Question about IBM ThinkPad T30 2366 Notebook
Ibm t30 a small picture of a pad lock appears on screen when i boot my t30 (looks like a dos screen. I removed memory it wouldn't start, i replaced it then removed battery and it went back to the drawing of a lock. press f1 and still would show a drawing of a pad lock? please help
    Genius:
  • 2,028 Answers
This is not good. It generally indicates that the security chip on the motherboard has malfunctioned. A hard drive failure can also cause this occasionally, but mostly it's the chip. Start by trying a new hard drive, if it works, GREAT, if not then the chip has malfunctioned and locked the system. Your only option is replacing the motherboard.
Posted on Jul 22, 2008
IBM think pad my screen does not show anything but the cursor
Run the Check Disk UtilityTo run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Apr 14, 2012 | Computers & Internet
T30 still won't boot after fan replacement
One of your memory slots might be bad as I'm assuming you tried both memory chips in the known working slot.
I found setting the boot up sequence in BIOS is better than using F12.
Set your BIOS to boot the CDROM first. I suspect the hard drive has failed or has a problem. Do you have a floppy boot disk? Lenovo has PCDoctor bootable diagnostics on their website. You may have inadvertently bent a pin inserting the hard drive. Your CMOS battery could be dead but since that was untouched I would be surprised.
Sep 08, 2008 | IBM ThinkPad T30 2366 Notebook
Memory upgrade
Usually there will be 2 screws to remove (these may be hidden via rubber pads, or labels). The appropriate panel will have a RAM "picture" next to it.
May 26, 2008 | IBM ThinkPad T30 2366 Notebook
T30 boot problemos screen.
you have been trojaned hit by spyware
2 main progs. you might want to look for spyware blaster and spybot search and destroy these are freeware and doesnt require signup these will clean your comp of the bugs
May 20, 2008 | IBM ThinkPad T30 2366 Notebook
Stopping at the BIOS Splash screen
Hi
Reseat all the RAM, CMOS battery and any PCI graphics cards and then try to boot the computer.
Also remove all the memory cards and then turn on the computer. If you dont get any beep sounds, then it is a problem with 1 or more RAM cards.
Then alternatively try with 1 RAM at a time in different slots and check if it is a problem with any of the RAM cards or the RAM slots.
Feb 26, 2008 | IBM ThinkPad T30 2366 Notebook
IBM Thinkpad T30 2367 beeps 8 times
It's your memory, or more to the point, the memory slots. take all memory out, install 1 piece in the slot closest to the back of the laptop, push down on the memory as if pushing it into the motherboard, and hold pressure while booting.
Bet that works. if not, let me know.
I've got the same machine.
Good luck
Jan 03, 2008 | IBM ThinkPad T30 2366 Notebook
T30 boot problem
Sorry, but probably your T30 (my favorite Thinkpad) has developed a problem with one of it's memory slots. It is an inherent problem with the Thinkpads. The way to tell is topress on the memory cover in a way that pushes the memory (or more to the point, the memory slots) into the motherboard. While keeping pressure on the memory, try to boot up. I use a T30, and have worked on several others, all have at least one slot with this problem. Also try taking out the memory which is closest to the front of the system, and pushing in on the remaining one. Hope this helps. If this is the problem, there are a couple of things you can do to keep it running, but probably with only one ram stick. Goood luck
Oct 07, 2007 | IBM ThinkPad T30 2366 Notebook
T30 led's
a small board that attaches to the mainboard via a small cable has come unplugged. remove the lcd bezel and check connections rto te motherboard itseld from a small daughter card.
Aug 26, 2007 | IBM ThinkPad T30 2366 Notebook
T30 startup problems...
We can start with the easy stuff first. Move the memory chip to the other slot. Remove the small square plate on bottom of the laptop. You'll need a really small screw driver for this. If you have two chips, remove one and see if the laptop will boot-up.
Jun 28, 2007 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad T30 2366 Notebook Logo
214 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
