Question about GE (PSS26MSRSS) Side by Side Refrigerator
G.E. refrigerator How to engaged defrost on a G.E. refrigerator with a board?
  • 1 more comment
  • Anonymous Jul 22, 2008
    I have tried this twice. When I replace the board is there some kind of code I should used when I installed it?
    I tried the solution twice It would work 3 or 4 days then frost would built up on freezer wall then stop making ice and stop cooling. When I replaced the board should I use some code when I installed it?
  • jdeez Jul 22, 2008
    I still want to know.
    My freezer is totally frozen behind the back panel, AND all the evap coils are covered in ice.
    I've been defrosting it with a hair dryer for the last 2 weeks...ugh
    Is there a method to manually engage defrost cycle, check if defrost heater is bad, or test the thermostat?
    The thermostat is CHEAP, and I'm considering replacing it just to see if this fixes it.
    Any and ALL advice welcomed...except advice to replace board, please? :-)
    At this point (before any real diagnosis is complete), spending $300 on a new board seems premature.
    THANKS!
  • 89 Answers
I do not suggest attempting this! If you think you have a defrost problem you need to test other thermostat and heating elements FIRST! But, I will tell you from experience that 90% of the time it is the computer board that needs replaceing.... Only if your having a defrost problem..IE., ice build up on evap coils. Replace the board and defrost all the ice with a hairdryer. And since you have the back wall off in the freezer you might as well replace the thermostat.
Goodluck,
Brian
If you still REALLY just have to know how to put refrigerator in defrost cycle just let me know.
Posted on Jul 21, 2008
How to turn my refrigerator off to defrost
Your model has a control Board that most likely automatically controls periodic defrosting. If it's not defrosting, then that Board, the heater, or defrost thermostat is bad.
Sep 07, 2017 | Samsung Refrigerators
Why mu refrigerator rrtg21pabb ia working but not freeze
If the refrigerator is not defrosting, the defrost control board might be defective. The defrost control board monitors several conditions and determines how often to run the defrost cycle. If the board fails, the refrigerator will not go into the defrost cycle. Eventually, ice will build up on the evaporator coil and then the refrigerator and or freezer will not stay cold enough. This will depend on where the evaporator is located. It's prudent to check the defrost heater and defrost thermostat for continuity before replacing the defrost control board.
Aug 27, 2014 | Haier RRTG21PABB 20.7 cu ft Two Door...
Afb910 freezer not freezing
If the refrigerator is not defrosting, the defrost control board might be defective. The defrost control board monitors several conditions and determines how often to run the defrost cycle. If the board fails, the refrigerator will not go into the defrost cycle. Eventually, ice will build up on the evaporator coil and then the refrigerator and or freezer will not stay cold enough. This will depend on where the evaporator is located. It's prudent to check the defrost heater and defrost thermostat for continuity before replacing the defrost control board. If that is not the problem then the coil might have a hole in it and needs repair and coolent rechrge.
Aug 26, 2014 | Freezers
Samsung refrigerator defrost problem
Check the defrost drain hose. If it is plugged, the water from defrosting has no place to go, so defrosting doesn't do much.
Also, make sure you have power to the defrosting circuit (you may have a problem with the wiring). The simplest and safest means is to do a continuity check of the wires between the control board and heater with the refrigerator unplugged, or unplug the heater connection to the control board and measure the resistance of the heater through the connector(s). If it is open or very high, examine the wire terminals for corrosion. If the defrost control board is separate from the rest of the refrigerator control system, check for power coming into the board.
May 12, 2014 | Refrigerators
Defrost is stuck in one all time it not cooling or freezing
A DEFROST TIMER is a cycling device, it times the frequency and duration that the defrost heater coils melt the ice that builds up around the evaporator coils. If ice is allowed to build up, air will not be able to freely flow past them - resulting in reduced efficiency and sometimes a drastic warming of the cooling unit.
