Question about Maytag Atlantis MAV6000 Top Load Washer
My washmachine smells horrible. My whole house it starting to smell like it. What do I do??
Pull the fabric softener dispenser cap off and look down the center of the spindle. The fabric softener when spun will slosh out the outer edge of the cub and go down through the spindle and I have found this needs cleaned out like once every 2 months or the holes in the bottom of the spindle gets clogged and then the softener solution just gels up and stinks. Try scooping out the gel stuff, and then take a ratchet and socket (dont remember the socket size) and unscrew the bolt that holds the spindle on and take the whole spindle to the car wash and use the tire & engine cleaner on it, and then rinse it out good until the water runs through the holes in the bottom.
Posted on Aug 12, 2008
My whole house smells like rotten eggs from my washing machine. I am currently running a hot water cycle with 3 tablets of Affresh (bought at Home Depot)...I'll know in about 30 minutes if it worked!
Posted on Aug 01, 2008
    President:
  • 1,462 Answers
There is nothing in a washer to smell - just stainless steel, rubber and plastics!
check the following:
are you using liquid detergent? if so after extended use, the machine smells like drains. put on the hottest wash with no clothes and smell will go. revert to using powder.
check there is a water barrier between the drain hose and your main drain. if not, the smell of your sewer will come up thro the drain hose.
is the drain connected to a spigot off the sink trap and do you have a waste disposal unit? these stink and unless you again have a water barrier the smell will come thro the drain hose
Posted on Jul 21, 2008
I burnet a styfoam, and plastic cover in the microwave. The smell is awful, like melted plastic and burnt wood. My entire house smells horrible. Is there some way to get the smell out.
Try pouring some vinegar in a cup and microwaving until the vinegar steams. This works well when burnt popcorn smells up the microwave.
Apr 21, 2016 | In Microwave Ovens
New lenomex has a horrible chemical smell - I sprayed waterproof on a jacket and am assume it has picked up fumes. How can I get rid of the smell. it is past its return date and need a fix, please
The heater will burn the fumes off , how long it will take I don't know.,can you put it out side and let it run till the smell goes, never spray any thing on the heater elements you could have a fire.
Jan 05, 2016 | Heating & Cooling
Burnt fish smell in microwave
Mix vinegar and water in a small container, set timer for 60 seconds and start the microwave, when it starts to steam it will bond to the interior, at that point dis-engauge microwave oven, if smell is still present open a small box of baking soda let sit for 24 hours in the oven before use.
Jun 02, 2012 | Panasonic Microwave Ovens
Smell
Clean all parts of the machine thoroughly. If you are using frozen chips, try another brand.
Nov 30, 2011 | Tefal ActiFry Deep Fryer
My washington machine water smells horrible, but not the water in the rest of the house. It all enters the house through the same pipe from the municipal water supply. Could there be something within the...
You probally have a front load washing machine. There is probally mildew in the wash tub & discharge hoses. Try washing an empty load with a hot water and a cup of vineagar and see if that helps with the odor. If it does, then repeat this once a month.
Jul 20, 2010 | Maytag Washing Machines
Rotten smell from my air conditioner unit
make sure your drain hose is draining, It drains all the condensation from the unit, then you will need to clean the coil(s)
Jul 30, 2009 | Sharp CV-P09FX Air Conditioner
Dc 14 animal emits a terrible smell after about ten minutes of us
You can take a Febreze sheet and put it into the canister/dirt bin where the dirt spins around. It'll spin around whilst you vacuum your house and it'll spread the fragrance through the vacuum and hopefully get rid of the smell for you.
You can also blow out the cyclone with an air compressor or a leaf blower by opening the bin door on the bottom of the dirt bin and blowing up the cyclone in the middle - perhaps there is something lodged up there that is causing the foul odor.
Mar 21, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
I have a Kenmore washing machine and so far I haven't have a problem with it...the problem is that most of the time when we do laundry a horrible sewer smell comes out. It doesn't seem to be coming from...
You are probably correct with the idea the sewer smell is not coming from the washer but rahter then drain line. Was this recently installed or has a slow drain down the pipe? There is suppose to be what is called a P-trap installed in the drain pipe to restrict the gases from coming back into your home. Check the drain line. If I can help further, I am here. Eric Campion
Mar 03, 2009 | Washing Machines
Horrible Water Odor
Does the old house have any time of whole house water filter or water treatment system? Usually with sulfur water it is necessary to treat the water. It can be nasty. good luck
Jan 19, 2009 | Franke 900 Gold Basket Strainer 900
Neptune t.l. washer has a horrible odor that we have not been able to fix, either with bleach & vinegar solution nor with Electrasol lemon scent dishwashing powder, as has been suggested to us. This...
if you use liquid detergent for a long period this will cause a nasty smell and it leaves a horrid slime in pipework etc. if so, put on a boil wash and change to powder.
also, make sure there is a water barrier between the washer drain pipe and your house drains
Jul 11, 2008 | Maytag Washing Machines
Maytag Atlantis MAV6000 Top Load Washer Logo
306 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
