Question about Janome MyLock 634D Mechanical Sewing Machine
I AM GETTING LOOSE STICHES AND AND HAVE TRIED ADJUSTING AS PER MANUAL. I have a Janome 8002D and nothing i do works eg. tightening tension for the loer looper thread and left needle thread in fact i have tightening all the dials to the last setting 9! but nothing works the stich is still loose
Sears model loose stiching
Posted on Jul 31, 2008
8002D won't stitch
If you are using the correct needle and it is brand new but still not stitching, then it very possibly is out of time.
Sep 05, 2017 | Janome Sewing Machines
I need threading instructions for Lumina 8002D
According to this, the machine is a rebranded Janome.
Lumina Aldi Overlocker
So, all you need to do is find a manual for the Janome 8002D.
Search for:
Make Model manual
Mar 28, 2017 | Sewing Machines
Hi. I just bought this machine and I am having trouble with my bottom stiches. I have tried every remedie but the stiches is too loose
Read this hope it helps
http://www.threadsmagazine.com/item/4302/understanding-thread-tension/page/all
May 19, 2016 | Sewing Machines
Singer 522
Hi . try adjusting the tension screw on the bobbin case on the thread tension leaf . tighten it slightly just enough that the thread needs needs a little bit of nudging to come out . do the same for the thread coming through the needle . this should help .
Sep 12, 2013 | Sewing Machines
The top stich is loose on my Janome Harmony 8100, I have cleaned and changed bobbins, but nothing seems to help.
Ok, Let's understand exactly what is going on. You said. "the top stitch is loose." So that we are clear....do you mean that you are getting loops on top of the seam? Or do you mean that you are getting wiggly stitches on top and small loops on the bottom of the seam? It's important to know... Because loops underneath means the top tension isn't right. Maybe you didn't thread with the presser foot in the UP position... or your tension is dialed too low.
Now, if you are getting loops on top of the seam... that means the top tension is too tight. Loosen the top tension. Make sure your bobbin is inserted correctly. If loosening top tension isn't enough, you may have to tighten the tension screw on the bobbin case/ or bobbin carrier.
Feb 25, 2013 | Janome Memory Craft 9000 Computerized...
Stitching is too loose on the Juno Janome Serger Model 3434D
sergers the most frustrating machines. Every time you change fabrics you go through a tension adjusting phase.
First make sure you have threaded the machine in the proper order. upper looper, lower looper, then needles from right to left. Always thread any machine while the presser foot lever is in the UP position.
If you ever break a thread... you MUST pull all threads and rethread using the proper order.
Ok that's out of the way. Pull all your threads and get out several pieces of the same fabric scrap. Thread each pathway with a different color. This will help you determine which thread is giving you fits. Sew a test strip. Which thread is loose? tighten/loosen that tension. Keep doing this until you have a well balance seam. Then clip the colored threads starting with the upper looper thread, tie off to your proper color for your seam pull the thread through and up through the throat plate. proceed in this manner with lower looper, right needle, left needle. Sew a test seam.
Good luck.
Aug 08, 2012 | Janome Sewing Machines
I have a janome 8050 sewing machine. It has started making loose stiches underneath and making a noise. I have changed the needle, bobbin, thread, cleaned the bobbin area. It will not make any stiches at...
The key to proper stitches is that tension on the bobbin must equal the tension on the upper thread spool as well. The bobbin has a tension screw that may have come loose or the thread is not properly in the tensioner. For example, the bobbin could be in backwards. Or the tension of the top could be too light and allowing the tension on the bottom to pull the thread down too much.
Open the bobbin tray and watch while you slowly rotate the hand control to see it make a stitch.
You will probably be able to figure out what is wrong.
Apr 08, 2011 | Janome Sewing Machines
The upper tension will not tighten on my Janome MC 8000. I have had it since '93 with no problems and all of a sudden when I was stitching the tension became loose on top (it was looping and making a mess...
Check for lint or thread in the top tension unit.....try "flossing" (as you would teeth) with a clean cloth.
Symptoms indicate top tension is being kept slightly open by debris.
Playing with the screw inside the cover on left of tension unit is not a great idea, it is designed for fine adjustment when tensioner is clean, so try to reset back to what it was before fiddling if you can remember how may turns you made.
If you continue to have problems, send a quick email (please mention the model and issue, we get a LOT of requests) and I shall see what else we can do to get you back on track.
CONTACT email
Jun 05, 2010 | Janome Memory Craft 9000 Computerized...
Janome MyLock 634D Mechanical Sewing Machine Logo
314 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
