners manual and check the setup on your remote
May 26, 2013 | Mitsubishi VS-5043 50" Rear Projection...
TV TURNS ITSELF BACK ON AFTER BEING TURNED OFF
The most common thing is malfunction in your remote control. Try moving the remote control to another closed room, and see if it still does it. If it does... well, I know how to setup a TV to turn itself off after a period of time you set, but how to turn it on? no.
Also something, might be stupid, but I'd tell it anyways, is that someone is fooling you by ór using the remote control, ór having another remote control, and turning it on all the time.
And another thing. By "off", do you mean standby? or actually turned off by pressing the button? Because this is only if it is turned off with the remote control. If it is explicitly turned off by the button, then it might be a malfunction on your tv, meaning you could call the support of the company that makes these tv's, and if it is actually a malfunction, you could get a new tv for free, if your warranty hasn't outdated yet.
That's all I can think of, I hope it helps.
May 04, 2010 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Goodmand 42'' TV turns itself off
Check to see it your TV has a timer and it was accidentally touched to activate. Good luck.
Jul 04, 2009 | Televison & Video
It turns itself on and off repeatedly
Try this:
Unplug the tv let sit for a minute while you replace the batteries in the remote and cover the IR remote sensor on the front of the TV. Cover it with a piece of black tape or a piece of aluminum foil.
Plug the tv back in and turn on.
If it no longer turns on and off by itself then you have IR interference from some other remote operated device in the room.
If it does continue to turn on and off with the IR sensor covered then it is the internal wiring/processors and will need servicing.
May 12, 2009 | Sanyo DS27510 27" TV
Power turn off after 45 minutes to 1 hour used
Check the "Sleep Timer" settings. If set to 45 minutes then TV would automatically turn itself off 45 minutes from being turned on. The variance in the "on" times is due to the TV turning itself off after not getting a signal from the remote for fifteen minutes.
Good luck,
Techjoel
May 09, 2009 | Sony KDS-60A2000 60" HDTV
Tv turns on by itself
Hey Bubba,
If your TV is turning on by itself at about the same time each day you may have a timer activated, turn it it off, the TV's micro might need too be reset. To reset unplug your TV from the a/c outlet for at least 5 minutes.
Jun 05, 2008 | RCA P52926 52" Rear Projection Television
TV Problem
SANYO MIGHT HELP YOU BUT YOU NEED TO CALL IMMEDIATELY BEFORE MORE DAYS GO ON..
Feb 21, 2008 | Televison & Video
Turn off
this happens to my tv as well it simply will just shut off and turn itself back on and then shut itself off every 2 - 3 minutes...can someone help??
May 24, 2007 | Polaroid FLM-2011 Television
Loewe Articos 55 55" Rear Projection Television Logo
228 people viewed this question
Top Loewe Televison & Video Experts
Josh Whitehead
Josh Whitehead
isaac johny
isaac johny
Are you a Loewe Televison and Video Expert? Answer questions, earn points and help others
