Question about Dryers
Whirlpool Duet Dryer
Hi, We have done this, any other suggestions would be appreciated.
Thanks
I would open up the outer panel and take a look at the control area and see if there is anything out of the normal. Clean it up and see if it starts to work. Make sure you unplug it and let me know how this goes so I can suggest what other things you may try.
  • mbrzez Aug 05, 2008
    Delicate, Casual and timed Dry Cycles do not work when pushing start. . All other cycles work fine. There are no code errors . If I go from a cycle that works after pusing start to one of these a dashed line appears. I read to test P-11 and P-14. What are these and where are they located? Any other suggestions
    where on the control panel are they located? I do not see that P number on the panel.
  • 3,037 Answers
Alright, I posted a request in your premium problem for you to send me a picture. I'm thinking possibly a fuse needs to be replaced. Do you have an ohm meter to check connections at all?
Posted on Jul 21, 2008
  • Benjamin Patri
    Benjamin Patri Aug 05, 2008
    Those are pins located on the control panel most likely which control those cycles, you should test them while trying the cycle
  • Benjamin Patri
    well, let me explain it better since I was quite tired when I first answered the pin question. The pins will be connectors on the control panel or anywhere else that control the functions that aren't working. They probably are Not labeled so you will need a service manual which most likely would need to be purchased but sometimes can be found online with extensive searching. I do not have a manual for this specific washer. A connector itself depending on how it is labeled may have multiple pins per each wire. Does this make sense?
Control panel not working
Hi
Thanks for using FixYa. To reset the dryer you’ll need to press and hold the END OF CYCLE button for 10-15 seconds. If still the issue is not resolved then unfortunately you'll have to replace the control panel. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 31, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool duet dryer does not run. The control lock light stays on even after I hold down the end of cycle button for over 5 seconds and/or unplug dryer for over 15 min. The light comes on when door is...
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 19, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Where is the serial # located on the Whirlpool Duet Dryers
On a tag on the door sill opening.
Or on the back near the control panel.
Mar 31, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Duet error code e1
Whirlpool Duet E1 Error
E1 is an open thermistor. The thermistor lives on top of the blower housing. Get to it by removing the bottom quarter panel.
The quarter panel is right there in front, down at the bottom, below the door. Look closely and you'll see two screws. Remove them and the panel comes right off.
Mar 02, 2010 | Whirlpool GGW9200L Gas Dryer
My whirlpool duet will not drain or spin
Hi
The drain line is probably clogged. Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. In this case it may then get into the drain hose that's attached to the pump.Remove the hoses from the pump and pull the item out. In case it clean there, check the outer tub port- open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then,try to remove the clothing through the port.
Thanks for contacting fixya.com
Nov 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I keep getting an E1 Error code on my Whirlpool Duet dryer. Technician came and didn't fix it. Any suggestions?
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
Aug 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool duet dryer
Press/hold start for 5-10 seconds.
May 12, 2009 | Whirlpool GEW9250 Electric Dryer
I have a whirlpool duet gas dryer. how do I open
1. Unplug the unit while servicing inside.
2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
Mar 26, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool Front Load Duet Dryer
Holding the End Cycle button for a few seconds worked! Yes
Aug 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Dryers Logo
Top Dryers Experts
