Question about XION (XON-500F8X2-201) (XON-500F8X2-201) Power Supply
XION Case and Supply
Hi, T-elos!
I read your post on the XION supply. I just reinstalled some innards into a new XION case. When I hook up the ps to the MB and flip the PS switch outside the case, I get a momentary light-up on the case fan, and then it turns off. When I try a load without hooking up the ps to the MB first, nothing happens. Is there something I'm missing?!? Why would it turn on and then off when hooked to the MB, but then not turn on at all when I try a simple load?
Thanks!
Jaygere79@yahoo.com
Jack
  • choochoo2525 Dec 28, 2008
    I czn't seem to get xion cpu to boot up microsoft windows correctly!
  • 3 Answers
T-elos here...
To test the PSU without a MB plugged in, you have to short the green wire on the 20/24 pin connector to a ground or black wire on the PSU, and that will turn it on. I have the problem where it turns on and off about 15 times before staying on and powering up.
Posted on Sep 27, 2008
  • 83 Answers
Try unplugging, then plugging back in the 20/24pin power connector. When you plug in the power connector, make sure the power supply is OFF and the switch in the back is OFF and nothing is plugged into the computer.
Posted on Jul 27, 2008
JUST bought a xion amp solaris pc case and can't figure out how to get the front panel off
At a guess, you'll have to take one side off then look inside, behind the front panel, look for sprung plastic lugs at the bottom, middle and top of the case.
The front may be hooked in one side so there will only be clips for the other.
Sep 12, 2010 | XION Solaris (XON-409) ATX Mid-Tower Case
Im trying to install dell i530 into Xion II case but cant figure out how the power switch led hooks up?
All of the pins locations and settings should be available on the motherboard manual. The pins should usually be located at the very bottom. ALL of the pin's settings will be labeled underneath the pins, but often hard to see, that's why I recommend reading the manual. All of the switches and LED pins will be different on different motherboards. The USB, if you have ones that are all separate connectors, goes like this: [+5V/VCC/Power] [D+] [D-] [GND]. USB and audio will always be the same.
Feb 17, 2010 | XION II Black Pearl ATX Mid-Tower Case
Replacement Door for XION case
Contact support to see if they will give you a replacement, if not, you can check e-bay to see if they have spare parts otherwise you might just need to buy a whole new case.
Dec 17, 2009 | XION II Black Pearl ATX Mid-Tower Case
I have a power supply that is turning itself off immediately after switching it on it is a new motherboard as well Any ideas why ?
I think either the MB or the CPU is with problems.
Try (2 after 1 works, 3 after 2 works...):
1) only PSU+MB+CPU and Fan - works? beeps like crazy?
2) add memory - works? single beep?
3) add/connect video - any image?
All other connectors off (disks, etc) only PSU, fan and case buttons.
If you don't get past 1), go back to the store and have it tested/returned there.
Mar 20, 2009 | OEM Systems Xion / 400-Watt / ATX / 80mm...
Whining sound with xion 800 watt power supply.
There is a fan insine the power supply, and also a fan on the CPU. Occasionally there is also a fan on the chassis of the computer itself.
Turn on the computer, take the case off, and listen to identify the source of the noise. If it's inside the PSU, return it and get a new one.
Feb 20, 2009 | XION PSU XION|XON-800R14N 800W RT
I purchased a zion 2 case and I cant figure out the fan plugs because the plugs are like the ones use for cd burners to power themup
To connect the power cable, just take the 4-pin connector coming from the fan and connect it to any 4 pin connector coming from the power supply. you can then use the 4-pin connector to power a cd/ dvd drive or ATA hard drive
~gnomer
Jan 31, 2009 | XION II Mercury (XON102) ATX Mid-Tower...
Loud buzzin sound on start up
If the POST screen is coming up, showing the the correct amount of memory in the system, and then telling your hard disk failure or something similar, your hard drive has failed. Put a new hard drive in the system, reload your operating system and all drivers, and attempt to use the old hard drive as a second drive long enough to get any files you need from it.
Dec 31, 2008 | Azza Xion II Series Gaming Computer Case...
Power Hiccups and Cycles
Faulty electrolytics in the power supply. Buy a new one or get it serviced.
Sep 27, 2008 | XION PowerReal 600 (XON600F14T201)...
Can't turn on PC, Presario SR2163WM
You sound like you know what you're doing, so I expect you've made all the motherboard connections(Same as the original PS). Does the switch work when you test it? If so, it sounds like the PS is DOA. I've had bad luck with cheap power supplies.
Sep 17, 2007 | XION (XON-500F8X2-201) (XON-500F8X2-201)...
XION (XON-500F8X2-201) (XON-500F8X2-201) Power Supply Logo
160 people viewed this question
Top XION Computers & Internet Experts
Jax Planet
Jax Planet
shuyumeng
shuyumeng
Are you a XION Computer and Internet Expert? Answer questions, earn points and help others