Most of the time, the defrost timer is in the cooling mode, allowing the compressor to activate when the thermostat signals it to. The remaining part of the cycle (usually less than 30 minutes)the timer is in defrost mode. In this mode, it signals the defrost heaters to melt the ice build up on the coils. This defrost action is limited by the defrost thermostat. If your DETROST TIMER go to bad, one symptom would be if your refrigerator is not cooling. Although there are many causes of this symptom, A stuck defrost timer can be one of them. The timer can get stuck in cooling (compressor activated) or defrost mode (defrost heaters activated) for usually two reasons:
- The timer motor can fail for one.
- The gears can also become locked up.
No matter what the reason is or which mode the defrost timer gets stuck in, the refrigerator can stop cooling. When the refrigerator is stuck in defrost mode, the compressor no longer comes on to cool the unit. If the timer gets stuck in cooling mode, the evaporator coils never get a chance to defrost, causing ice build-up to the point where there is a complete blockage of airflow past the coils.
The defrost timer can also cause the refrigerator to stop cooling due to failure of the internal switch which activates either the compressor or heater coils. Finally, when doing any repair on a refrigerator, check the condenser coils for dust buildup and clean accordingly.
According woth yur brand and model, look the part replacement in this link: partselect.com/refrigerator+test-defrost-timer+repair.
Good luck.
Jul 16, 2011 | Refrigerators
Where is the hotpoint HSS251FMD WW defrost timer located?
Hi, I think Your model number is HSS25IFMDCC . There is no defrost timer on your refrigerator, main relay board controls defrost cycles in this fridge. main board p/n WR55X10942 But I suggest to check on heater and defrost switch first - more common problem on this refrigerators. here is my video. hope it helps.
Aug 24, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Not cooling/freezing good
sounds like a defrost problem. defrost system consists of defrost timer or defrost control board,defrost heater,and defrost thermostat. most maytag sxs refrigerators have a circuit board in charge. part no.61005988 adc board.change the board and yer in business...
Jan 11, 2010 | Maytag Refrigerators
What if both sides of the refrigerator is not getting cold?And the back of the freezer side has frost.
Defrost problem. Either the defrost thermostat, defrost heater or defrost control board needs replacement. The defrost heater has to have continuity. The defrost thermostat has to have about 0 Ohms while it's cold. If both test out ok - replace defrost control board.
Part locations: Defrost heater and thermostat: under your frosted cover; control board - left upper corner of fresh food section, under the damper cover, in the middle.
Part numbers:
240554502 - control board
5303918255 - defrost heater kit
Can't find the part number for the defrost thermostat
Oct 17, 2009 | Frigidaire FRS26R4A Side by Side...
Freezer is working and refrigerator side is not work.
Most times that is a sign of a defrost problem. And because yours has the defrost board made onto the mother board we will need to do some looking around for the problem. Unplug refrigerator and pull away from wall. On back there is a cover over an area that contains the mother board. With power off take the board loose and examine the board for burn marks, sign's of heat or melted away solder connections. If the board looks OK the return it to its place and remove the rear panel in the freezer section. Need you to disconnect one end wire on the defrost element/heater. Check continuity through the heater to make sure there is no burnout. The defrost thermostat is connected to one end of the defrost heater. The contacts are open when the temperature is 50 degrees or higher, so testing it would look bad above 50 degrees. Just look to see if there is any deformity. If defrost thermostat is defective it will not allow the defrost heater to engage or to remain on long enough. Let me know what you fins. Sea Breeze
Jun 21, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Defrost problem...
check at front of fridge on bottom behind kick panel or at rear of fridge near compressor on some models you can manually engage defrost cycle,it looks like a small sometimes metal box with wires out of it,it will have either a protruding knob which is turned or a depression in which a screwdriver can be placed to rotate it.if it goes onto defrost and works o.k. this timer will need replacing
Aug 09, 2008 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
224 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
