Question about Samsung DVD-VR330 VCR and DVD Recorder
Can't copy to DVD
Hi, I have been using my VHS to copy to DVD and it was working fine. I then disconnected everything to move it to a new position. When I try to use it now {either with the remote or using the button on the front of the machine} a message comes up saying "this function is not available. The VHS plays fine as does the DVD. It just won't record. What is wrong? Thanks in advance, Jesse
    New Friend:
Most movies , on VHS , need a small decryption device to get rid of the ( Macrovision) protection, which will not let you record from VHS to DVD. I have one here that I use , works perfectly. It also decrypts from DVD to DVD , in case you need to back up a movie. Kids are allways banging DVD with scratches and it's not to copy the original & give them the copy to mess with, that way you allways have a perfect one in stock. If you ever need a converter , I have one left but works great. emailme:peppersradio@videotron.ca if interested?
Posted on Jan 25, 2013
SOURCE: Samsung DVD-4600 DVD/VCR Player
My Smasung DVD/VCR Combo stopped reading DVDs because of a dirty read head. It started by only playing disks sometimes, and progressed to never playing disks. I assumed it was a dirty laser lens so I bought a lens cleaner set. Unfortunately my player wouldn't play the cleaner disk.
So I took it apart and cleaned the laser lens manually with some isopropyl alcohol (the clenser that came with my cleaning disk), and a lens cloth (that came with my glasses). Just open the case (starting with the screws in the back) and remove the snap in cross panel that obscures the lens of the DVD portion. Put a drop of cleanser on the lens and gently wipe it with the cloth.
Oh and by the way, I take no responsibility if you break your own player while following my instructions. My own DVD player was far out of warranty at the time I cracked it open.
Posted on Jan 17, 2008
SOURCE: I have a Samsung DVD -VR 357 combo unit and i can't record
I have the Samsung dvd-vr 357. I have had a couple problems with it but I called samsung and they walked me through fixing it each time. I don't know if you have tried this or not but that is my suggestion. The last problem I had was copying from vcr to dvd. I got audio but no video. Problem was it was on dvd when i started it, it should have been on vrc. It should be set on whichever one you are recording from. Hope this helps someone.
Posted on Jan 10, 2009
blueextc3221
  • 15935 Answers
SOURCE: how do I record my vhs onto the dvd?
How about a USER MANUAL instead :D
Please note this unit is NOT a DVD recorder. It only has a DVD ROM drive to play DVDs - not to record to them.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on May 30, 2009
  • 909 Answers
SOURCE: DVD Recorder HR753 - having trouble copying
You need to finalize the disc for playing on other equipment. There will be an option for finalizing or closing the session in the recording menu.
Posted on Aug 26, 2009
SOURCE: cannot record copy protected message
OLD FBI WARNING USED TO ALLOW YOU TO MAKE BACKUP COPIES BUT THEY CHANGED IT KNOW THAT NOT EVEN THAT'S ALLOWED
OLD FBI WARNING DID NOT WANT YOU TO SELL, CHARGE FOR WATCHING BASICALLY MAKING A PROFIT OFF YOUR COPY
NOW YOU CAN NOT EVEN MAKE A BACKUP FOR YOURSELF
HBO, SHOWTIME, ETC ARE MOVIES CHANNELS SO IF YOU RECORDING OFF THOSE CHANNEL YOU ARE TECHNOLOGY COPYING ILLEGALLY
Posted on Dec 30, 2009
Cant copy from VHS to DVD
You may take a look at this guide, it's about how to capture video from VHS to computer and burn to DVD, it works pretty well for me
http://www.reviewstown.com/how-to-convert-vhs-tapes-to-dvd.html
Hope it helps. If you still have problem, feel free to contact me.
Jun 03, 2013 | Toshiba Cinevision DVD/VCR Combo
For some reason I can no longer copy from my VHS tape to my DVD disk in my Toshiba DVR620KU DVD Video Recorder. I have tried some of the same tapes which had copied just fine in the past. I am using the...
How old is Toshiba DVR620KU recorder and how long it started this problem?
Does it playback previously recorded discs correctly?
Did you tried lens cleaning disc in recorder to clean optical lens?
These info will help me to suggest a solution.
Thanks.
Jul 22, 2011 | toshibadirect.com
My JVC DR-MV150B plays prerecorded VHS tapes fine.
Try opening the front hatch of the tape by pressing the small, square button on the right or left (short) side of the tape. Check the black tape inside for any marks, dirt, scratches, tears, etc. If the tape is fine then your unit needs to be cleaned with a tape cleaner available at any electronics specialty or retail store. Good luck to you!
Jan 02, 2010 | JVC DR-MV150B DVD Recorder/VCR
Hi! I have a Magnavox DVD recorder/VHS combo. I
alot of times when the video cord gets pinched it will go to black and white you just have to replace it if that dont work. then its one of the machines.
Nov 06, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
VCR DVD Recorder not dubbing
I called the manufacturer and realized I was using the wrong type of recordable DVD disc to dub to. Non copy protected VHS tapes dub just fine as long as I'm using the proper disc.
Jun 03, 2009 | Sony RDR-VX530 DVD Recorder/VCR
Pictue but no audio on VHS playback..VHS record to DVD visual/no
Hi
please check the format settings, maybe the audio is not in good settiongs!~
Thanks!
Feb 01, 2009 | RCA DRC8300N DVD Recorder/VCR
Will not copy vhs to dvd
I had the same problem. What I had to do was press the 'dubbing' button on the remote while in VCR mode.
Dec 27, 2008 | Televison & Video
HOW DO I RECORD A DVD TO A VHS ON A VHS DVD COMBO BY PHILIPS
Cannot do this on a combo unit. There is a chip that senses copy protection and prevents recording a copy-protected DVD to a VHS and vice-versa. Solution: Use an outboard DVD player or an outboard VHS VCR and try the recording with the video routed through a "stabilizer" box. The stabilizer (about $30 or less on Ebay) defeats the copy protection on MOST DVDs, but not all. It works with Netflix DVDs. Route the audio as usual. Audio is not protected.
Dec 15, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Waiting for input signal
It's a protected video. The VRD-MC5 will not burn a VHS or input that has been protected.
Jan 09, 2008 | Sony DVDirect VRD-MC3 DVD Recorder
Dubbing vhs to dvd
Easy. Connect RCA lead from video/audio OUT on the VCR to video/audio IN on the DVD recorder. Set DVD recorder source to VIDEO then press play on the VCR and record on the DVD recorder.
Sep 09, 2007 | Aspire Digital AD-8091 DVD Recorder
Samsung DVD-VR330 VCR and DVD Recorder Logo
95 people viewed this question
Henry  Thomas
Henry Thomas
