Question about Belkin Computers & Internet
Although I finished installation of Wireless G router, I cannot start wireless internet.
  • 84 Answers
Go to the web based control panel of your wireless and do some necessary configuration to allow you to connect the internet. you can go there by typing 192.168.1.1, by default its password is admin and username is admin. then try to check the configuration in the wireless, if its set to mixed and set if its static or automatic? and from there you have it connected.
ally
Posted on Jul 21, 2008
When i install router to use internet connection it says check your wires, although all wires are inserted correctly and router is showing lights for it. How can i install my router on my pc to use...
Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password
You can now change the admin password and configure the wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Mar 03, 2011 | NetGear WGR614 Wireless Router
How to instal
You'll wanna check out: ftp://downloads.netgear.com/files/WNR1000_SM_WW_23Jan09.pdf
Look for "installation"..
To help you set up your router and get on the Internet quickly, the Resource CD contains a Smart Wizard™ Installation Assistant. The Installation Assistant walks you through the steps required to connect your router, modem, and PC(s); configure your wireless settings; and enable wireless security for your network. When you have finished, you will be Internet ready!
You can set up your wireless router using one of two methods:
• Smart Wizard Setup: The Smart Wizard Installation Assistant setup is available on your Resource CD. See "Installing Your Router Using the Smart Wizard" on page 9 to use the Smart Wizard Installation Assistant.
- This is the easiest option. The wizard guides you through the setup process. It automates many of the steps and verifies that the steps have been successfully completed.
- Smart Wizard requires a PC running Microsoft Windows.
• Manual Setup: If you cannot or prefer not to use the Smart Wizard Installation Assistant, see "Manually Installing Your Router" on page 13. For example, if you are connecting to a Mac, are using a Linux operating system, or are technically knowledgeable, select this option. If you choose to use this option and install your router manually, for best results, install and set up your router in this order:
Failure to follow these guidelines can result in significant performance degradation or an inability to wirelessly connect to the Internet.
NETGEAR does not recommend or support adding a NETGEAR router behind another router, or replacing a gateway with a a NETGEAR router.
If you have a Macintosh or Linux system, you must use the manual installation method (see "Manually Installing Your Router" on page 13).Getting to Know Your Wireless Router 7
1. Install and connect your wireless router to your network (see "Connecting Your Wireless Router" on page 14).
2. Set up your wireless router for Internet access (see "Setting Up Your Router for Internet Access" on page 18).
3. Configure your wireless network and select wireless security settings to protect your wireless network (see "Configuring Your Wireless Network" on page 21)
Feb 04, 2011 | NetGear WNR1000 Router
CAN I GET ASSISTENCE,TO INSTALL MY PRINTER,VIA INTERNET?
THIS IS APPLICABLE TO YOUR PRINTER THERE ARE THREE TOTAL SOLUTIONS
Driver_1.00.01.zip file and save to your desktop. Use a file compression software to unzip the file located inside MyBook_vista_windows7_Driver_1.00.01.zip to your desktop. You will now see a file called "MyBook_vista_windows7_Driver_1.00.01.exe" or "MyBook_vista_windows7_Driver_1.00.01" on your desktop. Double-click on "MyBook_vista_windows7_Driver_1.00.01.exe" or "MyBook_vista_windows7_Driver_1.00.01" to launch the driver installation program. The wizard will display a message saying that it is ready to install the driver, click Next. Accept the license Agreement and click Next Click Install to start the installation of the drivers. The driver will be installed without further interaction and should take only a few seconds to install. When the installation is finished, click Finish to close the installation utility. Reboot the computer system before connecting the My Book Essential or Premium Edition hard drive. After connecting the My Book Essential or Premium Edition hard drive, Windows will automatically detect the unit and a new hard drive icon will appear in the My Computer window. Your My Book Essential or Premium Edition hard drive should now be ready to use.
