Thanks I removed the airport card and the display now works. Wondering what to do now about a wireless connection - do you suggest purchasing a new airport card and renstalling?
You may need to open it up again and remove first the airport card and turn it back on and if that boot your computer there's a possibility that your airport is causing the problem and the airport may be loose and touching some other parts on it.
Cut the airport off and back on again. After that, delete any wifi profiles you have, and then re-add them. This will clear any corrupt profiles and troubleshoot that. If you can't connect to anything after that, check that the airport card is connected securely. If, after all that, it still isn't working, and other devices are able to connect to the same network, then your airport card is probably no longer working.
What I would suggest is reseating the airport card as it may be the card has come loose or the cable is not connected properly. The following support page on the apple website will tell you how to do it.
I'm not sure I follow. Did you replace your old 'b' card with a 'g' card and now you can't connect as you did before? What kind of router do you have and what is it set to accept? Can it talk 'g' or is limited to 'b'? Can your new card connect in 'b' mode?
The easiest way if your Powerbook doesn't come equipped with an
Airport card or isn't capable of supporting an Airport card is to purchase this http://www.sonnettech.com/product/aria_extreme.html it slides into the PCMIA slot on your Powerbook G3 (the credit card sized slot on the side of your Powerbook G3). There's support issues and model variations on older Powerbook G3's regarding Airport Card support and they're not as readily available as a standard PCMIA wireless card. This is my best suggestion for your situation.
At this point you are much better off installing a USB wireless antennae than spending money on an Airport card, cracking open the iMac, and installing it.
USB wireless adapters are cheap, plentiful, and have more capabilities than the generation of Airport cards that were made for G5 iMacs.
I had a similar problem with my 15" 1.33GHz powerbook G4. My problem was I couldn't connect to a network right away or at all, or wouldn't properly reconize the card (didn't drop it).
I solved it by removing the airport card from my PowerBook and putting it back into my G4. it should be in the same location. it's underneath the battery pack. 1. power off your G4 2. remove battery pack 3. there is a latch on the right side (if the charger port is facing down), open it 4. pull back plastic cover tab and gently remove the antenna plug from the airport. 5. pull the plastic tab, until the airport card is removed, keep out for 30+ seconds to ensure it erases any corrupt log file on card it's self. 6 place airport card into the slot again, fully inserting it, it should go 1/8" - 1/4" into your powerbook 7. plug in the antenna plug back into your G4's airport(it should click 2x(very lightly)), flip plastic tab back over top the antenna cord, close you latch. 8. place battery back into your G4 9. plug computer in, turn on and it should work if not then there is something wrong with the airport card reader, which i don't think it's the case here..
