Question about Kenmore 33464 / 33465 / 33469 Gas Single Oven
F30 ERROR UPPLUGGED IT FOR 2 HOURS STILL GET F30 ERR
  • alicerodrigu Aug 17, 2008
    Oven working fine then all of a sudden turned it on to bake rolls and started getting error F30......????
F30 error every time I turn the oven on
Posted on Jul 27, 2008
I HAVE A F30 ERR DISPLAY ON BOARD AND THE DOOR IS LOCKED. HOW DO I RESET AND GET DOOR OPEN?
Hello Friend, this is Z. I am happy to assist you!
If you are getting an error code F30 on your Frigidaire range, it usually indicates an issue with a faulty sensor probe or a wiring harness between the sensor probe and EOC (Electronic Oven Control). You may try and reset your range by disconnecting the power or by flipping the circuit breaker off and back on after 10 minutes. This often clears most false error code. If the error code does not clear, most likely the EOC of your range will need replacing. I am fairly confident that an authorized service agent will be able to restore your appliance to its normal operating condition. You can often locate a qualified service technician on the manufacturer website.
Aug 05, 2014 | Frigidaire Ovens
F30 oven won;t come on and
since how long are you getting this error ?
Jul 21, 2008 | Kenmore 33464 / 33465 / 33469 Gas Single...
PLES389ECH F30 ERR code. Oven and stove top is locked out after trying to run self clean. The fan is still running. I have turned breaker off and back on after waiting a day and range is still locked out....
This should help, good info includes links! http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/76555-error-code-f30.html
Oct 27, 2013 | Ovens
F30 err flashes on the board. Can't get it to bake or oven to come on.
If your oven is made by Frigidaire, the F30 error indicates a problem with the temperature sensor, wiring, the controller or the thermal reset. You will need to check the resistance at various points and replace parts as needed. There are actually 3 sensors in series on one model, with the reset switch under the sensor near the 12" burner. On this model the resistance across each sensor should be around 1100 ohms.
Please add a comment with the make and model for more information on finding the sensors.
Jan 01, 2013 | Ovens
F30 error on kenmore elite electric stove
F30 - Open Probe connections
F31 - Shorted Probe connections
Suggested Corrective Action
1. (F30 or F31) Check resistance at room temperature & compare to *RTD Sensor resistance chart. If resistance does not match the RTD chart replace RTD Sensor Probe. Check Sensor wiring harness between EOC & Sensor Probe connector.
2. (F30 or F31) Check resistance at room temperature, if less than 500 ohms, replace *RTD Sensor Probe. Check for shorted Sensor Probe harness between EOC & Probe connector.
Hope this helps (remember to rate this free answer).
Jun 04, 2011 | Ovens
My Oven is displaying a f30 ERR message and won't allow me to use my oven,,,the stove works fine....what do i do?
I have same problem, displaying a f30 err message and does not work oven rest is working. I have changed sensor still does not work.
Apr 17, 2011 | Frigidaire FEB27S6DC / FEB27S7DC Electric...
Had self clean on for a little over 1hour, was set for 2 hours and code F30 was flashing, self clean turned off
Hello & Welcome to FixYa
F30 error means open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you want to do it yourself and wan to be sure before replacing the sensor then you can test it with a voltmeter between 1080-1120ohms....if it reads more then or less then this then it needs replacement however, if the reading is around between 1080-1120ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 10, 2011 | Ovens
Frigidaire professional stove, Oven does not work, can't bake, self clean. get an ERR F30 code.
Is the clock set?
In mine - the clock has to be set - or it won't work;
Aug 12, 2010 | Frigidaire Ovens
F30 ERR message on Frigidaire Professional Series Range
I am a tech and just had this happen to me, so I can feel your frustration. I have replaced the temp probe, erc, and still had the problem.
Open the back, with the unit unplugged. On the lower right hand side there is a relay, beside the relay there is a "safety T-stat" disconnect from the circuit by removing one wire and read for continuity. If none is detected, replace t-stat and voila... stove works. Much cheaper than erc and probe...
Jun 11, 2009 | Frigidaire FEB27S6DC / FEB27S7DC Electric...
Kenmore Elite slide in range F30 error
I had the same F30 error problem but fixed it. On my professional series Frigidaire, there are 2 resettable red button locations. I discovered that only one is in the rear of the oven. After going to the breaker box and shutting off the power, pull out the stove enough to work, unscrew the rear screws (I didn't unscrew all of them, just enough to work back there). The small red button is on a small black round piece with two purple wires feeding to it. That was not my problem. Mine was the other red button behind the control panel. Pull off all 4 knobs, unscrew by hand the large black rings that are underneath the knobs, pull out the whole panel. Look back and right (below where the right knobs were located) to find the 2nd red small button. Push to reset. Check this one first since it is easier to do.
Dec 27, 2007 | Ovens
Kenmore 33464 / 33465 / 33469 Gas Single Oven Logo
373 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
