Question about Panasonic KX TGA272 Cordless Expansion Handset (KX-TGA272)
Panasonic KX-TGA272 The display has quit working on the unit. It still rings and you can talk on it. Is it worth repairing and if not where can another be purchased?
I have several of these same phones. I have found that when the battery is beginning to fail, the phone works but the display scrambles. A new battery should fix it. Also, take a pencil eraser and clean the contacts. This is actually the best phone I have even owned. Docbain
Posted on Mar 10, 2009
Panasonic KX-T7731 Programming Manual
We have two phones KX-T7731 (Main phone) + KX-T7020 in another office. We talking on phone and another call comes in it use to ring on the spare phone. Now it does not ring until 4th ring and goes right into answering machine. It use to ring on second ring. Is there a way to program phone to ring on second phone after second ring?
May 03, 2012 | Panasonic KX-T7731 Corded Phone
How do you turn off talking caller ID on panasonic kx-tg4032?
This feature lets you know who is calling
without looking at the display.
To use this feature, you must:
- subscribe to a Caller ID service of
your service provider/telephone
company.
- turn this feature on (page 24).
When caller information is received, the
handsets and base unit announce the
caller's name or phone number received
from your service provider/telephone
company following every ring.
The unit announces in English only.
L Name pronunciation may vary. This
feature may not pronounce all names
correctly.
L Caller ID service has a limit of how
many characters can be displayed. If
the caller's name is too long, the
handset may not be able to display or
announce the entire name.
L The announcement is heard at the
same level as the ringer volume (page
16, 23).
L If you turn on the answering system
and set the number of rings "2
rings" (page 36), the unit does not
announce the caller information. If
"Toll saver" is selected and there
is a new message, the unit does not
Mar 24, 2011 | Panasonic KX TG4032 19 GHz Twin Cordless...
My panasonic phones do not ring when an incoming call is coming in. There is a dialling tone on all 3 handsets and they all appear to be working ok
Ringer turned on? quite common and I'm a phone repair man. Does the calling party hear multiple rings? If it rings only once and goes to silence on the calling party end, there is a high resistance short on the line and it must be repaired.
Oct 19, 2010 | Panasonic (KX-TG1032S) Phone
Panasonic Kx-TG2432 Displays E9
Same here on KX-TG2248:
"Answer on" is flashing rapidly.
"Message/Slow Talk" is flashing rapidly.
"In Use/Charge" is flashing irregularly.
LED displays "E3" (and "set clock" symbol is flashing).
Removing and restoring power, many times,
produced one "spontaneous remission"
(it worked fine for several hours)
but next time moved (having to disconnect power),
it's now quite "committed" to remaining "insane" as above.
Jul 28, 2009 | Panasonic KX TG5100M Cordless Phone
Message problem
In your case there is no problem regarding your cordless phone. The problem might be in your network only. So please contact your network officer immediately.
Mar 18, 2009 | Panasonic KX-TG6700 Phone
One handset works, the other displays
Pull the battery out of the afoul unit. Let sit for 5 min. Put battery back in unit and set it in the base unit.
Feb 28, 2009 | Panasonic KX-TG1033S Cordless Phone
Phone wont talk--it has talkingidfeatures
The ringer has to be on first. Usually the unit announces the caller’s name after the 2nd ring. If you turn on the answering system and set the ring count to “2” the unit does not announce the caller’s name. Set it for more than 2 rings for name announcement.
Jul 16, 2008 | Panasonic KX-TG5632 Phone
Carnt change the time on my phone
For Panasonic system (especially for KX-T7633), you have to make changes from extension 101.
1. leave handset in the cradle then press "program".
2. Dial *# then "SP-PHONE" button until you see something like time set something something
3. manually input correct date then time then press "auto dial/store" button.
4. pick up the handset then hang up to save.
Mar 30, 2008 | Panasonic KX-T7633 Corded Phone
KX-TG6071M 5.8 GHz talking caller id not working
Hi trinigirl, You should not have to do anything to make the caller id information come through. There is no programming to perform for the regular caller id identification on your display after the second ring (it takes at least one ring cycle for the digital information to pass through). Your model also has the talking caller id function, which will announce in English the callers name or a custom name you can prepare in the phone book of handset number 1. With all that said, you are not getting caller id showing after the second ring, then your phone is bad (which is pretty rare for this symptom), or your phone line still does not have caller id activated. To troubleshoot your problem you need another phone line with working caller id and/or a different phone that is known good to pass caller id. That way you can interchange the phones/lines to see if it is your line or your phone. My guess it is your line somehow, though I have fixed phones that won't pass caller id, but rarely. If it is your phone, try rebooting it, thats about all you can do short of sending it in for repair. Let me know how it goes. CG
Feb 19, 2008 | Panasonic KX-TG6071M Cordless Phone
Panasonic KX TGA272 Cordless Expansion Handset (KX-TGA272) Logo
191 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