Here are the recommended steps to connect to a wireless base router 1. Check and remove power from both your router and the DSL ROUTER/CABLE ROUTER MODEM 2. Wait one complete minute until applying power to modem then wait one minute before applying power to wireless router. 3. Ensure you have green lights across both devices, specifically, the recieved and sent lights. These same lights will tend to blink rapidly when there is active data, at times this will still blink, and a DNS error will prevent you from connecting to the internet. If this is the case, call your ISP Internet service provider 4. Check your authentication Security key on your router first, then check all your wireless devices to ensure they are on the same network name, key, and channel with the same type of encryption as the router 5. Start one device at a time and check for connectivity, if your still experiencing a problem, check the settings on all your wireless adapters, device drivers, internet browser settings, firewalls and proceed. 6. still have problems, connect a rj45 cable from the router directly to your computer to at least see if your wireless settings are bad or if the router may be bad. 7. Contact your ISP to determine if your receiving singal 8. Avoid using a splitter or parital power backup for yours routers 9. Still having problems, change your wireless router only after your ISP changes their faulty modem 10.Attempt the same process when setting up your new wireless router and or modem
Jan 23, 2011 | G7 Productivity Systems VersaJette M300...
Can you give me a step-by-step tutorial to install my wireless router to my desktop computer?
To help you set up your router and get on the Internet quickly, the Resource CD contains a Smart Wizard™ Installation Assistant. The Installation Assistant walks you through the steps required to connect your router, modem, and PC(s); configure your wireless settings; and enable wireless security for your network. When you have finished, you will be Internet ready! Here's the manual: http://static.highspeedbackbone.net/pdf/Netgear-WNR2000-manual.pdf
Dec 22, 2010 | NetGear WNR2000 Wireless Router
Wht should i do to conenct to internet
1. Uninstall or disable all Internet-sharing applications, proxy software and security software such as anti-virus programs or firewalls. Although every program is different, if you choose to uninstall one, you can typically do so by clicking "Start," "Control Panel" and "Add/Remove Software" and then selecting the software you wish to remove. Because Homeportal 1000 comes with its own versions of these programs, this step is essential to avoid conflicts.
2. Connect Homeportal's AC power adapter to the back of your router, and then plug it into a power outlet. The green power light should come on.
3. Connect the router to your
computer. If you're using Ethernet, connect the Ethernet cable to both the router and the Ethernet jack on the back of your computer. If you plan to use USB, follow the same procedure using the USB cable and ports, instead. For a wireless connection, ensure that your wireless card is correctly installed on your PC.
4. Connect the phone cable to the back of your router and then plug it into a phone jack. This will allow the Homeportal 1000 to receive DSL signals from the phone company.
5. Place the Homeportal 1000 installation CD into your CD drive and follow the on-screen instructions to install the necessary software and until finish installation.
We are now ready to browse a website.
Dec 22, 2010 | 2wire HomePortal 1000 Router
I bought a Belkin N Wireless Router F5D8236-4 v2 and changed my internet provider a few months later and I have lost the Installation CD, can I install it without the CD?
Yes you simply need to hook up via an Ethernet cable, open a browser type in the routers address, login with username and password, and then you can edit any setting you like. Then when finished you save settings and reboot router.
installation guide below.
en-us-support.belkin.com/app/answers/detail/a_id/2533
Aug 12, 2010 | Computers & Internet
I can't get the passphrase box to come up when connecting to the internet, so I think the connection is not secure. The router is a Netgear WGR614v10 wireless.
It requires setup. Did you do anything to it when you first installed it? By default, open internet explorer and go to 192.168.1.1 (just type that in the address bar). If the login comes up, use admin and password. If it opens up the Netgear control panel, start by going to Wireless Settings and change your security options. Just before you finish, also change the router's password to something other than "password".
Carl
May 22, 2010 | NetGear WGR614 Wireless Router
No Active Internet Connection
If you want to use the wireless portion of your router, you would need a wireless adapter installed on your desktop. If you are getting internet on your desktop then this means that your wired connection is fine to the router is fine. The WMP54G adapter will work with your router, however if you are not planning on connecting to the internet wirelessly through the router then there is no need to purchase the adapter. Hope that this helps you out.
Serge C.
Mar 30, 2009 | Linksys Wireless-G WRT54G Router
Internet access not working on desktop thru Netgear WGR614 router
Make sure your desktop doesn't have static IP address. Go to Network Connections, Properties of Local Area Connection, Internet Protocol > Properties. Select Obtain IP Address Automatically and Obtain DNS Servers Automatically. Apply the changes and restart the computer.
Jan 18, 2009 | NetGear WGR614 Wireless Router
Computers & Internet Logo
21 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
