Question about Cameras
Lights out I was in my tanning bed and it sounded like it arked .the top lights went out and it smelled like rubber burning ,top lights wont come back on but bottoms ones are on.thanks for any help
    Problem Solver:
  • 5 Answers
Sounds like your top to bottom cord has shorted or, has a bad connection. Call Wolff Tanning at www.wolfftanning.com or 1-866-965-3382 for assistance. They have the parts for that unit.
Posted on Jun 09, 2010
  • 24 Answers
DUH?? This is a photography site, imbecile.
Posted on Dec 24, 2008
MY TAN BED WILL TURN ON BUT WONT LIGHT UP. COULD IT BE THAT MY 2/20 PLUG IS NOT STRONG ENOUGH?
No. DId you just get the bed? Are you sure it's 220V? what brand of bed?
Mar 15, 2016 | Health & Beauty
Accidentally plugged a 110 tanning bed into a 220 outlet. What may be damaged?
Actually the lights them selves might be damaged or the ballasts that start them. I do not know how you can test them. But if you look at the ends and they are black that is not a good sign. if they are the same shade from end to end thats good, the next thing might be the ballast's or starters. I do not expect you to have starters but they would be cheaper and easier to change if you did. To find the ballasts you would need to disassemble the bed. they would most likely be located between the lights and might power two four or eight lights each. and be connected to many wires. all leading to the lights at each end and the power supply. unplug the bed before you start they will be heavy and usually black color does not matter but they will be heavy. unless they are starters.
Sep 14, 2014 | Wolff Sunquest 14SE Tanning Bed
I have a Roper washer Model RAX4232PQ0 When it drains and spin cycle comes on it makes a very loud rubbing slash screeching sound and when we open it it smells like a burning smell Not rubber burning but...
Known problem:
A Failed switch Ark-Les part #8318084
Incident report on there website:
I have a Roper model #RAX4232PQ0 top-loading washing machine. The door switch wore out, short-circuited, and caught on fire. The machine continued to operate, so it took a little while to figure out where the smell was coming from. The failed switch is an Ark-Les part #8318084.
Dec 19, 2013 | Washing Machines
My local tanning salon said they use Wolff tanning lamps. What does that mean?
Wolff tanning lamps give off UV tanning rays like the sun but only UVA and UVB rays to help tan without increasing the risk of burning. These are the type of tanning beds that most salons use.
Feb 18, 2013 | Health & Beauty
What is a tanning bed?
A tanning bed is a type of bed (with a top and bottom part to it) that tans the user through ultraviolet radiation. There are tanning beds in salons but also home tanning beds which tend to have less lamps and use less watts.
Jan 10, 2013 | Health & Beauty
Sunquest 24s wont do nothing
Have a trained technician to check for blown fuse on back of bed and then for burned out wiring in top and/or bottom of bed. Voltage going to bed may also be a cause. These beds are sensitive to wrong voltages.
Dec 21, 2012 | Wolff Sunvision Pro 24S Tanning Bed
I have a sunvision 24 tanning bed and it isn't coming on what do i do
Have a trained technician to: Check main breaker, check that bed is getting power to it, check for bad fuse on back of bed, check for burned out wiring inside of bed at main relay, check that the timer is good.
Aug 28, 2012 | Wolff Sunvision Pro 24S Tanning Bed
My ESB tanning bed lights won't come on when turning on bed
my tanning bed comes on but wont light up
Jul 24, 2012 | Cars & Trucks
I need a owners manual for a Sunquest Pro 24 RS, Wolff Systems tanning bed
Have a trained technician to look at it. You probably have a loose wire nut in the wall box if it is hardwired or a loose connection on the wall receptical. The screws on the recepticals can come loose when pushing the receptical into the wall box. Most new construction uses plastic wall boxes so shorting out the receptical screws to the box should not be a problem. It is possible that the bare ground wire inside the box is hitting one of the receptical screws. If so, then push the bare wire away from the screws with an insulated screwdriver.
Jul 22, 2012 | Wolff Sunquest Pro 24RS 220 Volts
Car wont start Altenator seems to be struggling to turn and smells funny???
The bearings have went out of your alternator, you will need to replace it.
Feb 24, 2011 | 1996 Chevrolet Cavalier
Cameras Logo
198 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
