Red shadow on screen double image
THANKS FOR YOUR INTEREST, I TRIED THE MENU OPTION AND TRIED TO CHANGE A NUMBER OF SETTINGS BUT NONE WORKED, NOT SURE WHAT I NEEDED TO ADJUST. I WOULD LIKE TO TRY TO WORK OUT THE PROBLEM MYSELF. PLEASE GET BACK TO ME AS SOON AS YOU CAN.
REGARDS
  • 927 Answers
Good Day,
blue5j;
In order for me to help you further I will need more details. So, if you can provide me with the Brand and Model number?
Thanks, big IRISH.
Posted on Jul 21, 2008
I asked why the heads are cut off on my tv. I was told to adjust aspect ratio on the screen menu. I cannot find aspect ratio on screen menu. HELP
It will be listed as screen option, it will be "widescreen" "panoramic" and regular broadcast image, no such button as aspect but the above are aspect options.
Jan 11, 2017 | Televison & Video
If the converter goes out does the tv not do anything no screen light uponly red standby light?
if your question is that if cable or sat converter goes off for any reason , will your tv display a black screen , then the answer is yes , without an input most all tv sets will display the opposite of full white , this being full black , also any on screen displays might not work as well (no video to sync too)
Jan 10, 2017 | Televison & Video
What is the problem of my sony bravia klv-32bx35a double image after sodering the t con bord the image was lost all black....hope you can helpe thankyou
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jan 09, 2017 | Sony Televison & Video
I HAVE AN AKAI HD TV DVB-T32W. When I started out first time, it autoscans but found no channel. press DTV or ATV, it,says "No channel. need to rescan". But nothing happens, thanks
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Jan 09, 2017 | Akai Televison & Video
Truetech 10 inch under the counter tv is stuck on channel 2. I need 3. Channel buttons on tv & remote do not change 2 to channel 3. Unplugging, Resetting hasn't worked Any ideas?
Jan 08, 2017 | Televison & Video
My lg plasma tv is cutting off the edges of the shows we are watching. I cant find a setting that will take care of it. Can you help
hmm normally these settings are found in the picture settings of the set top box or just a setting in the tv's picture settings now there might be an option to say fill screen that may work best for some or leave the tv in 16:9 some broadcasts may only be in 4:3 at times this is normal broadcasting and not much can be done unless the setting on the picture option is set to fill screen
Jan 08, 2017 | LG Televison & Video
Suddenly I have double images the bottom 2 inches of the screen they are accompanied with wavy lines but function with all activities as normal, what can cause this?
The TCON board or thr LCD panel is faulty. Can confirm by replacing the TCON board.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
I have a lg tv 60 inch tv ln5600 when powering on red stand by light blinks 3 time then no light pic or sound not backlight and no image when using flashlight treid replacing power board does same
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
TV just flashes different colors
You have entered a diagnostic colour test. With the TV powered on, hold the 'Menu' & 'Enter' together, then press the power button. Problem resolved
Jun 25, 2006 | ViewSonic N2750w 27 in. HD-Ready LCD...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
